Question about Onkyo DR-C500 Multi-disc DVD Player
Tray won't open
I have the same problem as described. I opened the case, which was easy and removed a disc, but it appeares there is another problem. Either there is another disc stuck inside or there is a mechanical problem. It SOUNDS like there is a disc that I can not see, or the arm that pushes the drawer oper is broken because the drawer won't open and when the carosel turns , something is rubbing on it.
    Scholar:
  • 151 Answers
Have a professional open it up to check so not to further damage the device. If you want to do it your self, you can open it up, just make sure your warranty is not void by doing so...
A possibility is that the tray has a lodged cd in it...
Posted on Dec 10, 2007
  • Chris Montano
    Chris Montano Dec 11, 2007
    Oh and there are some players with rubber guides at the reading end, sometimes it comes loose and lodge in...
My ps3game console will not take games
If you mean it won't load from a game disc I've had this problem with mine. It was an older ps3 with a lot of hours on it. I would clean the laser lens with a q-tip and rubbing alcohol. When the lens gets too dirty it can't read the disc. I tried laser lens cleaning discs (I know they recommend not using them or touching the laser lens for that matter) they worked a couple of times but usually wouldn't. I had to disassemble my old 80gb or actually just open the case unplug 2 connections from the disc player and remove it. Then take the metal case off the disc player. DO NOT pop the disc player completely apart! The plastic gears in the drive and ejection system have to be in time. Not quite so easy to fix. With the metal case removed you can reach the lens or lenses (there are 2 one is for blue ray I believe) with a cotton swab dipped in rubbing alcohol to clean it. This worked for me at least a dozen times if not 2 dozen.
Nov 29, 2014 | Sony Playstation 3 (PS3) Console
My ibm intellistation z pro: nothing appears on the screen no ibm sign at start up no nothing also if i try to open the disk drive it won't open which seems weird
maybe a disc stuck in the drive? if you pull down outter door of disc drive (unless you can see the front of the disc tray already) there is a tiny hole on front of disc tray, large enough to get a paper clip wire into, that will release the tray and pop it open
Mar 06, 2013 | Computers & Internet
Xbox360 disc tray motor won't stop spinning
Hi Matt,
Here is the process for troubleshooting this specific issue:
  • First remove your disc from the tray. I assume you have already done this.
  • Ensure your faceplate (the front of your system) is on correctly. Sometimes these can become loose and off kilter. Press the two edges firmly with your hands and "push" it into place.
  • Push the eject button. Although it hasn't worked in the past, adjusting the faceplate may correct the issue.
  • If that doesn't work, move the disc tray drive gently from left to right when it is open. Again, be gentle-- what we're trying to do here is slightly adjust the disc tray in case it isn't entering your system properly.
Still not working? Time to send it to Microsoft for repair. You can find all of that information on their official support site. Click here for more details.
Hope that helps!
Feb 10, 2012 | Microsoft Xbox 360 Console
My dell 1645 disc drive won't open , I burnt a
There should ba a tiny hole on the front of the tray cover on the drive.
Switch off, get a paper clip or something about the same thickness and insert it carefully in to the hole, push it in until the tray opens.
Jan 08, 2012 | Dell Computers & Internet
Sony rdr-hx720 tray won't open and says traylocked?
The disc tray does not open and you cannot remove the disc after you press Z (open/close). ,Turn off the recorder. Once the clock appears in the front panel display, disconnect the mains lead. (If the recorder does not turn off or if the clock does not appear in the front panel display, disconnect the mains lead anyway.) Connect the mains lead again while pressing down A on the recorder, and release the button when the disc tray opens. Then, keep [/1 on the recorder pressed for about ten seconds until "WELCOME" appears in the front panel display
Oct 08, 2011 | Televison & Video
Im trying to change the rear brake pads on my car but im unable to remove the claiper due to the build up of rust on the outer edge of the disc. Is there a way to open up the pads to gain enough clearance...
Yes, if you can get a flat screwdriver in between the back of the brake rotor and the brake pad you can pry against the pad & caliper piston to depress it. It will be easier if you open the bleeder on the caliper to let the fluid escape with less force.
I hope this helps.
Aug 24, 2011 | Mini Cooper Cars & Trucks
DVD drawer won't open after playing a film. Film plays fine, but now we can't get the darn DVD out!
Disc have something sticky attached on top (label ,specially rental discs') so when you try to eject disc get stuck on tray of spindle motor.Top cover need to be opened in that case in order to remove disc
Aug 23, 2011 | ESA E4000 DVD Player/VCR
Disc tray will not open. I've turned on &off several times and it won`t open the tray. tries to but won`t open
This problem is caused by a loose drive belt in the eject mechanism, you need to open the ps2 and replace the drive belt...
Take off the top cover, then take off the cover from the top of the dvd drive mech... then carefully remove the disc tray and you should see the belt near the front. Replace that belt and it should work fine again
On a couple of rare occasions the drive motor has been found to be faulty, but usually replacing the belt will fix it
Jan 25, 2011 | Sony PlayStation 2 (PS2) Console
"open tray" appears on screen
try sliding your finger were the disc goes in and once you do that it MAY OR MAY NOT work. it worked for me.
Nov 20, 2010 | Microsoft Xbox 360 Console
Describe your Harman Kardon CDR30 2-Disc CD Recorder Problem It's a CDR26 and neither of the drawers will open.
With mine, it was the drive belts for the cd drawers, which were stretched and rigid. Open the case. Remove the 4 screws that hold down each cd drive. Push the drives out enough so you can pull the silver facing off the sliding try by pulling it up. Now you can lift out the cd drives, removing all the connectors as you go. Flip the white plastic slider underneath each drive and you can mechanically open the slide tray. This reveals the little motor and rubber pulley belt that operates the slide tray. If the belts are broken, perished, rigid or something, get something similar from your local electronics parts store (a couple of bucks each belt), and reassemble.
Feb 11, 2010 | Harman Kardon CDR30 2-Disc CD Recorder
Onkyo DR-C500 Multi-disc DVD Player Logo
559 people viewed this question
Top Onkyo Televison & Video Experts
Steve
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
