Question about GE Profile DPXH46EA Electric Dryer
Electronic ED54 dryer makes continual beep sound with no LED's illuminated or flashing.
  • 1 more comment
  • nicky_keys Sep 11, 2009
    The dryer make is a Fisher & Paykel ED54-F
    The dryer may have been subjected to an excessive amount of moisture. If it is left over night in a well ventilated area it will possibly run again without a problem.
COLEMAN INVERTER PMP1200 JUST BEEPS WHEN TURNED ON
It is most likely the low voltage alarm. Suggest connecting when the car is running with no load (110 volts not connected). If the alarm continues turn the unit off and on to reset.
Hope this helps?
Inverter Protection Features
• Short Circuit Protection. The inverter will automatically shut down until short is removed.
• Low Voltage Alarm. An alarm will sound when the voltage from the battery discharges to 10.5 +/- 0.5 volts DC. This is an indication that the battery needs to be recharged.
• Over Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input exceeds 16.5 +/- 1 volt DC.
• Under Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input is less than 10.0 +/- 0.5 volts DC.
• Overload Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the continuous draw of the equipment being operated exceeds 1200 watts or the surge draw of the equipment exceeds 2400 watts.
• Thermal Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the circuit temperature exceeds 150° F
Sep 13, 2016 | Electronics - Others
My Electrolux EDV 605clothes dryer is turning but not heating, heating element is ok possible faulty thermistor, dryer heats up when thermistor is unplugged but has an error code of 5 beeps
I think you're absolutely right exhaust sensor is faulty.
The buzzer will give 5 beeps, all program LEDs will flash for 5 seconds and the dryer will continue with the cycle. The warning beeps and flashing LEDs will occur every 30 seconds.
On Timer Drying programs it will run for the time remaining and in Sensor Drying programs it will run for 90 minutes. As the exhaust air temperature can not be sensed the element will be cycled on and off at a preset amount. The cycling time of the element will vary depending on the amount of time remaining.
NOTE: When this fault exists the dryer can still be used but regardless of the Sensor Drying program selected the dryer will use the 90 minute Timer Drying program, Timer Drying programs will use the selected program, and with both types of programs the element will cycle as above. The buzzer will also still be sounding.
If an exhaust sensor fault is detected the buzzer will beep and the Reminder Clean the Filter LED will flash. The LED flashes at different rates depending what is wrong with the sensor -
Fast (4 per second) = open circuit senor, broken wiring or multi pin plug not correctly fitted to the control board.
Slow (2 per second) = Short circuit in sensor or wiring.
The sensor resistance at different temperatures is as shown below.
Temperature (Celsius) Resistence (Ohms)
55 2960
50 3570
45 4330
40 5280
35 6490
30 8030
25 10000
20 12555
15 15880
10 20260
5 26080
0 33870
As you can see this is NTC thermistor with Negative Temperature Coefficient , means if temperature increasing the resistance decreasing.
Dado
Jul 06, 2015 | Electrolux Dryers
Why is my dryer beeping and showing E60?
The last alarm code memorized can be displayed even if the appliance is in normal operating mode (e.g. while the drying programme is being performed): - Press (start/pause) and first option button simultaneously for at least 5 seconds: the display shows the last alarm.The alarm sequence continues to flash as long as the two buttons are held down.
The appliance continues the cycle while the alarm codes are being displayed. If the appliance is in programme selection mode, the options previously selected are stored in memory.
E60 is family fault code but after reading last alarm you will see exactly fault code (E61; E62; E63)
E61 - Insufficient heating (maximum time exceeded)
  • Heater unit faulty
  • Wiring faulty
  • NTC sensor incorrectly calibrated/out of position
  • Electronic board faulty
E62 - Power reley to heater unit faulty
  • Wiring faulty
E63 - Intervention of auto-reset thermostat on the heater unit
  • Thermostat faulty (replace heater unit)
  • Wiring faulty
Dado
May 10, 2014 | AEG T57800 Electric Dryer
Fisher and paykel ED54
check door switch
Nov 29, 2013 | Dryers
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Dec 08, 2011 | APC Smart-UPS SC 1500VA UPS System
Forgot the combination to the lock. Is there a way to retrieve the combination or return it to its factory default combination 1, 2, 3, 4, 5
The instructions below are copied from the programming instructions (page 11):
ERASE ALL PROGRAMMING
(The "out of box" factory default will be restored)
1. At the back of the lock, remove the screw at the bottom of
the lock housing and remove the cover.
2. Take out the battery pack and remove battery power by disconnecting
the battery pack.
3. Plug in the (provided) male shunt connector into the yellow
wire female connector.
4. With shunt connector connected, re-connect the battery
pack. The lock will immediately sound 3 short beeps (if
these 3 beeps are not heard, then restart at step 2).
5. The lock will then sound more slow beeps, 1 beep for every
second it takes to clear the memory.
6. After a few more seconds, the LED will slowly alternate between
flashing red and green--disconnect the yellow wire
shunt connector.
7. The LED will continue to slowly flash green and red for 25
seconds. To enroll Function Cards, proceed immediately
as follows:
• With the lock LED slowly alternating between flashing
red and green, present the Function Card #1
to the lock. The lock will sound 5 slow beeps.
• The lock LED will flash green rapidly. The lock is
ready to enroll the Function Cards.
• Re-present Function Card #1 to the lock. The
lock LED will flash green then red, with two beeps
(indicating the card was enrolled successfully).
• Present Function Card #2 to the lock. Again, the
lock LED will flash green then red, with two beeps.
• Continue to present, in order, Function Cards 3-
9. Each time a new Function Card is presented, the
After the 9th Function card is presented, the lock LED will flash
green twice, sound two beeps, and will then remain silent,
ready for use. Note: If the lock continues to beep after presenting
the 9th Function Card, check to verify that the yellow
wire shunt is disconnected.
Note: If you only wish to use the first 3 Function Cards, simply
allow the lock to "time out" after 30 seconds.
Here is the link to the complete instructions, in PDF form. You will need Adobe Acrobat or equivalent to view them:
http://napcosecurity.com/download/PL3000_WI1280A.04_PROG.pdf
Good luck-and please provide feedback if this helps!
Nov 04, 2011 | Trilogy ALARM LOCK PL3000 Series T3 Prox...
Hi My F&P dryer (model ED54) is making a continuous sound on plug it in....no lights etc turn on...just one long and continous BEEP!!....Help
You dryers "Brain" the microprocessor, sounds like it has had a power spike, or spontaneous failure. You are going to need to get a "Quote" for a fix from a reputable repair centre/man
Feb 02, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Strange noise comes out from the ups after a power cut
The Back-UPS Office unit has five different tones or alarms:
1. Four beeps every 30 seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery Power Supplied outlets are now supplying battery power as opposed to power from the utility. If the UPS determines that the input utility power is unsafe for your computer equipment, the UPS will switch to battery power.
Note: If the power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will be illuminated)
This alarm indicates that a Low Battery condition has been reached and that the UPS will soon shutdown. Once the UPS transfers to On Battery operation, it can only stay on battery for a limited amount of time. The UPS will sound this alarm about two minutes before the batteries are totally exhausted. Once exhausted, the UPS will shutdown and turn off its output power to your equipment. If you hear this tone you should immediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overload condition after it has performed a self-test during start-up.
This alarm indicates a severe Overload was detected while the unit was on-battery operation. This tone will continue to sound until the unit shuts down.
5. Continuous Tone (On Battery LED will be flashing)
This alarm indicates that the battery-powered outlets are overloaded.
6. Continuous Tone (On Line and On Battery LEDs flashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault has occurred.
Jan 06, 2010 | APC Back-UPS ES 700 - UPS ( external ) -...
GE Profile DPXH46EA Electric Dryer Logo
141 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
