Dell 922 , out of papper
I have Dell 922 printer, I have recently changed the cartridges but still it disply the message to change the cartridges.(empty cartridge sign) Also my paper feeder not working properly, a message always pops up 'OUT OF PAPPER' even there are enough pappers on the tray. I have to feed one by one manually to get print outs.
Dell 3110 printer error message 093-922 -- I have changed the black cartridge and error is still on display panel.
Try turning your printer off, wait 10 seconds, then turn it on again and see if the problem persists.
Mar 04, 2010 | Dell 3110cn Laser Printer
I have a Dell 948, displaying missing toner cartridge or low toner, I have replaced the cartridge several times and still get this message. Any ideas?
dcruger
It is possible that you did not get the cartridge changed out properly. The link below will help you go through the process to make sure you got it changed out properly.
http://www.fixya.com/support/r4460452-replace_ink_cartridges_dell_all_in_one
Let me know if you have any more problem or questions
Issken
Nov 10, 2009 | Dell 922 All-In-One InkJet Printer
Check k cartridge 093-922
Could be
Bad chip on the cartridge
Some toner on chip contacts
Chip NOT been replaced (if its an remanufactured cartridge)
Jun 08, 2009 | Dell 3110cn Laser Printer
How to change ink cartridge in dell 922 all in one printer
Here is a link for the user manual in PDF for your printer:
922 AIO Manual
Replacement of cartridges begins on page 44 of the manual.
Thanks for using Fixya.
Apr 22, 2009 | Dell 922 All-In-One InkJet Printer
Printer Always Indicates Ink is Low or Cartridge is Incorrect
To get rid of the low ink warnings google the specific error message with 'ink refill' and look for 'engineers reset' or similar ..
NB. Dell printers (re-badged Lexmarks) are notorious for ink usage and high costs .. so my best recommendation would be to throw it away and purchase something else ..
Nov 30, 2008 | Dell 922 All-In-One InkJet Printer
New cartridge
Clean the copper contacts of the cart and reset back in the printer and if your getting the same error message please replace the cart with another cart .......
May 13, 2008 | Dell 922 All-In-One InkJet Printer
I get message carrier stall - error 1200
Try this 1.Disconnect power to printer 2. Force the cartridges to the left and then to the right 3. Clean at the transparent strip behind the cartrigde holder (Encoder strip) Be careful not to pull on the strip Hope this helps.....
Oct 08, 2007 | Dell 922 All-In-One InkJet Printer
Dell 922
TRY UNPLUGGING PRINTER FROM WALL AND PLUUGING IT BACK UP allow cartridges to unlock lubricate you carrige bar with 3in 1 oil while it is off the carrige bar is the silver bar the ink cartridge assembly travel along use only two or three drops of oil.
Oct 07, 2007 | Dell 924 All-in-One InkJet Printer
jasbo
jasbo
