A buddy of mine needed a monitor fixed for him so I offered to help. When i plug in the monitor it will turn on will all of the tubes lighting up, after about 6sec the monitor will start powering off and on. Unlike most problems the green power light also turns on and off, At this point I was guessing it was the caps but I wanted to make sure before I started spending money on parts.
This is a generic symptom that could happen to any LCD
monitor.
The following is a generic answer applicable to most.
The most possible causes are bad capacitors or a bad
semi-conductor.
Open the unit and check to see if any of the capacitors in the power supply or
other boards look domed or vented on the top.
Replace any capacitors accordingly. Use the same value capacitors. Most often,
1000uF 16V or 25V, 470uF at 16 or 25V, 220uF at 16V or 25V.
If this doesn’t solve the problem, try checking the surface-mount transistors
on the inverter board that run the lights. Some times these transistors go bad
and can cause the power to cycle up and down. Check the area for any cracked or
overheated ceramic or mylar capacitors.
Don’t forget to check for caps on the main board. Some times these boards are
overly simple and only have a couple of caps, but other times they are teaming
with them.
