Question about Hotpoint Aquarius WF000 Front Load Washer
Same problem aquarius model no wf541 14oow spin only 2 years old. Switch it on and press start solenoid water opens and starts to fill the prewash draw then after a few seconds the on/off, rinsehold and mini load lights start flashing and pump starts water pumps whilst l/h solenoid is still flowing does this for a few minutes and then solenoid and pump stops but lights still flash, press start again and it does the same again.
    President:
  • 1,653 Answers
Power it off at the mains for 60 mins and then rety. If it still does the same then call in a repair man as it is most likely thatthe main controller board is faulty and needs replacing.
Posted on Sep 11, 2009
Model EWF10843. How do I select diagnostic mode?
Electrolux Diagnostic Mode
* Press the Cancel button to enter standby mode and enable diagnostic entry.
* Within 10 seconds after pressing Cancel , press any button to wake up the control.
* Within 5 seconds of wake up, turn the selector knob to the far left cycle and press and hold Cancel and far left
button under the display simultaneously for 3 seconds to enter the diagnostic mode.
To save time at wake up, the Welcome screen can be bypassed by turning the selector knob.
1. Upon entering diagnostic mode, all lights should flash for 1¼"x2" display models and all lights on for the 1¼" x
4 3/4" display models.
2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water
should enter through the detergent compartment.
3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water
should enter through the bleach compartment.
4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and
cold water should enter through the softener compartment.
5. Turn the program knob (4) clicks from the start position. The prewash solenoid will activate and cold water should
enter through the prewash compartment.
6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door
can be opened. When the door is opened, the drum light should turn on.
7. Turn the program knob (6) clicks from the start position. The door lock will activate and the washer will fill then
tumble. Once tumbling has started, the boost heater will turn on.
8. Turn the program knob (7) clicks from the start position. The drain pump will activate draining out any water in the
tub and the washer will operate in high spin.
9. Turn the program knob (8) clicks from the start position. This is a free position.
10. Turn the program knob (9) clicks from the start position. The control will signal the last 5 error codes with E00
being no error.
11. Turn the program knob (10) clicks from the start position. Latest software version will be shown.
12. If applicable, turn the program knob (11) clicks from the start position. This is a free position
Exiting Diagnostic ModeA) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord or
Turn the program knob clockwise back to the start position. Press the Cancel and far left button under the display
until the LED's stop flashing
Jun 08, 2015 | Electrolux Washing Machines
Washer makes very loud humming noise in spin cycle but does not spin..I removed clothes thinking it was very heavy and it did spin out but when I put clothes back it returned w/no spin and loud noise..now...
Either the control board or the motor has gone bad. Here is the diagnostic mode to run to look for the errors.
The diagnostic test is performed by using the Program Knob. To START THE TEST: • On non-digital display models, turn the Program Knob to start position, Drain/Spin. • On digital display models, turn the Program Knob to start position, Touch Up. • Press Pause/Cancel to turn off LEDs. • Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then release buttons. 1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality. 2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment. 3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment. 4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment. 5. Turn the program knob (4) clicks from the start position. The door lock solenoid will activate. 6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened. 7. Turn the program knob (6) clicks from the start position. The washer will fill and tumble. 8. Turn the program knob (7) clicks from the start position. The washer will fill and spin (leakage test). 9. Turn the program knob (8) clicks from the start position. The drain pump and door lock solenoid will activate and the washer will operate in high spin. SAFETY WARNING: If power is removed during this test, the door can be opened. To prevent injury, DO NOT put your hands inside when the tub is rotating. 10. Turn the program knob (9) clicks from the start position. The control will signal the last error code.
Repost the error codes here.
Feb 12, 2011 | Frigidaire Affinity ATF7000E Front Load...
I have a hotpoint aquarius WF32O and when i put
is it spinning and craccleking,,carbons faulty in motor ;;will work on spin but not lower voltage wash?
change carbons,, use genuines,only
Jun 21, 2010 | Washing Machines
I have a whirlpool duet washer that will not spin at high speed and shows error code f 06
Error F06 is Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes. Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Oct 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
AWM6100/s door open light comes on shortly after starting
Bought a new washing machine. The motor had one of the coils open circuit and the cost of a new motor was nearly that of a replacement WM.
Oct 05, 2009 | Whirlpool AWM6100 Front Load Washer
10 year old model kenmore top load washing maching won't fill.
That means that eithere the membrane water lever switch is faulty (most common) or that the drain pump solenoid is stuck on open.
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
Hi, I have a duet washer that won't turn on. The "Control On" button is blinking and when I press the "Hold to Start" button, nothing happens. And ideas?
Open and close the door.
The door has to be opened between wash cycles.
Check the door switch/lock unit
using the diagnostics listed below.
If door is locked, Drain the unit.
Check wire harness for connections.
Check the touchpad/LED assembly.
Starting the test mode:
Close the door
Press Control On button
Select the DRAIN/SPIN cycle
Select NO SPIN by pressing the SPIN SELECT button,as needed,
Push Prewash Option button 4 times within 5 secs.
C:00 will show in the display.
To advance to the next step
Push Prewash Option button 2 times.
Here are the codes:
C:00 check door lock system actuator
C:01 Check cold water inlet valve flowmeter
C:02 check dispenser motor
C:03 check hot water dispenser
C:04 check basket rotation MCU,Motor
C:05 check heater sensor
C:06 check Drain pump
C:07 check Motor or motor control unit
C:08 check Motor, MCU control
Dec 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine WMA54 Hotpoint sticks on prewash
I realised that the washer was not filling properly with water!  So I pulled it out from the wall and noticed the cold water fill pipe had been squashed and had a kink in it so not enough water was getting through.  I remedied this by pulling the pipes through the under sink cupboard and securing them with gaffer tape,  Hey presto the machine now works again!  Hooray :D
Oct 06, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
219 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
