Microsoft Xbox 360 Console
Problem for Microsoft Xbox 360 Console
Xbox360
By cal222 on Dec 10, 2007
1 red light on console right hand bottom corner
Clarification Request
Posted by weedmanhustl on May 11, 2009
e73 error message just popped up and i never had internet hooked up or anything... any ideas?
Same Problem
May 14, 2009
-   i have xbox live(if it makes a diff) and the e 73 error pops up when i turn it on. what should i do?-   Guest
Mar 25, 2009
-   My xbox broke a couple days ago, so i messed with it and the red light went off, but every time i try to play a game the screen go's blank and i have to turn it off, it turns red sometimes but still works.-   skatingrulez
Feb 03, 2009
-   when I turn on my xbox ihave 1 red light blinking and it turns strait to a note saying error e73 -   mcluvin21
Jan 20, 2009
-   e73-   Guest
Nov 14, 2008
-   It says to go check on this it also shows a code E73.
-   Guest
Best Solution
posted on Dec 12, 2007
Helpful)
Quickie
Rank: Wiz
Rating: 82%, 84 votes
The Specific Type of hardware failure can be determined by the error code displayed on the screen.
If the screen is blank or you would like additional information follow the instructions for determining the secondary error code in the section below
E45: Unknown (possibly dashboard update related)
E64: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc.
E65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot.
E66: DVD Drive Error: DVD model, or version does not match that of the version expected by the dashboard. OR the firmware version on the drive is older then the firmware version expected by the dashboard. Make sure the DVD drive is of the same version originally included with the console and that it is using either the original firmware included with the console or newer.
E67: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E68: Voltage Error... This error means that the Xbox 360 has insufficent power to function properly. This can be caused by an error in the hard drive or the fans that make them suck up too much power, it can also be caused if you have unnecessary accessories attached to the console like an external fan unit. Attempt to remove unnecessary accessories first, and then necessary components such as the hard drive and USB devices. If you have any case mods you may want to investigate those as well.
E69: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E71: possibly a dashboard update error, Check below in the "Console Reset Codes" for instructions. If that does not work there is no other solution and the console must be sent back to MS for repair.
E72: (not yet known)
E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port.
E74: There is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In rare cases it is a problem with the GPU.
E76: This error deals with the Ethernet port's controller chip, a dead chip may not cause the error but removing the Ethernet controller chip does, it may also be caused by other Ethernet related problems.
E79: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it.
According to tmbinc: E79 is the error code if xam.xex could not be started, i.e. probably a file system corruption.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Feb 11, 2008
Somewhat Helpful)
shaunlisa
Rank: Apprentice
Rating: 73%, 4 votes
how can i fix e73
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Dec 10, 2007
Somewhat Helpful)
ctf1800
Rank: Wiz  Microsoft Expert
Rating: 85%, 4468 votes
http://forums.xbox-scene.com/index.php?showtopic=484726
Comments:
Dec 10, 2007
- why r u giving an inappropriate?
Was this helpful?
Yes
No
Solution #4
posted on Jan 30, 2009
Not Rated)
commings1799
Rank: Apprentice
Rating: 0%, 0 votes
call microsoft are stick two toothpicks in the back of the console so the fans can overheat. later, there will be two lights flashing and the fans will stop. when that happens unplug the following, power cable, AV cable, ethernet cable (if using one), and the hardrive. wait 5-10 minutes and plug everything back in and there you go its fixed. (only temporary and will only hold up for about 1-5 days
Was this helpful?
Yes
No
Popular Solutions for Microsoft Xbox 360 Console
Questions and Unsolved Problems for Microsoft Xbox 360 Console
Do you recommend Microsoft Xbox 360 Console?
Answer
Answer
I have the etheinet cable pluged into the motin but it wont conect to xboxlive
Answer
during game play my controllers quit working the console does not register that the controller has... (More)
Answer
i cant see the image on tv. i have sound but no picture.
Answer
do you have internet to play xbox 360 i just got it for christmas and cant get it to play
Answer
It wont play any games it just says open tray when i put a game in it clicks twice and says open... (More)
8 Other Users Have The Same Problem - Continued
Comment by perci, posted on Jun 22, 2008
e73
Comment by shaunlisa, posted on Feb 11, 2008
say system error at the bottom ov screen say e73 how can i fix it
Comment by becca19, posted on Jan 03, 2008
turned xbox 360 on and its coming up with system erorr and has 1 red light on right hand bottom side
Describe your Video Game Consoles problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
