Question about Whirlpool Washing Machines
Water not entering in to machine on switching on machine . water reaches only till the valve mechanism.this machine is top loaded type.
    President:
  • 1,653 Answers
It sounds as though the valve is at faulty and needs replacing. This is a fairly common fault. Unless you can source a replacement inlet valve and fit it yourself call in a repair man. It is a very quick and cheap job.
Posted on Sep 11, 2009
What is the problem of the washnine the water comes out from inletvalve thus not stop even he reach water level?
If the water continues to fill the tub above the requested unplug the machine and see if the water continues to enter the machine. If it does than the inlet water solenoid has failed and needs to be replaced.
Washer Water Inlet Valve Replacement Whirlpool Kenmore Top Load Washer...
Jan 09, 2016 | Washing Machines
Frigidaire front load washer starts the cycle but no water enters the washer
Hello friend, I appreciate your post!
Based off the information you have provided water is not entering your Frigidaire washer. Are the house valves turned on fully? Check to make sure that the house valves are turned on and if they are check to make sure the water hoses are not kinked or pinched.
The problem could be within your water pressure, pressure switch, or water inlet valve. I would recommend reaching out to a professional for further assistance regarding your washer to avoid any unnecessary part purchases. I hope this has been beneficial. -Matt
Oct 12, 2014 | Frigidaire Washing Machines
Skipping wash cycle
follow this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 13, 2013 | Admiral 3.4 cu. ft. Top Load Washer in...
My whirlpool estate top load washer ( model tawb600jq1) serial cro708750 type 110 has a very slow drip that begins during the wash cycle and continues after washing is done. How can I fix this?
Water valve is bad most likely. Once the machine gets going in final spin shut off the water supply till you can get another water valve.
This home video of mine shows the basic location of your water valve:
Sep 09, 2012 | Whirlpool Washing Machines
THE WATER IS NOT STOPPING, JUST KEEPS PUTTING WATER INTO THE WASHER KENMORE 90 SERIES
There are two possible causes of the water not stopping. First is the water inlet valves stuck in the open position and second is the pressure switch not tripping when the correct water level is reached. Turn off or unplug the machine while it is filling and if the water doesn't stop, the water inlet valve/s is/are indeed stuck in the open position. Replacing the water inlet valve assembly should solve the problem.
But if the water stops, the problem is the pressure switch stuck in the empty position. Disconnect power then raise the console up and hinge it at the rear of the machine to access the pressure switch. It is the part with the small clear hose attached to it. Detach the hose and blow air down into it including the pressure switch itself. Replace the pressure switch if the problem persists.
Click on the link below for the detailed procedure in raising the console and removing the cabinet to access and replace the water inlet valve assembly.
Removing the Cabinet on a Whirlpool or Kenmore Top-Load Washing Machine
Dec 31, 2010 | Kenmore 15864/15862 Top Load Washer
Water does not stop filling with water
The possibility is faulty water inlet valve.The valve lets the water to enter the machine.But if this valve is got weak/faulty then it will not stop the water from entering.If the water fill vale is checked ok then other possibility is faulty water fill valve switch.The switch detects the required water in the washing machine and shuts the fill valve off,but if the switch is faulty then it will not shut the water fill valve off and this will not stop the water from filling and this overfills the water.So most cases the water fill valve is faulty and it has to be replaced.But if the fill valve is checked ok then other possibility is faulty water fill valve switch. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. To get required parts ,you can get it from www.repairclinic.com . Keep updated if any more queries.Thanks.
Oct 14, 2010 | Kenmore 24032\24036 Top Load Washer
Sometimes when I turn on the wash cycle it will fill with water and complete the whole cycle and sometimes water will not come into the machine what could be causing this?
if this is a mechanical timer that controls the cycles. your timer may need replacing but it will not finish the cycle and pause on the fill mode, for the machine will not continue to cycle until the water level has reached your selected load size, a poor/faulty connection at the water valve solenoid, or water level censor can also cause this problem
May 01, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Not getting water into machine although mains water is reaching hose intake. model number of bosch is sgs44e28eu05 type si1501b
There's no water entering the machine If there's no water entering your dishwasher, check these: Water-inlet valve Float switch Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it. thanks.
Feb 17, 2010 | Bosch Dishwashers
Top load washer does not stop filling and over flows
TOP LOAD WASHERS HAVE A PRESSURE SWITCH UNDER THE TOP WITH A TUBE THAT GOES TO THE CONTROLS FOR THE WATER LEVELf89272d.jpg
Aug 11, 2009 | Washing Machines
Washing Machines Logo
19 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
