Question about Pentax Optio 330GS Digital Camera
My Pentax optio 330GS wont switch on. After pressing the ON button you get a couple of beeps and then nothing happens. The batteries are fully charged. If you gently tap the camera in your hand, sometimes the camera switches on and the lense comes out and allowing you to take pictures as normal! This camera was a birthday present and holds great sentimental value. Please help with any advice!
    President:
  • 2,761 Answers
Two possibilities: one bad, one not so bad. If you've recently dropped the camera you've likely damaged the lens tube (housing), and the camera will require professional repair. Before you panic though, the problem that you described is frequently battery related. Make sure that your batteries are the correct type for the camera, and that they are fresh/fully charged. If the batteries are OK, the problem may be due to corrosion on the contacts inside the camera. Remove the batteries and wipe the inside contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, wipe the ends of the batteries, and replace them in the camera. This cleaning process works about 90% of the time, and I hope that it cures your problem.
Posted on Sep 11, 2009
Testimonial: "Dear BillB-SA, Fantastic!! your recommendation to clean the battery contacts has worked a treat, the camera now works beautifully! Thank You so much!"
    Brigadier General:
  • 4,090 Answers
Dirt in the lens mechanism follow the advise below to clear it up. You almost found the answer yourself.
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 80 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Please rate our help to keep the FREE service online++++Thankis for using FIXYA
Testimonial: "Thanks for solution, Tried BillB-SA's solution first to clean battery terminals and that has fixed problem, will keep your solution in mind next time."
bmwrider
  • 215 Answers
SOURCE: Pentax optio 60
Your shutter is driven by a small motor attached to the lens assmbly. It could be that which has died or more likely you have a sticky shutter. A small knock or a drop of soda can stop them from opening. Try switching on and very gently with a cotton bud see if you can help open the shutters. Whatever you do don't force them and force them out of shape. You may have to do this a few times to get in sync with the power up sequence but if you can get both shutters to open fully you should be in business. If they keep sticking I've seen one guy glue them open. Personally I'd rather fix them so they do their job.
Posted on Jul 12, 2006
SOURCE: M40 Pentax - re tracking lens problem
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I must say credit where credit is due, Pentax Head Office Customer service was fantastic, they contacted the repairer, whom confirmed that my camera was in excellent condition and they took full responsibility for the repair cost. WELL DONE PENTAX!! I shall recommend to any of my friends whom are looking to buy a camera and any future replacement camera, will be PENTAX from now on. Great customer service, quick response all in FANTASTIC
Posted on Jun 12, 2009
  • 16 Answers
SOURCE: Pentax e10 shuts off The pentax optio e10
You probably set the auto power-off for energy saving
Posted on Jul 23, 2009
  • 102366 Answers
SOURCE: Optio 330gs Windows 7 compatibility?
http://www.pentaximaging.com/support/manuals-and-literature/
You also might want to consider NOT connecting the camera to the computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
Posted on Jul 12, 2010
lock123
  • 6831 Answers
SOURCE: How to unlock card in pentax optio Says Card
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 22, 2010
Pentax Optio E20 will not turn on.
The green light only means the memory card is getting power. That nothing else comes on indicates a serious problem that requires a trip to your local camera shop for help.
Nov 09, 2014 | Pentax Optio Cameras
I installed driver for my pentax 330gs and its now corrupted and can not be uninstalled, how do i remove it? i have tried removing it from add & remove program, used the software installation remove...
Forget all that. If all you want to do is download your pics from your camera, use a card reader to download to a folder you create on your desktop.
Nov 11, 2009 | Pentax Optio 330GS Digital Camera
Camera wont turn on!! help!!
Dear Texaslilly,
Although there is nothing much to do but you can still try the following.
  1. Try with different set of batteries
  2. Remove the memory card from the camera
  3. Cameras generally do have an option to plug-in external power supply..Try with external power supply .. if there is any.
  4. Now this might sound little crazy but no harm in trying .... Remove batteries... Press and hold the power button for few seconds... release the power button ... reinsert the batteries and try to power on without memory card.
Try the above and let me know if it works.
Regards,
Srinivas.
Jun 19, 2009 | Pentax Optio T20 Digital Camera
Pentax Optio M20: won't work.
ok have same problem press the power button and and the play> button at the same time. your screen will come on but not lens. then hold the play button down untill lens come out. this will work for you , you may have to do it a couple of times but it will work
Jan 20, 2008 | Pentax Optio M20 Digital Camera
Pentax Optio 330GS its gone blind!
You've probably got something as simple as a ribbon cable loose in the camera. Beware though, dismantling is a serious task unless you have experience. Amazingly the CCD is often connected in such a simple, analog-esqe, way that disconnecting it doesn't cause an error, just a black screen.
Sep 08, 2005 | Pentax Optio 330GS Digital Camera
Pentax Option 330GS problem turning on
Sounds like the images are corrupted on the card. If you have another card then try starting the camera with it. To get the card working again, you will need to format it in a card reader with FAT16 format, or try in another camera. If you want the images, you will have to obtain repair software to try to retrieve the images.
Color shift problem with 330GS
This is because the RGB filters in the camera are not perfect, and there is no one "green" colour. The green pixels pick up a wide band of colours, and are somewhat sensitive even to red and blue, especially near where green shades into red.
Black LCD screen on camera
Just had the same problem (black display). I moved my hand in front of it and took pictures of things but nothing happened. Then my girlfriend tried to point it to a lamp, and all-of-a-sudden it kinda woke up from a screensaver or something. So weird, but it worked. Perhaps it needs enough light in order to start using the display and lens. I couldn't take any pictures when the LCD was black. So, try pointing it towards a strong light source before you break your camera.
Aug 30, 2005 | Pentax Optio 330GS Digital Camera
Pentax Optio 330GS Digital Camera Logo
107 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
