WASHING MACHINGE NEEDS A NEW DOOR SEAL
MY WASHING MACHINGE NEEDS A NEW DOOR SEAL. WILL I BE ABLE TO CHANGE IT MYSELF? SOME OF THE RUBBER HAS COME AWAY AND, NATURALLY IT LEAKS QUITE A BIT NOW. THE MACHINE IS QUITE GOOD OTHERWISE. I CAN SEE A BIT OF RUST ON THE EDGE OF THE SEAL AND WONDER WOULD IT ALL FALL APART WHEN I TRY TO GET THE OLD SEAL OFF:
THANKS
    President:
  • 704 Answers
Yes, this is a relatively easy repair for the DIY'er to do themselves. With your brand and model number, you can easily determine what the part number is the bellows gasket to replace your damaged one. Typically the gasket costs less than $130 and you'll save at least another $150 in service tech fees by doing it yourself.
Go to www.searspartsdirect.com and click on the Find A Part link and enter in your Model number and it'll bring up a couple of links for your washer. You'll want to click on the "front panel and door" or the "tub and motor" link to see the line drawing and parts list for your washer.
Look for the bellows gasket and that's the part you'll need to fix your washer.
Here's how to undertake the repair:
It's a relatively easy repair, all you need to do is remove the spring retaining wire around the outer edge of the bellows gasket, just peel it back at the edge to see it. Now locate the locking loop by going around the rim. Once you find the locking loop, you can remove it using a couple pairs of small needle nose pliers as they make it easier to get off.
Once you've done that, you'll see the locking plate that holds the back side of the bellows gasket onto the outer washer tub. Remove those fasteners and you can get the bellows off and start in on putting the new bellows onto the washer, just reversing the order you used in the removal process.
Just take your time removing the old gasket so you remember what you're doing and when installing the new gasket so as not to rip or tear it in the process. I'd also suggest you let the gasket relax for a good 4-5 hours (to get the kinks and folds out of it from the packing box) before you do the installation.
Here's another link to one of my other solutions for installing a bellows gasket on a GE front loading washer that you can also review for more installation tips, etc.
http://www.fixya.com/support/t2730376-need_help_in_installing_door_bellow_ge
Hope you find this Very Helpful and best regards!
Posted on Sep 17, 2009
Model wm0642hw front load. it leaks by door frame.rubber seal with clamp.only 2 years old. do i need to change the door frame outer part a151? thanks for your response in advance
Hi, If the door isnt loose or broken? Its more likely to be the rubber door seal if its leaking between the seal and the door glass. Check the edge of the seal where it touches against the glass for damage or ware if its ok clean any soap residue or bits from the glass.If it still leaks change the door seal.
Regards Elect App
Jul 13, 2011 | LG WM-2277HW Front Load Washer
Water leaks from front of machine
dealng with a leak of this nature, it could be anything from a tear in the door boot (rubber peice between door and tub), a pin hole in the water pump or hoses, or a bad tub seal. Ideally you need to take the top off of the machine and run it to determine where exactly the water is coming from. One other thing to check, if you are using a detergent that suds up too much, a front load washing machine will leak around the door seal... they are designed for non-sudsing detergent.
Oct 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Leak in rear lifthatch water leaking into rear storage area. It appears to be getting in under the rubber gasket door seal
Hi this is quite a common problem, you have a couple of options you can either go out and buy a new door rubber seal or if it one of those seals where you can get you hand in between two parts of the seal then what you can do is get some thick string and run this in the middle of the seal doing this will pack the seal out a bit and then when the door is shut this will make a lot better seal and it will then stop the water getting in.
let me know if you need further assistance ok
ps the rubber seal isnt to expensive to buy but even a new rubber may still have the same problem as its more to do with the way the door is fitted and it seems it dont push the seal hard enough to prevent water getting in so i have found packing it out with some thick string or twine will push the seal out more and will seal it properly when you shut the door to
plz rate this solution as i have a whole page of unrated posts, thanks
Aug 31, 2010 | 2007 Chevrolet Equinox LS New Cars
Rubber door seal problem
In my 13.5 years experience I have never experienced a door seal coming away from the drum!!!
If this was the case then you would have a major water leak!!!
Does the door seal look twisted at all?
Have a good look at the seal. Is there any black mold on the seal?
If the seal has come off then I would need to guide you through the refit process.
Please email me on: aardvark.repairs@btinternet.com and I will email you back my phone number
Regards
Aardvark Repairs
Nov 17, 2009 | Washing Machines
HE2 washer leaking water from bottom of door/seal during washing
Open the door so it is 90degrees from machine, see if it is upright. if not undo the door bolts slightly and re alighn door. Good luck and feel free to give feed back.
John
Sep 03, 2009 | Kenmore HE2 Plus Front Load Washer
BOSCH: How to replace rubber seal (boot) of front loading washer
remove soap draw take screw out lower right.
remove boottom panel screw in filter flap push to the right panel comes off undo 2 x screw,take front lip off door seal off 2 screw from door interlock then front panel will come off you will beable to whole seal and spring cilp
slightly longer but easy you can see what you are doing.
Jun 30, 2009 | Washing Machines
Change integrated Neff washing machine door seal
you will need to remove front panel this is quite easy,turn off mains open door and look for steel band spring holding front lip of door seal this needs to be removed it will be tight but will pull off,push door seal into drum so as out of the way, look at bottom of panel you will find 2 or 4 holding screws dependent on age of appliance undo these ,there is one other screw to undo behind the soap drawer take out draw and remove screw it is bottom r/h/side one you can then pull front panel away you need to disconnect door lock plug just pulls out.
remove panel out of the way and you will see another steel band holding back of seal to wash tub remove this and pull of door seal. reverse procedure to fit new one a little washing up liquid may help reassembly fit panel etc run check for leaks.
good luck
Dec 22, 2008 | Neff W5340X0 Washer
Kenmore Elite HE3t door leaking (Model 44936)??
If the unit leaks during use with a constant drip from the 6 o'clock location between the seal and the glass on the door the solution is to change tha door seal. it is quite difficult to do I would recommend you call a local service company.
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Zanussi washing machine.
switch off
remove plastic clamp that holds seal to cabinet and peel seal off cabinet.
the inside of the seal is held onto the tub with a circular spring. push seal down (needs a bit of force), pull outwards and seal will come away from tub.
lubricate the slot in the seal that fits onto the rim of the tub with washing up fluid.
starting at the top, push the first little bit of the slot in the seal onto the rim of the tub.#
working in both directions, push the slot onto the rim until completely on. this is a knack so be patient.
the circular spring fits into a slot on the outside of the seal. this is quite difficult to get into place and extra pair of hands will help.
fit seal onto cabinet - this is easy - and refit plastic clamp
test for leaks on wash cycle as water level is higher
Oct 08, 2008 | Zanussi Washing Machines
Washing Machines Logo
285 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
