Question about Lexmark C510 Laser Printer
Photodeveloper Hi I have just changed the photodeveloper but the printer is not recognising that it has been changed. It still says that there is only 7% remaining. How do I tell it that I have replanced the photodeveloper?Thanks Lorraine
  • 4 Answers
SOURCE: lexmark c510 error message ;83 photodeve cart missing
See User Reference
http://www.lexmark.com/publications/pdfs/c510/eng/userref.pdf
Understanding printer messages
pages 184 and 185
"Message:
83 Photodev Cart Exhausted
What this message means:
The photodeveloper cartridge is completely used.
What you can do:
Replace the photodeveloper cartridge.
See also: Replacing the photodeveloper cartridge [page 73]
Continuing below
Message:
83 Photodev Cart Life Warning
The photodeveloper cartridge is nearing the end of its life.
What you can do:
• Press Go to clear the message and continue printing.
• Replace the photodeveloper cartridge.
Continuing below
Message:
83 Photodev Cart Missing
The photodeveloper cartridge is either missing or incorrectly
installed.
What you can do:
Correctly install the photodeveloper cartridge to clear the message and continue printing.
See also: Replacing the photodeveloper cartridge [page 73] "
Posted on Dec 09, 2008
SOURCE: 910 service engine + 900 service RIP software
931 service
Posted on Jul 09, 2009
SOURCE: Code E9 Service Call and Disgusting Sound
the photodeveloper cartridge needs to be changed.
i have two of the same printers. after swapping the photodeveloper cartridge, it worked again..
Posted on Dec 01, 2009
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: error msg appear set belt
    The error can either be caused by the OPC/OPC Marker assembly or the Main Motor assembly. Please follow the recommended troubleshooting steps:
    1. Power the printer off, remove and reseat the OPC unit, and power the machine back on. Print a test page. If error continues, proceed to step 2.
    2. Power the printer off and remove the OPC unit. Check the OPC Marker Sensor. If it is unsnapped or unplugged, reseat or replug it, and power the printer back on. Print a test page. If error continues, proceed to step 3.
    3. Remove the OPC unit and check it for scratches or defects. Also check the the markers on the OPC to make sure they are not damaged. Is the belt scratched or damaged? If the OPC is at or near the end of its life, OPC unit must be replaced. If the belt is in good condition, contact Lexmark technical support (if printer is under warranty) or your local authorized service provider for assistance.
    Posted on Sep 30, 2010
    elix0411
    • 3530 Answers
    SOURCE: what does a lexmark photodeveloper
    Welcome to Fixya
    Photodevelper kit is like a cpecial toner Cartridge OEM/Original Laser Cartridges. 100% brand new and manufactured by LEXMARK. This cartridges can generate clear prints, crisp images, and dark text with every print compared to standard cartridges.
    Thank you for using Fixya!
    Posted on Mar 29, 2011
    Hi, I have a Lexmark C510 Laser Printerphotodev exhausted message, changed it and still have the massage! Maybe it needs to be reset? I shut it off and restarted, but still have the message.. HELP!...
    The 83 Photodev Cart Exhausted message on the operator panel indicates that you must replace the photodeveloper cartridge immediately. To replace your photodeveloper cartridge please clink on the link below.
    http://bitly.com/nG3Toi
    Jun 17, 2011 | Lexmark C510 Laser Printer
    Hello there! When I print, all documents have a grey streak across it. its very slight but it also looks bad to customers so Im wondering if someone can help me Thank you in advance
    Either the toner cartridges, the fuser, or the photodeveloper cartridge are defective, or toner has accumulated in front of the printhead or on the printhead lens.
    Replace the color toner cartridge causing the
    line. If you still have the problem, replace the fuser and the photodeveloper cartridge. Clean any spilled toner you see in the printer housing near the printhead using a soft, clean
    lint-free cloth. Clean the printhead lens.
    Clean the printhead lens when you see print quality problems :
    1 Turn the printer off.
    2 Pull the front door release latch forward and gently lower the front door.
    3 Remove all of the toner cartridges one at a time.
    4 Open the top door.
    5 Remove the photodeveloper cartridge.
    6 Pull on the tabs to lift the lens cover.
    7 Gently wipe the printhead lens in one direction using a clean, dry lint-free cloth.
    8 Push the lens cover down.
    9 Align the photodeveloper cartridge with its opening. Gently lower it into place.
    10 Push the latches away from each other to lock the photodeveloper cartridge into place.
    11 Close the top door.
    12 Install all of the toner cartridges.
    13 Close the front door.
    14 Turn the printer on.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    Jan 26, 2011 | Lexmark C510 Laser Printer
    Reset replace OPC belt
    Here's the link on how to replace the Photodeveloper Cartridge on the Lexmark X500/X502: http://bit.ly/bzQQtH.
    Here's the link on how to reset the photodeveloper (OPC) count on the X500/X502: http://bit.ly/9BxHqz.
    Hope this helps.
    May 25, 2010 | Lexmark X502N All-In-One Laser Printer
    My Lexmark c510 only prints a black page.
    The black solid page could be due to a loose charge roller on the Photodeveloper. Here is an article that has pretty good instructions on how to verify and properly set the charge roller.
    http://bit.ly/cAC0Hw
    Mar 11, 2010 | Lexmark C510 Laser Printer
    What does Replace Belt CG mean?
    When the Replace Belt CG message appears, the photodeveloper cartridge has been exhausted and will need to be
    replaced. Order Lexmark part number C500X26G.After a new photodeveloper cartridge is installed, reset the
    photodeveloper count.
    1 Make sure the printer is on and the Ready message appears.
    2 Press .
    4 Press and hold for 3 seconds until you see Utility Menu, and then press .
    5 Press until you see Clear Belt CG, and then press .
    6 Press until you see Execute, and then press .The photodeveloper belt count is now reset.
    7 Press to return to Ready.
    Jan 12, 2010 | Lexmark C500n Laser Printer
    C510 printer displays "994 Service Engine Error". How do you address this?
    From a previous post: Posted by waynechurch on Apr 24, 2009 Is this error on a C510?, because the manual lists 994 as OPC belt marker sensor error.
    Normally with an engine service error i reflash the engine firmware first, if that doesn't cure the fault i would then replace the engine board. If you need the firmware, visit the Lexmark site get the contact phone number for your region and ring them. They're normally quite helpful and of coarse can tell you how to reflash it.
    Sep 25, 2009 | Lexmark C510 Laser Printer
    Here you go, courtsey of Lexmark's Knowlwdgebase.
    Don
    994 Service Engine Error on a Lexmark C510 ID: ENUS21233 If your printer is unable to move the photodeveloper belt to the correct position during printing, a 994 error will occur. However, it may simply be the case that the photodeveloper is either contaminated with excess toner or improperly installed. To test for and resolve this issue, please do the following:
    1. Power the printer off and remove the photodeveloper cartridge.
    2. Rotate the green metallic photodeveloper belt by manually turning the white drive gear on the bottom of the cartridge until the black positioning markers are visible.
    3. If necessary, carefully wipe any excess toner powder from the positioning markers using a soft, lint-free cloth or tissue.
    4. While the top cover of the printer is still open, inspect the sensor that is used to locate the positioning markers on the belt. CAUTION! The photodeveloper is very sensitive to light. Cover the green metallic surface of the photodeveloper with a piece of paper while it is outside the printer.
      • Refer to this image, this image, and this image to identify the location of the sensor.
      • Verify that the sensor has not come loose from its housing and that it is not contaminated with excess toner powder. If necessary, clean the sensor with a soft, lint-free cloth or tissue.
    5. Re-install the photodeveloper cartridge and power the printer back on.
    6. If the error remains, it is likely that a service call will be necessary to resolve this issue. Please contact Lexmark Technical Support, having first obtained the serial number of your printer. NOTE: If practicable, attempt to order another photodeveloper and replace it first to avoid the inconvenience of a potentially unnecessary service call.
    Jun 22, 2009 | Lexmark C510n Laser Printer
    Jan 08, 2009 | Lexmark X500n Color Laser All-in-One...
    Error message 83 - photodev cart exhausted
    The photoev cart is the photo developer cartridge.
    See User Reference
    pages 184 and 185
    "Message:
    What you can do:
    Continuing below
    Message:
    What you can do:
    Continuing below
    Message:
    installed.
    What you can do:
    Dec 08, 2008 | Lexmark C510 Laser Printer
    Lexmark c510 error message ;83 photodeve cart missing
    See User Reference
    pages 184 and 185
    "Message:
    What you can do:
    Continuing below
    Message:
    What you can do:
    Continuing below
    Message:
    installed.
    What you can do:
    Nov 26, 2008 | Lexmark C510 Laser Printer
    Lexmark C510 Laser Printer Logo
    88 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
