Question about Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishwasher problem i have been having problems with my dishwasher,it does not clean properly,i got fed up so i brought another dishwasher,i wash brilliant for about a week now it is also not cleaning,i have cleaned filters,put salt into it,what am i missing,2 dishwashers,same problem. Thanks dee
  • dee wise Dec 11, 2007
    thanks,the dishwasher has new pipes,i just have had a new kitchen installed,and the water pressure is good,anything else i could try.
    Dee
  • 640 Answers
If you have 2 units with the same problem i would check the water line/hose,they have screens in them and they could be obstructed.I would also see if the water pressure isnt too low.Also the line from the dishwasher to the drain i would check for obstructions.Let me know if you have any other questions.
Posted on Dec 11, 2007
I am having issues with my dishwasher where it appears to be working but does not clean. Hot water does enter the unit and drains properly but is not cleaning. Muck is still on the door, the arms are wet....
No you need not wash the dishes but just cleaning of the debris and then putting it in the dishwasher for proper cleaning will help you to prevent the drain from getting blocked.
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Mar 04, 2011 | Dishwashers
I have a Whirlpool gold dishwasher. It may be 6-7 years old. It is cleaning properly. Any suggestions?
I think you want to mean it is not cleaning properly..
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes
Feb 02, 2011 | Whirlpool Dishwashers
There is a symbol of a tap when i switch the dishwasher on..and it wont wash anything? It sounds like its draining? Ive tried resetting it and switching on and off but nothing. Does it need filling up with...
need to check your water supply from the house to the dishwasher, it won't operate properly if the water level in the washer is low. Check the water valve at the sink ands the water valve at the dishwasher.
Good Luck on your repairs
Dave
Dec 03, 2009 | Dishwashers
Glasses and dishes smell like a fishtank when done
9-10 times this is usually related to poor drain line installation.be sure that there is an incline at least the height of the bottom of the sink. the drain line is usually attached to garbage disposal.raise that line to prevent water from draining into d/w from sink....run jet dry dishwasher cleaner to clean unit and kill foul odor
Nov 08, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishes smell like fish
   Hi, I've been scanning this for awhile as I have this problem on and off. I have watched what I have been cooking and have come to the conclusion it's to do with eggs.  I always noticed it when we had eggs ( they are fed with ground up fish) so changed to vegetarian  fed  chicken eggs and problem got better, I only notice it now if I use a salad cream or mayonnaise type products with egg added in the ingredients and I hand wash these away from all other items.  I have noticed many comments on hygiene, but if you have this problem you become a cleaning nut trying to get rid of it. I always clean with vinegar and bleach and it did not work with this one. Hope this helps
Sep 03, 2009 | Whirlpool 24 in. Portable Dishwasher...
My whirlpool ADG 7540/1 doesn't heat up properly when washing, sometimes "lukewarm", sometimes a bit warmer still but not the 65 c of the programmed wash. Any ideas?
I have a Whirpool ADG7540/1 integrated dishwasher that goes straight to rinse programme, it is 6 years old, has it come to the end of its day or is there someone out there that can help? Sheelagh Fed up (Pontypridd)
Apr 21, 2008 | Whirlpool Dishwashers
Kenmore Ultra Wash Model 665 Dishwasher
Dishwashers which are properly installed and regularly used won't normally have a problem with bad odors. Check the following: ?Was the drain hose brought in at the top of the cabinet, or down near the floor? it must be 34" from the floor. ?Do you run the unit at least once every 2 days? -Run a cycle with a quart of vinegar to clean the tub and pump. ?Does the disposal tend to back up slightly when the dishwasher drains? Drain may be clogged. -Don't use gel detergent! ?Check your water softener(If so equipped) These can cause foul odors in the water supply if not properly balanced or maintained Good luck!
Sep 02, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
My Bosch Dishwasher doesn't clean
open the door while in the wash cycle and check water is spraying from the spray arms and that the spray arms are rotating. get back to me with the results and i'll try to give some guidance
May 04, 2007 | Bosch 24 in. SGI43E05GB Built-in...
Bosch 24 in. SHU5305UC Built-in Dishwasher Logo
98 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
