Question about Brother P-Touch 2420PC Label Printer
Unable to print labels for P TOUCH error code PTUSB (PT-2420PC-L4J432063)
4 Suggested Answers
loumsc
  • 114 Answers
SOURCE: Ptouch weak printing
You need to take a q-tip dipped in alcohol and clean the printhead. Let me know if this helps.
Lou
Posted on Sep 10, 2008
SOURCE: Brother P-touch 2420PC won't print
Aha! I got it :D.
Go to: http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faqp/000000/001400/000038/faqp001438_000.html?reg=eu〈=en&c=eu_ot∏=2420euk&page=FaqEndPage and download the driver removal tool, then reinstall. I had removed it manually and reinstalled but it obviously didn't delete the registry entries. It's working fine now. Good luck! Hope this helps you too.
Posted on Apr 25, 2009
  • 97 Answers
SOURCE: P touch 2420pc I cant
Usually if you change the setting in the printer and save it, then it changes back to some other setting after printing, the setting is being overridden by the same setting in the printer driver. Make your change in the driver.
Hope that helps...
Posted on May 06, 2011
P-Touch 7100 cutter error
Just a (too late) suggestion: The cutter on the PT-7100 (and I think on every Brother Label printer that uses TZ tapes) has a replaceable blade. Sometimes just removing the blade and making sure the tape path is clear of gunk is all it needs.
Apr 07, 2015 | Office Equipment & Supplies
"no tape" error
I found 2 helpful manuals from brother that you may want to checkout. they explain exactly how to install the cartridge:
http://www.ptouchdirect.com/ptouch/manual/PT1000.pdf
http://www.ptouchdirect.com/ptouch/manual/PT85.pdf
Feb 18, 2013 | Brother P-Touch PT-2400 Label Tape OEM...
Not enough disk space to spool document error message when using Brother Ptouch QL-500. All other printers are working well.
I am assuming that your hard disk is not actually full. I am guessing that you are running Windows 7. Click through your start menu until you can see the entry to launch your P-touch Editor. Right click on the entry and click "Properties". Click the "Compatibility" tab. Under "Privilege Level" check the box labeled "Run this program as an administrator". (You can do the same for all users of this computer by clicking the button immediately below, labeled "Change settings for all users".) Click OK, and you're done. The next time you launch the editor, you will get a message asking: "Do you want to allow the following program from an unknown publisher to make changes to this computer?" Click yes, and you should be able to edit and print your labels. Of course, all this assumes that you have sufficient privileges to actually edit permissions and run something as an administrator. Hope this helps.
Jun 06, 2011 | Brother P-Touch 2420PC Label Printer
P touch 2420pc I cant change lenght of tape. keeps defaulting to 100mm
Hope that helps...
May 05, 2011 | Brother P-Touch 2420PC Label Printer
I have a P-touch 2420 PC that has been working fine. today the printing of labels is all mixed up. even the individual letters are corrupted
If restarting your computer does not solve the problem your driver probably got corrupted. In this case you should delete the printer (Start - Printers And Faxes,Right Click the printer, Choose Delete). Now you re-install the printer. Be sure to use the correct driver.
Feb 08, 2011 | Brother P-Touch 2420PC Label Printer
I have a P-touch QL-500 brother label printer. When I try to print my label I get error message Not egough disk space to spool document
This solution from loquiter worked for me on my Vista PC
noavatar_s.gif loquiter
I am assuming that your hard disk is not actually full. I am guessing that you are running Windows 7. Click through your start menu until you can see the entry to launch your P-touch Editor. Right click on the entry and click "Properties". Click the "Compatibility" tab. Under "Privilege Level" check the box labeled "Run this program as an administrator". (You can do the same for all users of this computer by clicking the button immediately below, labeled "Change settings for all users".) Click OK, and you're done. The next time you launch the editor, you will get a message asking: "Do you want to allow the following program from an unknown publisher to make changes to this computer?" Click yes, and you should be able to edit and print your labels. Of course, all this assumes that you have sufficient privileges to actually edit permissions and run something as an administrator. Hope this helps. .g_thread_answer { overflow:visible !important; } Was this solution helpful?
Jan 24, 2011 | Brother P-Touch 2420PC Label Printer
Too much tape
Hi, it seem your label maker is set to the last(amount) of labels printed. Go to: Print Labels, click; Number of Labels; clear to set to (1) Label. That should stop the run off of labels. Thanks paul70f9
Jan 04, 2010 | Brother P-Touch 1180 Label Printer
With a pt 65, how do I reduce the size of the print?
Cook,
With the unit powered up, press and hold the yellow Code button. While holding it down, press the & key and watch the pointer at the top of the screen. Note how it is moving to the various size As. That will increase and decrease your font size.
Mar 05, 2009 | Brother PT-65 Personal P-Touch Electronic...
Aha! I got it :D.
Feb 08, 2009 | Brother P-Touch 2420PC Label Printer
Brother PT-85
Make sure you have fresh batteries, It sounds like the batteries are low,
Lou
Aug 10, 2008 | Brother P-Touch 1180 Label Printer
Brother P-Touch 2420PC Label Printer Logo
50 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
