My screen has went to the right hand side but pic is ok
    Scholar:
  • 66 Answers
Go to picture mode on your remote control and select the central options to restore your pictures back. i hope this helps..........
Posted on Sep 11, 2009
  • beki08
    beki08 Feb 29, 2012
    i have this same problem and we have tried resetting it to factory settings but nothing. there are no central options on remote so can't change picture to make it central.
I have a SONY Flat Screen TV 3LCD and the screen went black.
open the heatch on the lower right hand side and flick the lever and pull the bulb housing out look at the internals of the bulb to see if it has failed out it will have some little particles floating around inside or a dark burnt spot of completly broken coil if you have any of that get a new bulb from ebey ok they are as easy the change as to remove and inspect but be careful they contain mercury and are toxic so handle with care and good luck ok
Jan 11, 2011 | Sony Televison & Video
I want to print on photo paper I have no idea how to start,printer is a photosmart 7450
OK, Assuming you have Photo paper loaded in your printer and your photos from your camera downloaded to a photo software program. eg Adobe Photoshop/ Serif Photoplus etc.
Bring up the photo/photos you wish to print on your photo software. eg click on the open yellow folder top left and open the fotos you want.Click 'Browse' if you don't see the ones you want. ( Open as many as you want to print.)
In order to make your prints economical you can print two or three fotos on one sheet. Click 'File', 'Print multiple' and you will see format sheets in the right pane. If you only want to print two pics on one sheet click in the right pane on the two 7 x 5 sheet or, to print three pics of the same or different pics click the sheet with three frames on it. You will now see your pictures in the right hand frame and the format sheet in the right hand frame.
Left click and hold on the pic you want and drag it into one of the boxes in the right hand frame - let go.
That pic will now appear in the box selected. you can now size it to the box it is in. If it is the right way up eg portrait in top left of a three frame page click on fit to frame to maximise picture. Click and drag another pic from the left side frame to another box in the right frame. If you have chosen the three option sheet click and drag your next foto into the bottom box on the sheet. This is a Landscape box but don't worry.
After dragging your pic into it look for an icon in the function bar along the top where, when you hover your cursor over it, says - 'rotate and fit'.(It's a square with funny corner bits!) Your pic will the be realigned to fit the the box. Having all the pics you want on the sheet click the print icon. (Picture of a printer on the tool bar.) when the print box appears click on 'Properties' and open the 'Paper/quality' tab. click the drop down box for paper and select HP Photo paper - gloss or whatever you are using. The quality will automatically set to 'Best'. Click OK and OK and the files will be transferred to your printer and it will shortly start printing your pictures.
Bset of luck.
Any problems at all, just get back to me.
Cheers.
Ian
Dec 01, 2009 | HP Photosmart 7450 InkJet Printer
Dryer does not start
Check the fuse on the blower housing.
To get to the heating element on most of these dryers you remove the back dust cover: whirlpool%20dryer.jpg 1. Hi Limit (small limit upper right hand side of this pic) the most frequent problem if dryer RUNS but no heat. 2. Heater assembly. 7. Control thermostat(s). 5. Fuse(350F), if blown(open) the dryer will NOT run. 4. Heater element.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 13, 2009 | Dryers
No pic blue screen but we have sound
hi moma. the problem is that you need a new lamp for your tv...mind just went out a week ago and that is what i had to do go to a tv repair man tell them what kind of tv make sure you have model and serial no. plus lamp type,,, you will find that on the side or back of you tv on the left hand side as you are looking at the screen... hope this helps.
Jun 02, 2009 | Apex Digital GB5108 51" Rear Projection...
Problem with touch screen
Same thing happened to me. Use the physical buttons on the right of the device to open the menu. Then use the arrow keys to go to "Settings" and hit OK. Navigate to "Display" and hit OK. Move down 2 to "Touchscreen calibration" and hit OK. Follow the directions (first cross is in the top left). That should sort it.
Jan 05, 2009 | Archos 605 WiFi Digital Media Player
Gateway monitor problem
Does this monitor has a reset to factory specs on the menu? If so then select it.
Jan 05, 2009 | Gateway FPD1760 17" LCD Monitor
Can't change channel
Most remotes have the source button at the top right hand side all the top left hand side it should be called sauce or it might just have three lines if you have a black lever on the right hand side then you need to press that in and wait it should put you to the av screen then if you let go you can press down or up that will let you chose av or video of hdmi ok if you want to send me a pic of the Tv so I could help you more if you can't find it I don't mind ok
Jul 10, 2017 | Toshiba Televison & Video
Won't take a picture
I work on these cameras all the time you have a ccd going out or has gone out that is causing the auto sensing feature to now work their for the camera stops working. 1 other thing it might be could be the main-board but they don't go out as often.
Mar 29, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Televison & Video Logo
Top Televison & Video Experts
