Question about Nokia 3110 Cellular Phone
Not detect ot detect my nokia3110c by nokia browser in my nokia mode.
My NOKIA3110c is not starting after pressing POWER BUTTON ON. How can I do Flashing of my NOKIA3110c.
First of all download latest version of nokia pc suite from here. Then download latest firmware files for your phone using navifirm then follow this link to flash using phoenix. You need to disable your antivirus and your phone must have sufficient charge while flashing.
Oct 03, 2012 | Nokia 3110 Cellular Phone
How can i repair start up problem of nokia3110c using pc&usb data cable my self
If your phone is detected to Pc when you connect via usb.Follow the instruction below
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 3110c file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
Sep 02, 2011 | Nokia 3110 Cellular Phone
I want BSNL Internet in my NOKIA3110c mobile
Please call up the call center of the service provider BSNL and ask for the links to be added to your phone browser settings.
Jun 15, 2011 | Nokia 3110 Cellular Phone
I Can't use my memory card in another mobile & also in PC. I have Nokia3110c Device.
Maybe the memorry card has some errors. have aqscan done on the card, quarantine the error files and then checck . If not remove off all files , then format the card and try if this detects .
Sep 06, 2010 | Nokia 3110 Cellular Phone
When i applying themes in my nokia3110c .it shows that " una
you have to switch off it for 2 min and restart it ur problem will b solved
Aug 13, 2009 | Nokia 3110 Cellular Phone
Regulerly restart
Hi...
There are still wet parts inside... have it checked to a repair phone shop and have it dry and check for other unseen problems.
goodluck... please rate..
Jul 01, 2009 | Nokia 3110 Cellular Phone
Cannot install .Jar iles or .sis files to nokia 3110c
I have bought nokia3110c. Iwant to install .sis files on my cell.
how can i do it
please send solution for it.
thank you
Oct 19, 2008 | Nokia 3110 Cellular Phone
Nokia 3110 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
