Did you figure out what this problem was? Exact same thing happens on my 40D. Push the shutter button and it switches off. Have to remove the battery for it to switch on again. After a few times of resetting it, it seems to start working fine for the rest of the day. It does however appear to be getting worse. It actually started doing this when I tried to use the pop up flash and now its moved to the shutter button. I'm about to send it in for repairs. Any ideas??
Comments:
Sep 14, 2009
- Thanks for the replies. I have two genuine canon batteries. One is brand new. Problem occurs even when they fully charged.The battery was my first suspicion. I will try clean the contacts although they look clean. Will post again and let you know what happens. Thanks
Oct 26, 2009
- Yes I figured out the problem, well... not me, but the repair guy. They had to replace the shutter motor. Cost me about $275 to repair. All sorted now. They did service it at the same time so it looks brand new. I think its worth fixing...
Before you send the camera in for repairs,
try this free fix. The problem that you described is frequently battery related. Make
sure that your batteries are the correct type for the camera, and that
they are fresh/fully charged. If the batteries are OK, the problem may be due to corrosion on the contacts inside the camera. Remove
the batteries and wipe the inside contacts firmly with a dry cloth
(heavy corrosion may require cleaning with a wire brush, steel wool, or
sand paper). Remove any residue that may have fallen into the battery
compartment during cleaning, wipe the ends of the batteries, and
replace them in the camera. This cleaning process works about 90% of
the time, and I hope that it cures your problem.
I'm having exactly the same problem - so far cleaning the battery doesn't make any difference. It's interesting that others are having such similar problems - how did you resolve it in the end?
Was this helpful?
Yes
No
Popular Solutions for Canon EOS 40D Digital Camera
when i press to take a picture the shutter only does the first part of the release. I have to take...
(More)
when i press to take a picture the shutter only does the first part of the release. I have to take the battery out to get it to release. It does the same thing every time. I have taken the card out as well and nothing changes
i can't get a clear image. there is always a haze!! What can i do?( i have had other photogs try and...
(More)
i can't get a clear image. there is always a haze!! What can i do?( i have had other photogs try and shoot with it as well to make sure it wasn't just me)
the shutter seems to be not responding in time. it sometimes doesnt fire at all,if it does, it takes...
(More)
the shutter seems to be not responding in time. it sometimes doesnt fire at all,if it does, it takes several seconds
