Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
I have a 1 year old ryobi mult tool stimmer hedge cutter it has all ways been a problem to start i went to get it to start to day (i alwayes put new petrol/oil mix in it ) it started after about 30 pulls of the starter but it would not pick up revs unless i kept playing with the choke have you had a problem with these items or have i got one with a problem i am a retired motor mechanic so i am not stupid etc i sounds like it is drawing in air somewere?? i hope you can help please
  • 1,498 Answers
Hi Red,
I've got several Ryobi's. No start problems, mine are in the interchangable shafts.
I'm glad you have experience, it'll be a lot easier for both of us. The following questions/thoughts are in no particular order.
The drawing air you mentioned sounds like a factor. Can you tell where its coming from?
  • Is the primer bulb intact?
  • Flexible, no cracks
  • Does it function? When pressed and released (after 5 or so presses), does it fill with fuel or is there air in there?
  • Does in reinflate right away?
Pull the plug and eyeball it. You know what to look for. If anything looks suspect, replace it.
Try the starting ether test. Take off the air filter, give it a spritz of starting ether or carb cleaner. Then try to start it. If it starts right up, theres a fuel flow problem.
Are the carb assembly bolts tight? if you can see the gasket, inspect it for breaks. You may need to remove the carb to check the gasket.
Tip: I don't even mention this to most folks, but with your background, this trick could help locate the problem.
On some machines brought to me for repair for starting problems, I take off the pull start assembly. I use a screw gun with a socket bit on the shaft nut to spin/start the motor (Gives your arm a break). This would make it easier to find where the air is being drawn in, running or not.
You can prime it, adjust the mix, hand over the choke, all while the motor is spinning.
Comment back on your findings.
Best regards,
Mike
Posted on Sep 11, 2009
  • 2,418 Answers
2 stroke engines are a bit goofy. Ckeck your air filter, ck the spark plug and clean it. Look for 2 small sceews loacated close to the carb. One is for idle air mix, one is for full throttle mix. If you use the same mix of gas and additive each time you will have to adjust these screews once in  awhile. If you use a different mix/additive you will have to adjust them every time. Get a can of starting fluid to get it started easy, then adjust it a little at a time to keep it running, once it is hot make your finial adjustments.
Can you help
Sounds like the cable in the upper shaft is broken. Start it without the attachments installed and see if the cable is turning.
Sep 01, 2014 | Garden
Needs carby ajusting for ryobi lawn hornet 70 about 15 years old but has been great
Hi duthie20, the low speed(closest to engine block) should be 1 and a quarter the high speed 1 and a half(the other one). That should get ya going, you may have to tweek these adjustments a little eigther way. Happy New Year!
Dec 28, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
The pull cord for starting the cutter has detatched
normaly there is 4 bolts holding the cover on take them out and the pull clutch in under there,,, put the string back in the cover and tighten the clutch up first so it pulls the strin in when you let it go,,,tiy a good knot in the pull start string or you will just pull it out again!
Jul 01, 2010 | Ryobi Garden
Cant start ryobi 890r brushcutter
My Ryobi 890r brush cutter will start and then die
May 16, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Hello I have a Ryobi HT26 hedge trimmer that is one year old. It starts fine but dies after I try to release the choke and pull the throttle. I cleaned the air intake that was semi plugged, replaced the...
Sorry but I have the same problem, did everything you did plus bought a new carb. I think these are just a bunch a ****. I have Ryobi electric tools which are okay but I am NEVER going to buy a buy Ryobi gas product again>
Nov 22, 2009 | Garden
One year old Ryobi s430 4 stroke trimmer will not start.
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwill need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to seedaylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Oct 19, 2009 | Ryobi Garden
Ryobi 18V Hedge Trimmer Blade Question
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Aug 27, 2008 | Ryobi 18V Hedge Trimmer
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
259 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
