Question about HP Officejet 4355 All-In-One InkJet Printer
I CANT SEND & RECEIVE DOCUMENT THROUGH FAX. PLS, ASSIST ME. TQ
4 Suggested Answers
  • 111 Answers
SOURCE: 5610 cannot send or receive fax
There are about a billion reasons you could be having this problem, the most common one being that you don't have a phone line plugged into the fax machine. You don't provide very much information about your problem or what you've tried up until now to solve it.
Fortunately, HP.com has a web page that should help you figure out what is going on:
Cannot Send or Receive Faxes
Let me know if this helps. If not, please post back with more information about the problem. Thanks.
Posted on Oct 03, 2008
SOURCE: cant send or receive fax
how do i stop the # 9 from coming up first when I dial a fax #
Posted on Oct 28, 2008
  • 1602 Answers
SOURCE: I can receive faxes,but cannot send on out.
CHECK THE FOLLOWING FOLDERS IN THE CONTROL PANEL:
NETWORKING AND SHARING CENTER
PROBLEMS REPORTS
SECURITY CENTERS
WINDOWS DEFENDER
WINDOWS FIREWALL
I AM GOING TO START IN THE NETWORKING AND SHARING FOLDER AND THE WINDOWS DEFENDER AND FIREWALL 1ST
ROD
Posted on Mar 13, 2009
FAX will not send nor receive.
Free Fax Free Internet Faxing
You could try this if you have a normal computer scanner or the document is a file on your computer before being printed. Sounds like your fax machine is simply broken.
Feb 06, 2014 | HP LaserJet 3050 All-In-One Printer
Whenever i send a fax, the machine confirms by viewing 'TRANSMITTING OK' but the addressee receives a blank document
Check the baud rate of your transmissions. Slow them down to the slowest setting and send a test fax to a helpful person. Slowly increase the baud rate (communication data speed) and send the fax test. When the fax doesn't show up on the receive site, then step one baud rate speed back, and save the setting.
It could also be your fax that is faulty, or even the receive sites fax, also being faulty.
To test your copy-head, insert a document into your loading section of the fax and press copy. If the copy prints out fine, then you know the head is reading correctly.
It is also possible that the receiver fax (the other end) has a printhead failure.
Nov 25, 2013 | Canon FAX-JX200
Can not send fax. The receving fax rings but my machine does not respond and send the fax. I can receive ok.
The document does not feed into the machine.
Be sure the document is not wrinkled, and you are putting it in correctly. Check that the document is the right size and not too thick or too thin. (See document types and sizes on page 43).
You cannot receive faxes automatically. Check if "TEL" appears on the right side of the display. In TEL mode, you
cannot receive a fax automatically. Be sure the handset is seated on the cradle properly.
The machine cannot receive faxes manually. Do not hang up the handset before pressing Start/Enter to receive a
fax.
The machine does not send anything. Check that the document is loaded face down. Send should show up
in the display after it dials. Check if the machine to which you are sending can receive your fax.
Dec 22, 2010 | HP 1010 Plain Paper Thermal Fax
Receive has replaced send on my on teleface 2820
Make sure the document is inserted 'deep' enough into the ADF. Make sure after inserting the document, the display shows 'key in the destination number & press start'.
Dec 11, 2009 | Brother Office Equipment & Supplies
My fax machine will not fax
but you can receive document? or just you cant send document?
well check you telephone conection in LINE
Sep 25, 2009 | Brother MFC 210C All-In-One InkJet Printer
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after
each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 1.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Cant recive fax
Ok - phone off hook is a message on the printer because you are on the phone. There is a phone that is up somewhere in your home that it can recognize. You cannot send a fax or receive and be on the phone at the same time. This can also be caused by credit card machines, internet service (filter needs to be on fax line), and other fax machines.
To the original poster - your question is fairly vague. This hp link solves the most common issues when you can send but not receive.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01503742&lc=en&dlc=en&cc=us&lang=en&rule=21569&product=391182
Sep 09, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Unable to receive fax
unable to send fax through power line carrier communication. only some part of the document received
Apr 28, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Setting up fax machine to receive
Receive Mode Setting
On the operation panel, press the following buttons to select the appropriate receive mode.
  1. Press <Fax>.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode set], then press <OK>.
  4. Press the right or left arrow button to select the receive mode that best suits your needs, then press <OK>.
    FAX ONLY MODE: When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only.
    MANUAL MODE: When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually.
    ANS MACHINE MODE: When you want to receive voice messages on your answering machine and receive faxes automatically.
    FAX/TEL AUTO SW: When you want to receive faxes automatically as well as voice calls.
    DRPD: When you have subscribed to a DRPD service with your telephone company.
  5. Press <Stop/Reset> repeatedly to return to fax standby mode.
Sending Methods Sending From Your Machine (Memory Sending)
  1. Load the document on the Platen Glass or the ADF.
    Sending from the platen
    Important: When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
    Sending from the ADF
    *MP830 shown
  2. Press <FAX>.
  3. Adjust the settings for your document as necessary.
  4. Dial the recipient's number using the numeric keys or speed dialing.
  5. Press <Color> for color sending, or <Black> for black & white sending.
    • When the document was loaded on the Platen Glass:
      1. When the following message is displayed, load the next page on the Platen Glass.
        If you have only one sheet to scan, press <OK>..
      2. Press <Color> to send in color, or <Black> to send in black and white.
        IMPORTANT: If you do not press the same button you pressed in step 5, the machine does not start scanning.
      3. Repeat steps 5a and 5b to scan in all pages of the document.
      4. Press <OK>.
    • When the document was loaded in the ADF:
      The machine starts sending automatically after the document is scanned in.
      Note: Color sending is available only when the recipient's fax machine supports color faxing.
  • To cancel sending before sending a fax, press <Stop/Reset>.
  • To cancel memory sending while sending a fax, follow any instructions on the LCD after pressing <Stop/Reset>.
  • If the document remains in the ADF after pressing <Stop/Reset> during sending a fax, press <OK>. The remaining document is automatically fed out.
Sending From Your Machine (Manual Sending)
Use manual sending when you want to talk to the recipient before sending a document, or if the recipient does not have a fax machine that can receive automatically.
Caution:
  • With manual sending, you cannot use the Platen Glass to send documents.
  • You will need to connect a telephone to your machine if you want to talk to the recipient before sending a document.
Follow this procedure:
  1. Connect a telephone to your machine if you want to talk to the recipient before sending a document
  2. Load the document in the ADF.
  3. Press <FAX>.
  4. Adjust the settings for your document as necessary.
  5. You can lift the handset if one is connected to the machine.
  6. Dial the recipient's number using the numeric keys or coded speed dialing.
  7. Talk through the handset to the recipient. (If you hear a high-pitched signal instead of the
    recipient's voice, go to step 9.)
  8. Ask the recipient to set recipient's fax machine to receive faxes.
  9. When you hear a high-pitched signal, press <Color> for color sending, or <Black> for black & white sending. Then hang up the handset.
Jan 07, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Recieve but not send
Is your handset plugged in the right hole. Customers occasionally plug the handset in the hole marked ext.
Dec 07, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
HP Officejet 4355 All-In-One InkJet Printer Logo
35 people viewed this question
Seeker5211
Seeker5211
