Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Whirlpool glass top stove
I dropped a kettle on my glass top stove and shattered the glass on it. Is there anyway to replace just the glass top or what do you suggest?
  • 25 Answers
The glass top can be change, but be aware that if you have all your cooking element fixed togetter, this could cost plenty of $$$. If your heating element can be remove easyly, you are a lucky owner.
Posted on Dec 10, 2007
Glass top on my Kenmore oven shattered- is t repairabe
Probably cheaper to replace whole oven try insurance if u have its an accident so insurance may pay if u have.
Oct 16, 2014 | Kenmore Ovens
Is it okay to use glass whistler tea kettle on ceramic stove top range
I've seen mixed results across the internet on this one. From personal experience, for some reason, my glass teapot left some sort of stain on my ceramic stovetop. It also took longer to heat. I then went out and bought a simple metal one and have been pretty satisfied. If cosmetics are a concern, it's not too difficult a step to pour the water into your teapot after the fact, right?
Jul 23, 2014 | Frigidaire Ffed3025ls 30 Smooth Top...
I need to replace the glass cooktop on my Maytag electric stove
  1. Open oven door and remove two screws that secure top.
  2. Lift up front and slide forward about 8 inches so that you can disconnect two wire couplings.
  3. Place on table upside down(I put newspaper down to catch the broken shards of glass) and remove burner unit (1piece, 4 screws).
  4. Place old burners on new stovetop in the same position as original.
  5. Remove 4 white plastic shims (round) from old stovetop and put on new stovetop.
  6. Tighten all screws and then sit it back on stove (two front tabs fit into slots) and then insert screws into holes and tighten.
  7. Took about 20 minutes, including vacuuming broken glass from inside burners and cleaning grease form crevices between burners and old stovetop.
  8. Wrap old stovetop in the newspapers that are underneath it and place it all in a plastic garbage bag to avoid any broken glass from falling out.
Jan 21, 2010 | Maytag MER5775Q Electric Kitchen Range
Can glass kettle be used on glass hot top stove?
No you should not use a glass kettle or glass type pots on a ceran top stove. Always use metal flat bottom kettle and pots. When buying a metal kettle make sure that there is no gap between the bottom of the kettle and the surface of the ceran top. Some metal kettles have an indentation on the bottom. This does not work well on the ceran top.
Hope this helps.
Dec 30, 2009 | Kitchen Ranges
Roden Gas glass stovetop shattered MODEL GC73H
I have come across this occurence twice before.
With glass stove tops the glass is toughened and can generally withstand most temperatures associated with normal cooking situations. This, of course, assumes that there is sufficient space beneath the cooking utensil (saucepan, frying pan, etc) for air to circulate and the build up of heat to dissipate. If this cannot take place heat will build up to the point that the glass - a refractory material will no longer be able to withstand the internal and external forces created by the differences in internal and external temperatures and will thus shatter.
Though this is generally rare, it is known to take place and users are warned. Incidentally, this is the reason the shape of the glass top is the way it is and not the usual square as with other tops, in order for the heat to dissipate more easily.
In short, you should insist to your landlord that you were not misusing the appliance, but through genuine use this somewhat rare event occurred.
Aug 06, 2009 | Cooktops
Glass stove top shattered
yes it can be repaced but they are not cheap may costv a few hunderd dollars thanks from gilles
Mar 15, 2009 | Frigidaire FEF366 Electric Kitchen Range
Broken stovetop
Hi!!! With my experience some of them glass tops are very expensive check everywhere before you buy it and the labor to install one is high also.Good luck..
Jan 03, 2009 | Frigidaire Ovens
Replacement of glass top
Unplug first! Find the screws that hold the cooktop to the range. Usually in the front just above the oven door when it is closed on the underside. This should release the cooktop. The burners and wiring may have to be removed. You can order the part at
Apr 07, 2008 | Cooktops
Replacing glass top stove HELP!!!
You can buy replacement tops for your range. Check with your manufacturer for local parts distributors or service locations and they should be able to find you one. There is also online part stores that sell them like anywhere from 150-400$
Feb 04, 2008 | GE Profile JTP18 Electric Single Oven
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
418 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
