Trying to recover my system with the recovery discs, but I continue to get an error code of 0x80070037 what does that mean?
This is a problem with your communication bus of serial Hard Drive is you are using one.
I would recommend you to go to http://www.hirensbootcd.net/ download it and run recovery off it really a good software and works well. Let me know if any other problem arises.
Posted on Sep 11, 2009
How to fix Error F3-f200-0002 on toshiba windows 7 laptop with recovery media on flash drive
If you still have your recovery partition that the computer came with you can do this:
1. Initially you keep hold the power button for around 5 to 10 seconds to turn off your system. Keep in mind that keep holding the power button force the system to turn off. But any of the unsaved data will be lost.
2. At the similar time press and keep hold the zero key simultaneously, now push the power button one time to switch on your system.
3. While the screen is get appeared then free the 0 key.
4. If it any message to select the 32bit or 64bit operating system then you click Next button.
5. When provoked by the warning screen; click on to the Yes button to keep continue with the system recovery.
6. In that choose Recovery of Factory Default Software from the menu and then hit it off on the Next.
7. Choose Recover to out-of-box state option from certain options and then click Next button once again.
8. Understand and recognize this final warning screen.
9. Now finally click Next to start recovery
Aug 31, 2015 | Toshiba Computers & Internet
How to do system recovery on compaq presario 5000 windows me
Starting a Recovery Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears. You can also start a recovery from recovery discs, or from Windows. For more information refer to Performing a Full System Recovery in Windows XP . Back to topRecovery is taking too long If your computer stops responding after using the recovery program, do the following:
NOTE: If the computer appears to have stopped responding after restarting from a recovery, please wait, it may take several hours or longer to complete the initial Windows XP setup process, especially if a recovery was run from a recovery disc set sent by HP. A Standard recovery may also take longer, depending on how many files are stored in user accounts (like in My Documents ).
  1. Exit the stalled recovery process by pressing the POWER button on the PC until the power turns off, this takes approximately five seconds.
  2. Before recovering, disconnect personal media drives, printers, scanners, cameras, camera-type memory cards, and other devices that did not originally come with the PC.
  3. If you are using recovery discs, be aware of the following items:
    • If you created the recovery discs using Recovery CD Creator, be sure to run the recovery from the same drive that you used to create the discs.
    • Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
    • You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
  4. Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
  5. If the recovery stops when recovering from the hard drive, use the section Disc errors occur during the recovery process to eliminate errors on the drive. Try recovering again after the disk errors are removed.
Jan 13, 2011 | Compaq Presario 5000 PC Desktop
I have a Sony Vaio VGN-N130G. It crashed and I am trying to get it to reboot from the recovery disc but after the first disc starts the Complete C drive thing it stops and says ERROR 400 and can't...
Make sure that the operating System on the recovery CDs is the same as the one on your computer.
If you are trying to recover from a CD with Vista and your computer operating system is Win-XP that will not work.
Other Thing may be you had a hidden partition and some how you over written it or it is damaged.
check the hard disk partition stat.
Nov 27, 2009 | Sony VAIO VGN-N130G/W Notebook
Recovery Error 320
I had error 305: 69 when I tried to repair my sony vgn-ns160d using the recovery disc1. I called sony support and they told me that me hard drive was defective and needed to be replaced. they did not want to send me new recovery discs beause I was out of warranty. I copied the recovery disc at slow speed on another computer and tried rebooting the sony laptop with my fresh copy of the recovery disc. and it WORKED! it was not my HD that was defective it was their recovery disc! sonys support is non existent! trying to sell me a new hard drive!
Jul 07, 2009 | Sony VAIO VGN-NR498E/S Notebook PC
Recovery error 320 on sony vaio laptop
Ketanvasu your an idiot....If he's trying to recover the laptop obviously the thing isn't working...so how the hell is he supposed to burn cd's genius?
May 09, 2009 | Sony VAIO VGN-NR498E/S Notebook PC
Unable to recover my system
u need to fix error on harddisk.
u can fix those error with "chkdsk /r"
command
Mar 25, 2009 | HP Compaq Presario C304NR Notebook
Recovery Disc not working
Is that recovery disc created in ur machine or not...
Nov 30, 2008 | Toshiba Satellite L15-S104 Notebook
Computers & Internet Logo
137 people viewed this question
David Payne
David Payne
