Question about Samsung SGH-a737 Cellular Phone
The pound key won't work anymore and that is the space button for texting.
When texting what key do you use to back space on the Nokia 3310
with "C" button as a "backspace", "back" or "undo" button
Jun 03, 2017 | Nokia Cell Phones
How do you get to use the space bar in the button zero
I'm not entirely sure what you. If you're using the numeric keypad to type out a 'TEXT', then you'll want to use the '#' key in order to add spaces. The actual key pad has dedicated buttons for '0' and 'SPACE'.
Jun 05, 2014 | Samsung SCH-U450 Cell Phone
How to text without preselective text
if you look at your key pad the pound key should be the button you press to change that if you look on your screen and find the abc area that shows the selection of texting and press the pound key it should change. hope this helps
Dec 23, 2012 | Cell Phones
The pound symbol is shown as being on the number 3 key, however it is not available on any key. The @ symbol is supposed to be on the ' key but is actually hidden under the number 2 key. I need the pound...
Go To control panel - Regional and language options and click on Languages tab; there click on Details button in "text services and input languages" ; then change the default input language to English (United Kingdom).Then the keyboard layout will change to UK standard and you will find the Pound symbol.Change it back to English (US) once your purpose is over
Apr 01, 2010 | ASUS Eee 4G Notebook
I HAVE A NEW ACER 5517 AND CAN'T GET THE @ KEY TO WORK???
First, does the #2 key work? I assume thats the same key as your at button.
If it does, if you hold the shift key and press 3, do you get the pound sign?
if the 2 key does not work, then the problem is with your #2 button. if the # key does not work, then the problem is with your shift key.
Try the right shift key, blow air into those keys, if it still does not work, you will need to replace the keyboard.
it will be covered under warranty.
thanks adi
please rate this solution
Mar 25, 2010 | Acer Aspire 5100 Notebook
Can't get the pound sign over the number 3. I get
CANT GET £ SIGN, AND " HAS SWAPPED WITH @
1, HOLD THE SHIFT KEY DOWN
2, PRESS THE "WINDOWS LOGO" AND "ALT" BUTTONS TOGETHER ON THE LEFT HAND OF THE SPACE BAR ONLY. THE RIGHT HAND ONES WILL NOT WORK
3, YOU MAY HAVE TO USE THE MOUSE TO CLICK ON THE PAGE.
4, YOU WILL NOW HAVE THE "£" BACK & THE @ OR " IN THE CORRECT PLACE.
Jan 20, 2010 | Logitech Computers & Internet
Can not find key for spacing words when texting
Hi!
On the D500 the key for 'space' should be the key on the right hand side of the keypad, at the very bottom (see below).
f39273c.jpg In a text message, pressing that button will insert a space.
From the main menu of your phone, holding that button will enable 'silent mode'.
Hope this helps!!
Dec 04, 2009 | Samsung SGH-D500 Cellular Phone
How do you space between words on an older razor phone?
To put a space in between words in a text msg or text body, you hold down the *STAR button. The space key looks like this ( __ ) and it is on the *star key on the old Razer
Sep 02, 2009 | Motorola Mobility RAZR V3
Samsung SGH-a737 Cellular Phone Logo
51 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
