Question about Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony bravia 46 shutting off a blinking 6 times
  • 93 Answers
Here's blink codes for sony bravia
1 blink abnormal AU Power Voltage
2 blink abnormal d5v/a9v power voltage
3 blink Abnormal panel voltage
4 blink backlight failure
5 blink abnormal main power voltage
6 blink abnormal speaker voltage
7 blink internal temp. rise
8 times ic5000
that helps?..
Posted on Sep 11, 2009
Testimonial: "Cheers for the help it maybe the was i have the surround sound hooked up thanks heaps "
  • blackcell447 Feb 10, 2012
    This helped us .. Had 6 red blinks and volume control thru tv aka stereo didnt work .. we would reset tv and poof turns off and red blink 6 times.. we inspected with back off tv and found two wires not plugged onts sockets well or clicked into place..now we have now light or problems..haha hope it helps others... DO NOT try this unless you are comfortable we electronics and high voltage...
Mi Tv Sony ldl-40w659d lo enciendo y autom?ticamente despu?s de unos 5 segundo pasa de color verde a color rojo. No me permite entrar a nada. Qu? puedo hacer? Debo resetearlo a configuraci?n de f?brica? Como lo har?a? Gracias
Posted on Aug 30, 2018
    New Friend:
My Sony Bravia was shutting off after about a minute, followed by six blinks. I tried unplugging everything and resetting to factory defaults, and that did nothing. Finally I tried turning off two external wireless speakers that were sitting near the TV, and that did it! Turns out 6 blinks means there's a speaker problem, and the wireless speakers must have been interfering with the internal speaker. Weird. Anyway, problem solved!
Posted on Apr 05, 2017
    New Friend:
Klv-46r452a 6times red lihgt blinking
Posted on Dec 25, 2015
    New Friend:
Hi there just wanting to know is that info you guyz gave is that for the sony kdl 46cx520 plz let me know
Posted on Jan 13, 2015
    New Friend:
I had the same problem. I have a Sony Bravia that was shutting off with six blinking lights (abnormal speaker voltage). I replaced the HDMI cable from the Comcast cable box with a five cable (three video, two audio) cable (sorry, I forgot what that cable is called). Anyway, the Sony Bravia has been on for couple of hours and has not turned off. I think the HDMI ports have a high voltage limit for input signals and it shuts down the TV if the input voltage is too high. Hope this helps.
Posted on Jan 04, 2013
  • Richard Talbot
    Richard Talbot Dec 11, 2013
    Any other problems to report after the cable change? I am having a similar issue. I have 6 blinks after the tv turns off. If I wait long enough it will come back on, but will turn off again after some time.
  • Bob Slater Dec 11, 2013
    Richard, does this happen when you have a HDMI cable installed? If so, update the firmware drivers for the TV set. Goto the Sony support/repair web page and look for 'drivers & software'. Find your model number and download the latest drivers to your computer. Then put the drivers onto a thumb/flash drive and put the flash drive in the service port on the back of the TV. Go thru your TV menu and find the update selection. The TV will know to look for the new drivers from the service port. Hope this helps.
2 Suggested Answers
SOURCE:
Kensolutions
  • 455 Answers
SOURCE: standby light blinks 6 times..no picture...i have
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Posted on Aug 20, 2011
Sony BRAVIA Fails to fully Power ON. TV shuts off when backlight should kick in, after logo lights and fades. 'standby' blinks 6 times.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Feb 29, 2016 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
What would be the cause? Sony Bravia standby light 3 blinks times any ideas?
try re-closing your lamp door. indicates possible lamp door/switch problem
Jul 19, 2014 | Sony Bravia Kdf-46e3000 46-inch 1080p 3lcd...
Sony bravia 42ex410 tv red light 6 times blking tha tv on 1 second off
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can vet an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/
Dec 30, 2013 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Sony Bravia 46" The standby light flashes four
If tv model number is KDL-46S2000 then 4 times blinking standby light indicates back light failure problem in your tv.
Check/ replace back light inverter boards to solve its problem.
Thanks.
Dec 29, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
My Sony Bravia, model KDL-46XBR4's standby light is flashing 6 times. We have reset it 3 times but after several days it shuts down and continues to flash the standby...always 6 times. Can anyone tell...
I am experiencing exactly the same problem. TV turns on but within 60 seconds the screen goes black and the red standby light blinks six times. Were you able to resolve this problem on your TV?
Oct 17, 2010 | Sony KDL-46XBR4 46 in. LCD Television
Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
Mar 14, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
14,605 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
