Question about Tally Line Matrix T6100 Printer
Printer displaying paper out on on control panel
  • zfdffd May 11, 2010
    Here is some great PRINTER solution by Some FIXYA EXPERT.
    Get any kinds of PRINTER solution from bellow.
    » Brother Printer Solution
    » Canon Printer Solution
    » Epson Printer Solution
    » HP Printer Solution
    » Lexmark Printer Solution
    » Xerox Printer Solution
    » Other Printer Solution
    8
    New Friend:
  • 114 Answers
Paper out calibration can be done without activating the tech access . Set the printer to Offline press the Mode Key, display will show Offline Normal.
Press either Arrow key until display shows Offline Test.
Press the Forms/1 key.
Press either Arrow key until display shows Test Diag.
Press the CPI/2 key.
Press either Arrow key until display shows Diag Prnt Cal.
Press the LPI/3 key.
Press either Arrow key until display shows Pap Out.
Press Enter
Follow the instructions on the LCD display, which will advise on removing and reinserting the paper.
After you have compleated the calibration place the pritner ONLINE to exit the menu.
And finally turn the printer power off, wait ten seconds and turn the printer power on again.
paper inn value should be less than paper out.
If the problem still exits you may need to repalce the lower tractors or the main logic board.
Posted on Feb 17, 2010
    Novelist:
  • 169 Answers
You may be able to calibrate the paper out sensor to fix the problem.
Set the printer to Offline.
Press the Enter and Line Feed keys together and hold pressed until the alarm sounds (typically 3 or 4 seconds).
You should have seen briefly displayed, Tech Access On
The display will again say Offline.
Press the Mode Key, display will show Offline Normal.
Press Enter
Posted on Dec 17, 2009
ERR 041
Must have Engine (fatal) and Jam Error logs display on the Control Panel or listed on ..... 041. paper jam. switch off the printer, remove its cartridge, look for paper jam or piece of paper jam in the rollers, clean it, place cartilage properly, switch ON the printer. it will work.
Jun 11, 2014 | OKI Electric Industry B4300 Led Printer
Paper jam in hp deskjet3510 all in one printer
Hello Shirley,
Please click . Paper Jam Message Displays on the Printer Control Panel to access the troubleshooting steps that should resolve the issue.
Jan 07, 2014 | HP Deskjet 3510 e All in One Inkjet...
Need to align ink cartridges
Follow the steps to align newly installed cartridges.
  • When prompted, make sure plain white letter or A4 paper is loaded in the input tray.
  • Press the button next to OK on the control panel display.
  • The product prints an alignment page.
  • Place the alignment page print-side down on the right front corner of the glass.
When the On button stops flashing, the alignment is complete. Remove the page and recycle or discard it.
Method two: Print an alignment page using the computer
  • Double-click the HP Digital Imaging Monitor icon ( ) on the lower right side of the Windows taskbar.
  • The HP Solution Center displays.
  • In the HP Solution Center, click Settings . Then click Printer Toolbox .
  • The printer Toolbox displays.
  • Click the Device Services tab.
  • Click Align the Print Cartridges .
****If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Feb 05, 2013 | HP PSC 1210 All-In-One InkJet Printer
NO BLACK PRINTING on my Canon mx310 printer. in case of misprint please align head
Follow the steps below to align the printer
  1. Press and release the On/Off button located in the upper left-hand corner of the operations panel to turn the power on. Open the sheet feed cover on the rear paper tray. Pull out the paper support until it stops at its fully extended position.
  2. 2 Open the paper output tray. Flip the paper output tray extension out. Load a sheet of letter-sized plain paper in the rear tray. Slide the paper guide to the right until it is snug against the left side of the paper.
  3. 3 Press and release the Home button on the control panel. The Home screen will be displayed on the LCD panel. Press the Up or Down Arrow button to scroll through the menu. Select the Settings option. Press and release the OK button. Select the Maintenance option. Press and release the OK button. Select the Auto head align option. Press and release the OK button.
  4. 4 Wait for the confirmation screen to be displayed on the LCD panel. Select the Yes option. Press and release the OK button. Wait for the printer to automatically align the print head and print the alignment sheet. This process should take approximately 4 minutes.
Regards,
Shawn
Feb 03, 2011 | Canon PIXMA MX310 All-In-One Printer
Xerox phaser 6130 is stuck in 8.5 x 11 -- we need A4
When loading paper in the Paper Tray set the paper type and size on the Control Panel before printing.
NOTE: If [None] is selected in the Paper Type pull-down menu in the print driver, printing will default to the Control Panel settings. Printing will be performed only when the settings for the paper size and type configured in the print driver match the settings on the Control Panel. If the settings in the print driver and Control Panel do not match, follow the instructions displayed on the Control Panel.
To select a paper type:
NOTE: Paper type settings must match those of the actual paper loaded in the paper trays; otherwise, image quality problems can occur.
  1. Press the [Menu] button on the Control Panel.
  2. Press the [Up] or [Down] arrow button until 'Tray Settings' is selected on the Display Screen, and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select the tray, and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button until 'Paper Type' is selected, and then press the [OK] button.
  5. Press the [Up] or [Down] arrow button to select the correct paper type for the loaded paper, and then press the [OK] button.
  6. Press the [Menu] button to exit.
To select a paper size:
  4. Press the [Up] or [Down] arrow button until 'Paper Size' is selected, and then press the [OK] button.
  5. Press the [Up] or [Down] arrow button until the correct paper size is selected, and then press the [OK] button.
Jul 06, 2010 | Xerox Phaser 6130 Laser Printer
My hp deskjet 3550 is not printing. the green light at the power button keeps on blinking. What is the problem? both ink cartridges are full. there is no paper jam.
1. Turn the printer on.
2. When the memory starts counting on the control panel, press and hold the green SELECT button. Continue to hold green SELECT button until all three Control Panel LED's are illuminated and on solid.
3. Release the green SELECT button.
4. The control panel will display SELECT LANGUAGE.
5. Press the DOWN ARROW button until control panel displays COLD RESET.
6. Press green SELECT button. The printer will perform a cold reset and then continue its power-on sequence.
May 28, 2010 | HP Color Laserjet 3550 Printer
After clearing a paper jam incorrectly
Please check all places and follow all the steps here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00441807&cc=us&lc=en&dlc=en&product=441125
Thank you
TechSaver
Feb 05, 2010 | HP Officejet 5610 All-In-One InkJet...
Power on but can not display on control panel
the problem of the 1200 is that it is not picking paper but i have solve the problem thank.
but the 4300n laserjet iks the printer that did not display in the control panel
but i surpect the logic board and the upper board can you tell me your idear about the printer 4300n laserjet am waiting
Jan 07, 2010 | HP LaserJet 1200 Printer
Tally 2250
Measure with a ruler the size of the form in inches that you are going to use .
Calculate the number of lines you have by relating it to the Line Density using the formula
Form Length = Form Size * Line Density
For example for 11 inch paper at 6 lpi = 11 * 6 = 66 Lines
You must disable the Printers Menu Lock before you can change any settings - (power on holding down SETUP)
Press SET UP button on the Control Panel.
Select the MENU Option on the Control Panel Display.
Select the NEXT Option on the Control Panel Display until PAPER is displayed.
Select the PAPER Option on the Control Panel Display by pressing the button directly beneath it.
Select the Desired Paper Path for the Form Length change - The different Paper Paths can be stepped through by using the NEXT Option on the Control Panel Display.
Select Paper Path by pressing the button directly beneath it.
Select FORMLEN by pressing the button directly beneath it.
Select LINES and then increase or decrease the value on the Control
Panel Display by using the two arrow buttons until the desired length in lines has been achieved.
Select the SET Option on the Control Panel Display by pressing the button directly beneath it.
Set the Printer back ON-LINE by pressing the ON-LINE button.
This will set the form length on the printer, see the support section of www.dascom.co.uk for more info
Sep 18, 2008 | Tally T2250 Matrix Printer
Tally Line Matrix T6100 Printer Logo
206 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
