Question about D-Link AirPlus DI-524 Wireless Router
Hi, I have a toshiba windows XP laptop which stopped connecting to wireless network(WEP) .But it connects to network through LAN with ethernet cable .Laptop wireless finds my network but does not connect( other laptops connects to same network).I checked intel wireless adaptor function, it seems functioning.No problem with router confirmed by internet provider, as it connects to other laptops.tried updating wireless adapter, reinstall it, no success.CAN u help resoving this with remote assistance??
Check your security settings would be a good start. Have you checked to see if XP uses WEP to authenticate? (it should do this automatically but sometimes it doesn't)
Posted on Sep 11, 2009
It connects to local networks but not the internet
You don't say whether you are trying to connect via an ethernet cable, or via a wireless connection.
Try the following in order: Some of these may seem obvious, but it helps eliminate the more simple problems first: (general guidance, as I'm not sure which windows version you are working with. Did you upgrade from Vista to Win 7?)
Assume you have enabled the network on the laptop FN + number key or physical switch?
  • Check if you have the Ethernet and wireless drivers for this laptop first from the Toshiba support site and install them
  • In Control panel / device manager, see that the network devices for wireless and Ethernet Lan are appearing and have no warning mark next to them. If they have, you need to check what the problem is by clicking on the device shown and following the instructions given (repost your findings if you need more help)
  • See if you can connect to the internet using the ethernet lan connection cable (direct wired connection). If it does this ok, the problem lies with the wireless connection.
  • Assuming the wireless card in the laptop is present and is functioning, the next step is to check the router settings. Using the supplied CD that came with the router, or clicking on the router symbol in control panel / network and open the wireless security settings page, reset the wireless password and make a note of it. Save settings. When setting security, choose 128 bit security for more safety.
  • See if the laptop now picks up the network and when prompted enter the password you just created. If this works you are finished.
  • If it still does not work, try disabling Windows Firewall ( a common problem) and see if that then allows for connection.
  • If it STILL fails to work, try the laptop on a friends network. If it connects then, the problem is with your router. If it does not work, you have a failing wireless card in the laptop.
To confirm this, obtain a USB network dongle and test it on your laptop with your own network. You can get a replacement card off the likes off eBay and this is not difficult to fit.
Jul 13, 2011 | Toshiba Satellite A305-S6908 Laptop
Router working but as soon has i secure it with a WEP key my wireless wont work anymore ???
You may need to edit the settings in the connecting computer, it may be using old specs and being rejected....without prompt, on some OS.
Jul 12, 2011 | Linksys Wireless-G WRT54GS Router...
I upgraded my toshiba NB200 from XP to Vista, but can no longer connect to the internet. Diagnostics is telling me that the computer does not have a wireless network adapter installed. It worked on XP....
Use an Ethernet cable to connect the LAN port on the Toshiba to your cable-modem (or DSL-modem) or to your home-router.
Then, run 'Windows Update', and look for "Optional Hardware" updates, which should include the correct device-driver for the wireless adapter.
Jun 15, 2011 | Computers & Internet
Cant Find Ethernet and Wireless lan Drivers
Use the Driver Genius Professional Software to get the updated drivers for ur pc
Apr 19, 2010 | Toshiba Satellite A205-S5804 PC Notebook
Wireless connection 2 says its not connected
Yep. Plug the ethernet cable into the computer. Reset the modem AFTER you plug in the ethernet cable. If it still cannot come online then go to your control panel, network connections (xp) and right click on Local Area Connection (LAN). Go to properties, then Internet Protocol, highlight and click on properties below that. It should be obtaining an IP and DNS automatically unless you know you have a static IP (most dont). Close those two windows and right click on the LAN again. Disable. right click again and enable. It should do it. Vista... Control Panel, network and sharing center, manage network connection, then do the LAN the same way you do in XP
Oct 09, 2009 | Motorola Computers & Internet
How can i connect a toshiba runniung windows me. to the internet via ethernet cable? is it possible with just the cable and no card? is there a programe i can download to help my laptop? what can i do?
It should have a LAN (network card) built in to the laptop.
First of all make sure you have the LAN (network drivers) installed. You can do this by checking in device manager.
To open device manager click Start, point to Settings, and then click Control Panel.
Double-click the System icon. Click the Device Manager tab and look in the list for network adapters/controllers.
If the driver is installed you should be able to directly connect the ethernet cable to your laptop.
I'm not quite sure where the ethernet port is on that particular laptop but it will be on the back or sides of the unit and it will be the only port the ethernet cable fits into.
From there you should be good to go, if you can't get a connection reset the modem by removing power from it for 2 minutes, connect the power again, wait another 2 minutes for the device to settle and try the internet connection again.
Regards.
Oct 01, 2009 | Toshiba Satellite 1715XCDS...
Unable to activate wireless lan
TRY GOING TO START, START SEARCH TYPE WIRELSS DEVICE
LOOKE IN DEVICE MANAGE FOR WIRELESS FOLDER
INPUT DEVICES
AS SO CHECK THE FOLLOWING FOLDERS ALLOWING COMMUNICATION BETWEEN THE LABTOP AND THE WIRELESS DEVICE AND THE COMPUTER.
NETWORKING AND SHARING FOLDER
PROBLEMS AND REPORTING
SECURITY FOLDER
SYNC CENTER IF YOU HAVE ONE
WINDOWS DEFENDER
WINDOWS FIREWALL
THE LAST 2 PROGRAMS IN THE LIST ABOVE CAN STOP THE DEVICE FROM WORKING.
YOU WANT MORE HELP I WILL HELP YOU IF YOU HAVE THE SITE CONTACT RODGANDYSR@GMAIL
ROD
May 12, 2009 | IBM TP R51 - P M715 1.5GHZ 256MB 40GB...
Can't connect to my router anymore (WEP encrypted).
Hi deray953,
First we need to remove the previous profile in your wireless network. I believe you know the SSID for wireless connection using WEP security. You can check this by going to;
Using Windows XP SP2/3
1. "Control Panel" > Switch control panel to classic view ( look at the upper left side ). > Double click "Network Connections" > Right click "Wireless Network Connections" > choose "Properties"> Click the Tab "Wireless Networks" ( middle tab) > go to the list of profiles and remove the Wireless name or SSID for your home connections. > click OK and Close the properties of wireless.
To reconnect again, you need to know your WEP key or network key for wireless connections if not, you can do this procedure...
1.Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
d. Click on the Wireless Settings under Setup.
e. take note of the KEY 1 ...that is your WEP key..take note of it.
Connecting Through Wireless Zero Configuration (Windows XP SP1 and SP2)
For Windows XP Service Pack 1:
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then, click on View Available Wireless Networks.
2. Click on the Advanced tab.
3. Please delete all the preferred networks then click on OK.
4. Right click on the Wireless icon again and click on View Available Wireless Networks.
5. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Please type in the Network Key and then confirm it.
6. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Networks.
5. Select your network and click on Connect.
6. If you have Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use Windows to configure my wireless networks" on the Wireless Networks tab.
Connecting to a Wireless Network on Windows Vista:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network's name or SSID and click Connect.
d. It will ask you for a network key. Type in your wireless network key on the field provided. Then, click on Connect.
Apr 02, 2009 | NetGear RangeMax WPN824 Router
Cannot connect to wifi from bt home hub any suggestions. laptop higrade 8615gtx
Could be a variety of reasons.
Assuming you have not had it working before
Assuming the wifi is broadcasting it SSID
Assuming you have laptop connected by ethernet cable to hub:
Assuming you have XP:
Go to start/control panel/network connections/right click the wireless lan icon and select properties/select wireless connections and delete ALL previous entries.
With Vista go:start globe then
Control Panel\Network and Sharing\Manage Wireless Networks and delete all entries
Now:
press windows key and R
type cmd and enter
type ipconfig and enter
note lower set of figures ie 192.168.0.1
open browser and type in those figures and enter
should now open router firmware
When asked for log in use defaults of admin - admin or admin - password
navigate to wireless security and set encryption to WEP 64bit and create a simple encryption code - save settings
Change broadcast channel to 8
make sure wifi is set to open and not shared
Save all settings, allow hub to reboot and now see what happens
Dec 10, 2008 | Computers & Internet
Reinsalled windows xp on toshiba notebook -- now wireless won't work.
Hi Matt,
When you try to connect wirelessly to your network did get any pop up message like asking you for a network key WPA/WEP? if your wireless network is security enabled then you need to enter the security settings again on the computer since you re-installed XP the security settings that was saved previously was also wiped out.
May I know the exact model number of wireless router/access point that your trying to connect your laptop so that I can provide you with instructions on how to retrieve the security key.
Nov 06, 2008 | Toshiba Satellite A45-S151 Notebook
D-Link AirPlus DI-524 Wireless Router Logo
113 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
