Question about Canon imageCLASS MF5750 All-In-One Laser Printer
Feeding problem we are unable to take out the copy or print as the m/c scans but the main motor is not turned ON
SOURCE: Brother MFC 240 C Scan problem
yeah,, help!
Posted on Oct 19, 2008
  • 413 Answers
SOURCE: Message appears on printer display: Sanner Failure - Unable to scan or copy
Install all the software on the installation cd.
Posted on May 29, 2009
komguy
  • 2306 Answers
SOURCE: canon pixma mp780 auto feed does not print
You probably need a new printhead, but that problem cann also be caused by the purge or cleaning station not working properly. If you do a cleaning cycle with no carts. and the little pads in the printhead come back with no ink on them then the purge is working and you need a new printhead.
Posted on Aug 24, 2009
Riztech
  • 731 Answers
SOURCE: iseMY Hp all in one 4355 printer is unable to scan
The HP Officejet 4355 can print, scan, copy and fax.
You need to install the printer software to print and scan. Copy and faxing does not required software installation.
Regards,
Rizwan
Posted on Feb 11, 2010
Dicedonions
  • 118 Answers
SOURCE: I'm unable to get the scanning and copy output on samsung series
turn on/off, unplug, plug in2_bing.gif, should reset configs.
go to applications folder for your computer, dbl click printer icon for make of printer/scanner/copy. check settings. if all else fails, select printer reset button in settings page.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Posted on Apr 29, 2010
How do I get rid of the lines when I make copies. It dose not happen if I print a scan
If you are using the ADF ( automatic document feed ) for your copies, raise the scanner cover and clean the strip window to the left of the main platen. If you are using the platen for copies and getting lines where scans are clean - you have a physical issue and it should be checked out by a technician.
Apr 22, 2015 | Canon Pixma Mx882 Mx 882 Photo All-in-one...
Tip
ERROR codes Canon 4540
Canon 4540 E00 Low fuser temperature E001 High fuser temperature E010 Main motor clock pulse E011 Bind or load on main motor E020 No TF for 3 minutes E030 Copy counter E050 Duplex unit E201 Scan motor E203 Scan motor E210 Lens home E240 DC controller E241 DC controller E320 CCD E400 DC controller, 24V E500 DC controller, 24V E510 Finisher feed motor E520 Stacker motor E530 Guide plate shift motor E531 Stapler motor E620 DC controller, edit board
on Jan 19, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 4035
Canon 4035 E000 Low fuser temperature E001 High fuser temperature E010 Main motor clock pulse E011 Bind or load on main motor E020 No TF for 3 minutes E030 Copy counter E050 Duplex unit E201 Scan motor E203 Scan motor E210 Lens home E240 DC controller E241 DC controller E320 CCD E400 DC controller, 24V E500 DC controller, 24V E510 Finisher feed motor E520 Stacker motor E530 Guide plate shift motor E531 Stapler motor E620 DC controller, edit board
on Jan 18, 2010 | Office Equipment & Supplies
I have brother DCP 7055 it shows print unable 71 error pls suggest
This is due to Polygon Motor Error in the Laser Unit.
Pls try one of these:
1. Input the correction value of the laser unit correctly.
2. Check the harness connection of the laser unit. Try re-connect them.
3. Replace main PCB Assembly.
4. Replace the laser unit.
Mar 02, 2015 | Brother Dcp-7055 Laser Print Copy Scan...
Unable to print 36
Possible Reason:
1. High voltage power supply PCB
failure
---Replace the high voltage power supply
PCB ASSY.
2. Harness connection failure of high
---Check the harness connection of the high
voltage power supply PCB and reconnect
it.
3. Main PCB failure
---Replace the main PCB ASSY.
Aug 08, 2014 | Brother Dcp-7055 Laser Print Copy Scan...
I have brother DCP 7055 it shows print unable 72 & some time it show 71 error pls suggest
Dec 18, 2012 | Brother Dcp-7055 Laser Print Copy Scan...
Printer works fine, but when scanning to copy or scanning to fax a line appears right down the middle of the either the outgoing fax or the printed copy. This when using the feed from the top of the...
If it only happens when you copy or fax, as opposed to 'printing"...clean the scanner glass -both the main glass and the narrow **** glass on the left side.
Please rate me.
Mar 31, 2009 | Dell 1815dn All-In-One Laser Printer
Ink system has fail. unable to copy receive faxes, or print. Refer to printer documentation. Error: 0xc18a001
i can not feed paper at all or copy to paper but i can scan files to my computer how can i fix this
Mar 01, 2009 | HP Photosmart 3210 Printer
No paper feed (brother MCF-440CN)
Had a similar problem with the MFC-885cw. Turns out that , if you have a photo paper tray installed which sits just above the main tray, you need to puill it all the way back towards you otherwise it blocks the paper feed. Not the best design feature I've ever seen.
Feb 20, 2009 | Brother MFC-440CN InkJet Printer
Canon imageCLASS MF5750 All-In-One Laser Printer Logo
26 people viewed this question
old marine
old marine
