Damaged screen I have a damaged screen =is it possible to get a replacement ?
  • brylmario Feb 27, 2008
    My laptop (Dell Inspiron 1100) screen is damage, with black spot and lines, unable to see anything, any help?
    Thanks
  • Anonymous Jun 17, 2008
    Everex StepNote SA2050T PC Notebook cracked screen
You can find replacement screens for £50-£150 (try pchub.com) Replacement needs patience and a small screwdriver
Posted on Jan 25, 2008
    Scholar:
  • 151 Answers
It's pretty expensive to have it replaced but it can be done.
Canvass repair prices first and decide whether to have it repaired or replaced with a new computer.
Try using the external port and attach a monitor there so you can still use it at home...
Posted on Dec 10, 2007
Copier stays on please wait after resumig one job
There are two possible solution, the first is that the Drum Potential Sensor is damaged and need to be damaged, the second is that may the NV-RAM is damaged and need to be replaced. This two possible problems need to be solved by a experienced technician. If this question is posted by a user, than the only thing you may check is do the PCU Harness is connected good. That harness is located under the touch screen, when you will open the front door, than putt the toner bottle in position for replacement. right under the touch screen behind the toner bottle you will see two harness re-connect them and see do the problem will be solved if is not than are the two other possible solution i mentioned in the start of the answer. good luck.
Nov 12, 2014 | Ricoh Toner for Aficio 1060, 1075, 2051,...
USB PORT DAMAGE DROPPED LAPTOP
It's possible you cracked a chip or two when it dropped, or damaged a connection between a diode, capacitor or so.
It's also possible that a ribbon has come loose within the device, which will need to be tightened again. But your message is also a bit unclear.
If the screen isn't responding, you may need to tighten the screens ribbon cable, after that if it isn't working the GPU may be cracked. Afterwards, if that doesn't work you may have damaged the mobo itself.
If a USB port isn't working, the usb's connection to the mobo needs to be re-soldered. Or a replacement USB may be needed.
You're going to have to bring it in for work possibly, unless you want to try to fix it yourself, in that case you can order replacement parts for laptop on eBay since companies themselves do not sell replacement parts.
Possibly wait a day and see if it works afterwards, when something hits the ground it has a lot of friction go through it which will cause a lot of heat to it.
Feb 26, 2013 | Computers & Internet
I repaired the female power jack in my Averatec and must have compromised something else in the process as now my screen has two large black quarter sized black spots, on quarter of the screen at upper...
If you put any pressure on the screen while repairing the power jack then yes, the LCD will need to be replaced. If you are certain that you did not physically damage the screen during the repair then it is possible that you damaged the motherboard (which houses the video processor). If the motherboard was damaged I would say it's time for a new laptop.
Aug 24, 2009 | Averatec 3200 Notebook
Fuji Finepix 450. Nothing on the screen
Screen has been damaged. Possibly due to impact damage. It's probable the usb socket is damaged to. If the camera still works and saves pictures then you can upload pics to your pc via the card reader. Try sourcing another camera for donor parts like the screen on ebay
Apr 08, 2009 | Fuji FinePix F450 Digital Camera
White screen on my ipod 2gb nano
Hey,
there are a few possible reasons for this
1. the lcd screen is damaged.
in this case the lcd screen would need to be replaced,
check warranty and apple repairs https://selfsolve.apple.com/GetWarranty.do
2. the board or the cable between the lcd is broken or damaged.
the lcd screen would need to be replaced or the flex cable, but that might be difficult.
3. the ipod is frozen.
instructions are at
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
Let me know if you need anything else.
Thanks,
Ekse
Jan 13, 2009 | Apple iPod nano
I have a samsung d900 and the screen has gone can see nothing exept what looks like liquid is it pos to have a new screen fitted and if so how much
THe flat cable from the phone to your screen is damaged probably (its also possible the screen itself is damaged but less likely depending what happened with the phone)
A good repair shop should be able to replace this item.. if its the flat cable no worries, if its the screen yoru better of buying a new phone
Dec 05, 2008 | Samsung Cell Phones
When i try to flip my sidekick 3 sumtimes it gets weird displays
Yep, it will. The flex cable is probably damaged
Here is a guide for the replacement of the lcd screen:
How to replace Sidekick 3 LCD Screen
find the screens here:
Sidekick 3 LCD Screens
I hope that helps everyone.
Nov 23, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Broken Scree
Good Day;
It is very possible to replace the screens on the TV. Is the out side damaged or both, the TV has two screens? Good Luck, big IRISH.
Sep 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Samsung e900 white screen
Need a new ribbon, can be found on google about £8
Nov 04, 2007 | Samsung SGH-E900 Cellular Phone
Damaged screen.
the screen cannot be repaired, it must be replaced
Aug 28, 2006 | Panasonic TC-32LX50 32 in. HD-Ready LCD...
Computers & Internet Logo
312 people viewed this question
Alun Cox
David Payne
David Payne
