Question about RCA D52W19 52" Rear Projection Television
TOSHIBA 61 REAR PROJECTION TV
Not powering up. Light on power button blinks.
    Genius:
  • 1,030 Answers
Shutdown. this set processor has detected one of many problems. first thing to always try is unplug the set for about 30 min and plug back in.. if it does it again. then the set has a safty cuicit problem. could be one of 25 problems. high voltage. data. there is a way a tech can read error codes. that the processor has generate ...any sounds or smells?
Posted on Dec 10, 2007
Why is power light blinking
is it yellow as it blinks or red? if yellow check the kill switch located at the base of the lamp compartment cover ensure it presses the switch lever in order to ser the tv to standby mode the yellow blinking will stop and u will see a stable red ready for switching on
Jul 19, 2013 | Toshiba 61H71 61" Rear Projection...
Shuts off power light blinks
This is a very common problem among Toshiba & Mitsubishi RP TV's. It is caused by the circuit boards not communication with each other. The fix is about $600-700 with labor, parts, etc. I would suggest getting an LCD or LED TV.
Nov 28, 2010 | Toshiba 61H70 61" Rear Projection...
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
Toshiba Rear Projection TV Problem
common problems on toshiba are the stk ic and it is not ease to replace them you will need a technician
Sep 15, 2008 | Toshiba TZ50V51 50" Rear Projection...
Tv wont power up
if you can not turn on TV set with the power button on the TV its not astandby problem as this would by pass the standby. Theres most protec,on a set of this age, top have a poiwer regulator,vertical,horzontal/chcroma problem and is goingto need a trained tech to assist you in this repair. www.afiata.com
Aug 01, 2008 | RCA D61W20 61" Rear Projection Television
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
BLINKING POWER LIGHT AND TV DOES NOT POWER ON
I have a toshiba 61 inch projection tv the power light flashes with no picture any easy fixes?
Jun 24, 2008 | Toshiba TP61G90 61" Rear Projection...
Toshiba is one of the few sets that do not have a diagnosis feature built into the power light , Toshiba has to be able to light the screen to access its self diagnosis features. So you will most likely need the service manual to check the voltages in order to properly diagnose your set. You can get a service manual at the following link, and they will email it to you if you would like. here is the link.
http://servicemanuals.vstore.ca/
Feb 09, 2008 | Toshiba 61HX70 61" Rear Projection...
Toshiba 61' cinema series rear projector
check for loose connections and or bad convergence amp ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
good luck
please mark the post with a fixya!
Feb 07, 2008 | Toshiba 61H71 61" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
35 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
