Question about Vehicle Parts & Accessories
Ford puma 3 button key fob needs reseting. how do i do it.
  • Vehicle Part... Master
  • 4,869 Answers
Check this site to see if your key is one of the ones illustrated
It also includes free instructions
http://www.mirez.co.uk/Keys.htm
Posted on Sep 11, 2009
2005 ford explorer sport trac. Door lock buttons do not work. Fob does not work. must lock with key. Doors are very hard to open.
You can reset your fob. Here's a link on how to reset fob,if you have 2,then do at the same time,when 1st fob is done ,push any button on second one asap. http://www.keyfobprogram.com/2005-ford-explorer-remote-programming
Aug 30, 2017 | Ford Cars & Trucks
Mustang alarm
Ford sold a Ford branded alarm through the parts department. These sometimes were a dealer installed option on new cars. Mine would randomly stop responding to the remote and I would have the same symptoms as you describe. I had it removed and the original equipment factory system still worked. Be warned, if you have the Ford "accessory" alarm, your key fobs (remotes) are different and the method to program them is different from what you will read online. You can tell if you have the system by looking at your key fob. The standard Mustang key fob is a 4 button (lock, unlock, panic, and trunk). The accessory alarm uses a 3 button remote and clicking unlock twice would pop the trunk. I really wish I had a picture of the remote because there are 3 button Ford key fobs for cars without a trunk release although I don't think you should have one on a Mustang. Long story short, if you have the accessory alarm, you can solve your problem by having it removed but you will need new 4 button key fobs to remotely lock/unlock your doors
Apr 04, 2014 | 2003 Ford Mustang
How do I disarm anti theft device on a 2001 ford taurus
SEE THE STEPS WITH CAREFULLY AND COMMON SENSE:God bless you
Press the unlock button on your vehicle's key fob to deactivate the alarm. If you've misplaced your remote for the car, use the PATS programmed key to unlock the driver's side door. Then, put the key in the ignition and turn the key to the "on" position. The vehicle's battery should be on, but the engine shouldn't be running.
  • 2 Locate the override button on the alarm box, beneath the driver's side of the dashboard. Press the button and hold it in until the alarm beeps one time. The LED light for the alarm should stop blinking, indicating the anti-theft system is disabled.
  • 3 To reset the vehicle's alarm, put the PATS programmed key in the ignition and turn the key to the "on" position. Press the override button. When the alarm resets, it chirps two times and the LED light begins blinking.
    Jul 25, 2012 | 2001 Ford Taurus
    Doors do not centrally lock with fob or key (they close but open straight away). Onlu option is lock drivers side with key and then lock the other 3 doors manuually. Ford Fiesta Mark 6 in the UK
    hi
    you need to try a couple of diffrent things with this problem
    1- get in drivers seat close doors and lock by hand
    2- then put key in ignition and turn key till dash lights come on (do not start)
    3- while key in ignition unlock doors with fob ,
    4 - then lock again with fob while key in ignition.
    5- then remove key exit car try locking doors from out side this should reset all your door locks
    Oct 25, 2010 | Ford Fiesta Cars & Trucks
    My battery died on my key remote for my 2002 Ford Expedition. I have replaced the battery, but apparently need to reprogram it. How do I do this?
    It should work even after taken the battery out., but here is the process.
    1. place key in ing.
    2.turn from position 2(lock) to pos 3(off), cycle pos 3 to pos 4, 8 times within 10 secs. your 8th turn ending in pos 4. Doors should lock/unlock confirming the program mode is ready.
    3. within 20 secs, program your fob by pressing any button on the fob. the doors will lock/unlock confirm it is programmed. If more than 20 sec pass before pressing the fob button, the step will have to be redone.
    Feb 05, 2010 | 2002 Ford Expedition
    Need to reset the key fob after replacing the battery
    You should not have to reset the key fob after a battery replacement. The signal from the key fob stays the same and is programed to the reciever.
    If the key fob needs to be reprogrammed then follow these steps.
    1. Have all key fobs with you during programming.
    2. Sit in the vehicle with all doors closed.
    3. Lock all doors using the Lock/Unlock switch on the door.
    4. Insert and withdraw the ignition key 7 to 9 times within 10 seconds (do not turn the key, just insert and withdraw).
    5. The 4 way flasher indicator on the dash should flash once or twice.
    6. Insert the ignition key and turn it on (key on, engine off).
    7. Press any button on one remote and the 4 way flasher indicator on the dash should flash once.
    8. If you have more key fobs to program use the Lock/Unlock button on the door to unlock the doors and then lock the doors.
    9. Press any button on the next key fob and the 4 way flasher indicator on the dash should flash once.
    10. Repeat if you have more key fobs. Only 5 can be programmed.
    11. To exit, simply turn of the igniton and remove the ignition key.
    12. Unlock the doors using the Lock/Unlock switch on the door and exit the vehicle.
    13. Make sure the window is down when testing remotes in case you leave the keys inside.
    14. Close all doors and test all remotes that were programmed.
    Do not skip any steps or the process will not work.
    If the 4 way flasher indicator does not work when inserting the key, you will need to start the process from the begining. If it still does not work the receiver may be your problem.
    If the 4 way flasher indicator does not flash when pressing any button on the key fob then the key fob is the problem (dead battery or defective remote)
    Dec 18, 2009 | 2002 Nissan Xterra
    How do i put the code in my ford puma
    Ford Code Entry Instructions
    Once the unit has been turned on the display will show ' CODE - - - -'
    Press preset [ 1 ] repeatedly for the first digit
    Press preset [ 2 ] repeatedly for the second digit
    Press preset [ 3 ] repeatedly for the third digit
    Press preset [ 4 ] repeatedly for the third digit
    To save the code press the [ 5 ] key to accept.
    The set should now operate.
    Dec 10, 2009 | Car Audio & Video
    Central locking not working on a 2001 Ford Puma
    ignition on and off three times, car beeps, press lock button car beeps, remote programmed
    Mar 25, 2009 | Ford F Cars & Trucks
    Vehicle Parts & Accessories Logo
    800 people viewed this question
    Top Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
