The unit is leaking water down the wall, how to i clear the drain pipe
  • 34 Answers
Blast the end of the drain with a garden hose for a couple of seconds.
Posted on Sep 11, 2009
Lg duct type inverter Remote flushing HL
HL means the drain trough in the indoor unit has flooded and caused the float switch to operate. If you have a look outside, there should be a drain pipe coming down from the roof and attached to your wall, this is where the condensate water would normally drain from the machine. The drain pipe or drain trough outlet has probably blocked up.Carefully blow air up the pipe to try and clear it. Watch out when it clears as water will suddenly run out and you don't want to get a mouthful of dirty water. Don't stick a garden hose or anything like that up the pipe.
Apr 08, 2016 | LG Televison & Video
Leaking water in front left side
hi tom
yes the drain tube may be glogged and when the unit defrosts the water just flows to the bottom of the un it then eventally out, if you have a clogged drain, you will see water on a pretty reglar basis
8, 10, 12 hours
the drain pipe is behind the back wall on the freezer, if you take that off you will se an ice build up, remove that ice and clear the drain tube
you may need to pull out the machine and remove the tube from the back to ensure that it is entirley clear
Oct 20, 2009 | Refrigerators
We have RUUD AC, in second floor , that has a white pvc ope connected to condensate drain. other end of this pipe is inerted into large pipe neanr wall. looks a drain outlet. In the middle of this white...
Hello, W/D here.
There are a couple of things you need to check:
Look at where the drain connects to the A/C unit. There should be another pvc line right next to where the drain connects. This is the clean out/flush line, and is used for adding algeside to the tray internally, which thens go out the drain. Most importantly, there is a 1/8" hole between them, and usually, it's very hard to see. Make sure that this hole is open. If it is plugged, the condensate cannot drain from the unit while the unit is running and will create havoc with your drain system. The 'tee in the drain line is an air vent/vacuum breaker and can be used for a cleanout, but try the little vent hole trick first. Your drain line from the unit should be sloped to your house drain. If you do not have a clean out connection at your unit, then you can clean from the tee to the wall. Put one cup of white vinegar into the tee. It will work as well as bleach, without the corrosiveness of the bleach. If you have a cleanout on the unit, put the vinegar in there, and restart the unit, as the vinegar needs to get flushed by the condensate.
Your tray is designed to catch any leakage, and should drain to the outside. Look for your drain line and clear it. Tray drains generally plug at the ends, and not usually in the middle. You can clean the pan drain with a piece of stiff wire. I like to use electrical solid core wire, #12. Pass it dowh the drain from the pan, and back up the drain from the outside. Chase it with water. Usually the pluggage is either insulation, or dirt dobbers.
Best wishes and regards, W/D
Aug 17, 2009 | Heating & Cooling
Leaking central a/c unit
All central A/C units have a condensate drain line that comes from just under the evaporator in the Main air supply plenum.
You may have a blockage in that drain line and will have to remove the pipe to clear the obstruction. Try flushing the drain pipe with warm water until it flows easily from the top to the end.
You might have a gravity drain that goes into a floor drain or a french drain along the basement walls. The other typical drain installation is a condensate pump that the water drains into and when the float in the tank is lifted, a small pump turns on and pumps the water (condensate) out of the house either thru a drain hose thru the wall, or into a drain in the basement, etc.
Check the entire drain line and anything connected to it for any possible obstructions and/or blockage.
If you have any other questions once you take a look at your installation, just add a comment and I'll check back within a day to provide more info, based on your input.
I hope you found this very helpful and best regards!
Aug 06, 2009 | Whirlwind FH-778 Air Conditioner
My Air conditioner leaks water
All A/C units drain water and need a clear path to drain water.
If window unit the unit MUST lean to the outside so the condensation water can drain that direction and insure the drain hole is clear of debree.
If an indoor central a/c unit the drain must be clogged the unit is leaning away from drain or the pipe going to the drain is clogged somewhere as it exits house. Cant drain if doesn't have a clear path to do it's job. Doubt it's a problem with the brand.
Aug 02, 2009 | Kenmore Heating & Cooling
Inside rhe house unit is leaking water from around the pvc pipe.
cant understand what you are describing. is the drain pipe clear. water coming out end into french drain or pump. if not clear out by mechanical means or by blowing.
Jan 15, 2009 | Ruud Heating & Cooling
Leaking water inside
Dear brians933,
If the air conditioner is window / wall mounted please make sure that it is tilted backwards about 3/8 inches. The front side should be upward and the out side portion of the AC downwards. If the drain pipe is blocked the water will leak inside. Please run a stiff wire or thin rod in the drain pipe and then **** the water out please donot blow in, the pipe is getting more blocked this way.
Hope this solve your problem.
Regards,
ramesh22
Jun 25, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
192 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
