Brother HL2070N is printing black dots on the left side of the margin
    Master:
    Sergeant:
  • 460 Answers
It is a catridge problem. so you can replace it.
Posted on Sep 14, 2009
I have small black dots down the left hand margin of each printed page approx 10cm apart. MFC8870DW
10cm means it's caused by a large roller. The only roller large enough for that would be in the drum. Replace your drum and it should clear up, the model number of the drum is DR520.
Dec 03, 2014 | Brother MFC-8870dw Wireless Multifunction...
I have small black dots down the left hand margin approx 10cm apart- machine is only 12 months old
hi
First try printing a few pages to try and clean the drum unit. If the problem is not solved after printing a few pages, the drum unit may have glue from a label stuck on the drum surface.
go to this link -- below for further instructions
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000200/000016/faq000216_016.html?reg=us&c=ca&lang=en&prod=mfc9440cn_all&Cat=112
hope this helps
Nov 14, 2010 | Brother MFC-9440CN Laser Printer
Unwanted 'dots' on printout
There is a dot somewhere on the drum, remove the drum and toner cartridge from the machine, then remove toner from drum. Look at the shiny roll, you can turn it from the black gear on the side. Once you find the dot use a cue tip dipped into little bit of alcohol and clean it off.
Mar 31, 2010 | Brother MFC 240C All-In-One InkJet Printer
Black line 1cm in from margin when printing
this is a catridge problem so pls replace your printer catridge.
Aug 22, 2009 | Brother MFC-9420CN All-In-One Laser...
Little dots on right side of margin (Brother HL-5040)
I would have guessed the trouble shooting steps you first performed. It could still be a bad imaging drum. Or a fuser. Not sure if this model has a replaceable fuser or not.
Jul 08, 2009 | Brother HL 5040 Laser Printer
11 blue dots print out down the left hand side of documents
It's probably the toner cartridge again. See if you can spot defects at the cyan drum unit that matches the marks on your printout.
Apr 14, 2009 | HP LaserJet 4600dn Color Printer
Magenta Dots vertically on Left margin of page
That is referred to as a repeating defect...most likely caused by a defect on the magenta drum unit. Here is a link for information on how to repair this problem:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000016/faq000216_016.html?reg=us&c=us&lang=en&prod=mfc9440cn_all&Cat=3
Jan 17, 2009 | Brother MFC-9440CN Laser Printer
Dots on the left side margin
This problem comes from drum cartridge, you may try:
1) take out drum cartidge open drum cover clean the surface at leftside(using soft brush) and check drum surface at leftside, there is damage if you see the color surface appear a broken-ring at leftside(the color changed), you have to change new drum cartridge,
2) sometimes cause cartidge clean brush dirty can not do well cleaning job, just clean this parts at leftside well then turning drum a little there is no toner appear at surfac leftside if ok.
Dec 21, 2008 | Brother HL 2140 Laser Printer
Black bullets down left side of paper
inspect the pc drum, if there is no dots, then its ok, also inspect fusing unit rollers and transfer belt for dots and clean laser glass.
Apr 24, 2008 | Konica Minolta magicolor 2300DL Laser...
Printing dots on Brother HL 4040CN
do this procedure
1.print test page then stop the printer on the middle print proses by turn the printer of or open the rear cover
2.remove the paper jam carefully
3.look to the paper if the problem found change the drum unit els the fusser unit cause the problem
Apr 01, 2008 | Brother HL 1440 Laser Printer
456 people viewed this question
jasbo
jasbo
