Question about Dryers
I have siemens tumble drier when I put it on 86 minutes drying programme stops after a few minutes and timer comes on at 8 minutes won't dry clothes ENR WT79020EV OIFD790901631
  • 986 Answers
This is probably the motor going bad. The sensors wont cause this to happen. The start switch either, replacing all the sensors in the world wont make the motor be good again. But their is something you can do to try and make the motor last a while longer,their isn't any holes to oil the dryer motor so you must make some,using a 1/8th inch drill bit make a hole in either end of the motor where the bearings are (taking care not to hit the shaft), then add some hi temp oil such as zoom-oil, (dont use WD-40) and work the motor free as you can by hand. If this frees up the motor it may go a while longer. Also oil the rollers and check the slides to make sure they are not pinching and stalling the motor. If the motor can't reach top speed it will get hot,overload and stop.
Posted on Sep 12, 2009
Why is my Tumble Drier keeps beeping without stopping a few minutes into the drying program?
It sounds like the carbon brushes are probably worn down - they ride on the drum (in the top ) and determine the amount of moisture left in the clothes for drying - they connect to the drum and the metal bar inside the dryer - A wet clothing item conducts between the two giving the dryer an idea of how much moisture is left in the load - equal to how much time / heat is needed to dry load as required. These brushes wear out and need to be replaced over time
Aug 03, 2014 | Miele Washing Machines
I want to know that on my washing machine lg-80BKF21P model the time(min) 10 minutes was remaining and the washing process is done,it ends but after drying all is done but 10 minutes were remaining and...
tumble driers and combination washer driers have a 10 minute safety margin, where the heat fior drying is dispersed, to avoid people grabbing very hot clothing.. especially if it is not quite dry as this would make them, hotter to the touch.
Tumble driers usually continue to tumble, but blow cool air through the clothes to get rid of the heat, before stopping.
Oct 02, 2017 | LG Washing Machines
Thor washer/dryer combo not drying properly. What is capacity of machine?
Whilst 'combos' will 'wash' a full load of clothes, they are not so good at 'drying' a full load. Since there must be a 'tumbling space' inside of the drum, into which the clothes can fall during the drying cycle.
In a 'nutshell' one 'wash load' equals 'two drying loads',
That's the price you pay for having a space saving 'combo' machine instead of having a 'washing AND a drying machine.
Add to that the fact that most 'combos' are 'condenser driers', as opposed to 'free flow outlet driers',
The consequence is that it takes far longer to 'wash and dry' a load of clothes in a 'combi' as oppose to two separate machines
Aug 21, 2013 | Washing Machines
Timer stops at 6 minutes but continues to tumble.
You will need to replace the auto dry sensor on your dryer.
Mar 11, 2012 | LG DLE2516 Electric Dryer
How do you remove the water pump on an indesit idc75 condenser drier?
This easy to use white Indemnity condenser dryer will make a welcome addition to any kitchen. The 10 minute cool tumble and reverse tumble option will help keep creases in your fabric to a minimum. Energy efficiency ratings & performance: Energy efficiency rating: C. Maximum drying capacity 7kg. Condenser dryer features: 160 minute timer. Including 10 minute cool tumble. 2 dryness levels. Manual control. Reverse tumble option. Reservoir full indicator. Fluff filter. Size H85, W59.5, D58.5cm. Drying programmes Freshen up cycle. Manufacturer's 5 year parts and 1 year labour guarantee. Technical specifications: Energy consumption: 4.48kWh per cycle based on dry cotton cycle. Energy consumption: 336kWh per year based on dry cotton cycle.
please comment on my post or vote for the solution.
Dec 21, 2010 | Indesit Dryers
Thermal fuse blows Before this happened heat element went and dryeer would blow cold and not shut off until timer was manually turned off. Replaced all parts except timer. dryer worked for ten minutes and...
If you are referring to the thermal fuse on the tumble drier, my thoughts are that the airflow is being restricted.Cool air is meant to flow in the back air vent which cools the components. This causes air convection and allows the clothes to dry evenly. No airflow makes everything overheat and the first item to normally break is the overtemp. thermal fuse.Go from there.
Sep 23, 2009 | Dryers
Dryer tumbles, trake long time to dry or partly
Check the hose at the rear of the drier, if the hose is restricted even to the vent outside she will not move the air to dry your clothes. Also check the filter and down inside the filter area. Clean it out.
Sep 18, 2009 | Dryers
Amana model LGA30AW automatic setting doesn't shut the dryer off
You can make adjustments to your Automatic Cycles by adjusting the Factory Dryness Level:
Changing the Automatic Cycle settings to increase or decrease drying time:
If all your loads on all Automatic Cycles are consistently less dry or more dry than you would like, you may change the default settings to increase or decrease the default dryness
level.
Your automatic drying settings can be adjusted to adapt to different installations, environmental conditions, or personal preference. This change is retained and will affect all of your
Automatic Cycles, not just the current cycle/load. There are 5 drying settings, which are displayed using the time display:
0 Much wetter clothes, 30% less drying time.
1 Slightly wetter clothes, 15% less drying time.
2 Factory preset dryness level.
3 Slightly drier clothes, 15% more drying time.
4 Much drier clothes, 30% more drying time.
TO CHANGE THE DRYING SETTINGS: NOTE: The settings cannot be changed while the dryer is running or paused. The dryer must be in standby mode (power is off) to adjust the default settings.
  1. Before starting a cycle, touch and hold DRYNESS for 6 seconds.
  2. Touch DRYNESS to select the dryness level shown in the time display: 0, 1, 2, 3, or 4.
  3. Touch START/PAUSE to save the new dryness level setting.
Oct 05, 2017 | Amana ALG331RAW Gas Dryer
White knight 767 tumble drier
If the rug was very heavy you could have burnt up the motor. If it will restart after it cools off, replace the motor and clean out the vent system.
Good luck.
Dec 08, 2007 | Dryers
Dryers Logo
78 people viewed this question
Top Dryers Experts
