Question about Garden
Where can i get hold of replacement parts for my ryobi expand it straight shaft strimmer
scrodamoon
  • 659 Answers
SOURCE: Strimmer Line
rotate the starter pulley by hand. You should feel the spring getting tight. Once the pulley is slightly tensioned, usually 5-10 turns, release the pulley and let is pull the string onto the pulley. You may have to add some tension to get all the rope to wind on the pulley.
Posted on Oct 04, 2008
  • 1341 Answers
SOURCE: Do I need Special grease for Brushcutter/Trimmer shaft
No grease is grease but there is sillicone used nowadays as it just looks clean to use. Now check if it does use some kind of oil in the system.
Posted on Aug 03, 2009
SOURCE: Manual - Ryobi RLT30CES strimmer
Try this one:
http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Cheers
Nigel
Posted on Sep 10, 2009
Testimonial: "Thanks. Got it."
bbreton
  • 437 Answers
SOURCE: how do i replace a shaft for ryobi whipper snipper
I never heard it called a whipper snipper before but I am on this side of the ocean. you should be able to go to www.ryobiuk.com. Put in your model number and you should find a parts list for it.
HTH
Good Day. mate
Posted on Oct 28, 2009
rycgl
  • 1545 Answers
SOURCE: Ryobi PBC 3046YE strimmer starts but cuts out when speed control
A lack of acceleration in these units is most likely a fuel delivery related issue. It may possibly be time for a diaghram kit or carb rebuild kit to be installed in your carburetor. Ethanol in the gas deteriorates the parts that accomplish the acceleration procedure and may need to be replaced as they don't function anymore.
Many other things can affect these little machines as well such as clogged air filters, clogged crank case vent, clogged mufflers/exhaust ports./ spark arrestor screens...but more often than not, your problem is a carburetor issue.
Please look at the troubleshooting section on this Zama site PDF file
http://zamacarb.com/pdfs/TechGuide_2007.pdf
Posted on Jul 10, 2010
When I try to strim the line on my ryobi 1830h13 keeps wrapping itself on the interior shaft of the strimmer, .and it's very difficult to get out
Your blade on the shield is either gone or dull and not cutting the string off to the right length as it turns.
Aug 12, 2016 | Ryobi Garden
Can you help
Sounds like the cable in the upper shaft is broken. Start it without the attachments installed and see if the cable is turning.
Sep 01, 2014 | Garden
Ryobi line strimmer hedge cutter attachment won't cut even though the blades are moving can you give any idea what he problem might be?
grass,string or vines can get wound around the motors shaft, you will need to take off the spinning head to remove debris from motors shaft
Jul 25, 2014 | Ryobi Garden
Husqvarna 128LD Starter Recoil Issue
Here is the complete Illustrated Parts List. It has exploded views of the whole strimmer.
Jul 20, 2013 | Husqvarna 128LD 28cc 2-Stroke Gas-Powered...
I inherited this trimmer and do not know how to add new string. There isn't any kind of a manual that we can find. The trimmer is a RYOBI 137R. Thank you.
hi i have a ryobi rlt 30cd strimmer and when i was useing it it just stopped it as fuel in it but ive cleaned the carb but i still cant get it to run as any one got any ideas thanks
Jul 15, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
I have a Ryobi RLT 30CESA with the strimmer attachment. What do I need to fit a Brushcutter blade to it
I would not put a brushcutter blade on this unit. The curved shaft quik disconnect may not hold up to the shock torque created by the brushblade. It may damage the drive shaft since it is a curved shaft quik disconnect model. You may have to purchase a straight shaft trimmer to get that job done.
Oct 02, 2009 | Garden
RLT30HT 30CC PETROL STRIMMER difficult to start
The plug that I have in my 720r is a Champion RDJ7Y. Can I suggest that you pull the old plug out and look to see which one you have? Also when you buy the new replacement it should already be gapped for what you need.
Jul 27, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My new Ryobi boggs down/ stalls as soon as I pull on the trigger.
You should have 2 small adjuster screws next to each other on top of the carb.Try adjusting each of them a little with a thin screwdriver as the engine is running.Put strimmer on the ground first and adjust screws while you are revving engine until it runs correctly.Trial and error and very small adjustments can make quite a difference.Hope this helps.
Jun 12, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
61 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
