Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Will not come on
Set had a convergeance problem. I changed the STK 392-110 ICs for upgrade 392-115s. The set came on and went off. I checked the solder joints and found a loose solder joint on one pin and repaired it. The set came on and went off and now will not come back on. It has power to the board and the power fuse is good. It has been unplugged for abut 36 hours. Anybody with an idea. Also I see many of you have requested and perhaps received a copy of the service (not operating) manual. If some would swend it to me that would be very helpful.
hunter@hunterellzey.com
Thank you
Vinylcutter
    President:
  • 4,402 Answers
Go over you solder joints again and make sure nothing is cross soldered, also check the larger resisters on the board.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Posted on Dec 11, 2007
I changed my two IC chips and three resistances on my Hitachi TV to fix color alignments. Now the problems is that yellow and blue double image are seen at the bottom of my screen with no much effect on...
Ur tv still have dead resistors parts,test all 12 resistors parts around the 2 STK convergence ICS and changes some more dead resistors parts or changes all 12 resistors parts for sure.If tv still have the same problems after tested and replaces more resistors parts or all 12 resistors parts.Than some how when u handling and replacing the 2 STK convergence ICS and resoldering the 2 STK covergence ICS u short it out the 2 STK convergence ICS by resoldering without proper grounding ur self not to allow for static electricity to kill the 2 STK convergence ICS or u using a soldering iron to high of a wattage for doing soldering ICS work.
Apr 23, 2011 | Hitachi 43FDX01B TV
I have red convergance problem.. This is the second time I have replaced all diodes and the stk chips. they dont have any 110 stk chips so i am using 150 stk chips. I replaced all diods and now RK 62...
Alot of techs recommend using the higher wattage ICs to replace the stock ones, which is never a good idea since the resistors get stressed. Upgrading to the STK394-160 IC is the only upgrade Hitachi recommends but then the values of the resistors need to be changed since the stock resistors will not work with the upgraded ICs
Oct 09, 2010 | Hitachi 61HDX98B 61" Rear Projection...
My tv looks like it is in 3-d. i went to set-up menu, convergence, the red is off and will not move over to line up. it was fine one minute then it was out of wack the next.
The tv 100% have convergence problems,it dead.The tv convergence board,require changes 2 STK convergence ICS and some or all it resistors to solved the convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 07, 2010 | Pioneer PRO-620HD 58" Rear Projection...
JVC AV-56WP74 Convergence problem. I've read about convergence problems with the JVC AV-56WP74 and I am pretty confident my set needs the convergence board repair. You mentioned to another user that you...
Hi Dave
Thanks for using FixYa. If the issue is with the failed convergence (STK) ICs which needs to be replaced then, it’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs(STK ICs) which are located behind the black/gray heat sink and also check theresistors as if they are short the ICs might blow again after sometime. Please check this picture:
And yes you are right there are repair kits available which includes repair instructions with the parts, if you want to do it yourself, you can buy and repair it yourself. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 17, 2010 | Televison & Video
My daughter pressed a button on the remote and the set went completely out of focus with mixed colors.
Ur convergence is dead.Must know how to solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The Shop will cost u $300 to fix for parts and labors.
Mar 17, 2010 | Toshiba 50H81 50" Rear Projection...
My pioneer set has a converge problem
replaced both stk convergence ics.also check
the resistors near the ics with a ohm meter to
see if any are open or burnt.
Jul 29, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
43uwx10b
They are Big Black ICs will have STK on them they are startup and convergence ICs They control set to turn on and off and convergence. Look for board that has them on it.2 of them together. If they are 110s use 180s ,Let me know what # on STKs you have.
Jan 06, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Panasonic pt-53tw53 convergence
It looks more like an open solder because you were able to align it properly after replacing the STK ICs, if there was an open resistor(s) you would not be able to get it align.
I would suggest to go back and double check the solder joints on the STK ICs as well add some fresh solder to the resistors nearby the stk392-180.
Good Luck.
Apr 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Tv troubleshoot for me
chances are that IC804 has failed. You have two ICs that allow you to converge the three colors. IC804 is used for Red Horizontal and Vertical Convergence and also for Green Vertical Convergence. IC805 is used for Blue Horizontal and Vertical Convergence and also for Green Horizontal Convergence. These ICs run very hot and have a very high failure rate which sometimes will cause damage to resistors in their associated circuits. They are both STK-110 and it's best to replace them both at the same time. It's also a good idea to upgrade them to either STK-150 or STK-180. These will run a lot cooler than the STK-110.
Before replacement do inspect for any open or overheated resistors as I stated earlier. Being you only have problems with Red Convergence the plus and minus power supplies should be okay since they are common to both ICs.
Try www.tritronicsinc.com. They have the Hitachi CZ00433 (STK392-150) in stock for $20.11 ($32.43 retail). These are Hitachi OEMs. I've had very good results replacing STK392-110s with these chips. Do check for open or overheated resistors before replacing these chips
Dec 29, 2007 | JVC AV-48WP74 48" Rear Projection...
Colors separated
You need change STK392-560(can use STK392-570)
I guess it happend when holding bolts weaken to radiator.(Check other STK on next radiator)
You have to change STK on right radiator.
Disconnect small connectors. You can l leave Hi Voltage two lines(RED). unscrew board.
Pool board out.
Unscrew STK. Set board verticaly. Just pool STK bu pincet and heatup solder. One by one...
Clean halles.
Set new STK with thermopasta on board in to hallsradiator. Screw up.
Wet contacts by liquid fluse. And sosler them.
Clean up by alcohol...Check for short by lense...
Apr 28, 2007 | Sony KP-57WS500 57" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
16 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
