Question about Toshiba Satellite M45-S265 Notebook
Toshiba Laptop - Dim Screen
Hello All.
I have a Toshiba Laptop, and the screen went Dim, so the only way to view it is to hook it up to a television with the S-Video Cable.
Can someone please give me a list of possible problems and the amounts that it would cost?
Toshiba Laptop Satellite M50 Model: PSM50C - YK400E Serial: 75123001K
Thankyou
    Sergeant:
  • 310 Answers
Hey, sounds like the back lights in the laptop are faulty, if it is backlights you should be able to see the whole picture but will be hard to see and dull.
Heres one website that sells them, aint sure if its the cheapest place, last time i think i was about £80 for them. which is alot of money but depends on the laptop make etc.
http://www.laptoprepair.co.uk/laptop-backlight-problem-dim-screen.html
Have a nice Christmas when it comes,,
John
Posted on Dec 10, 2007
Lcd screen went gray and would not work
I would bet that the power supply for the LCD is sending too much power. There is nothing you can do to fix that, but replace the screen, or the motherboard.
Dec 01, 2013 | Toshiba Satellite Laptop Coretm Intel...
Dim screen
sounds like your backlight inverter or lamp has failed. It is worth fixing if you can find someone to do it for a reasonable price. It isn't something I would recommend trying yourself unless you have laptop repair experience. If you just want to purchase a new laptop, you can put your old one on Ebay or Craigslist. I can assure you someone will buy it as is.
Sep 24, 2012 | Sony VAIO VPC-EH11FX/B Laptop Black
I have a Gateway 450ROG with very dim video on the display, I can hook up an external monitor and the video on the external monitor is fine but still very dimvideo on the monitor of the laptop. You can...
Hello !
Since an external monitor works, it is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
In either case, a technician in your area should be able to help. Evaluate to see if the repair is cost-effective.
Hope this helps.
Oct 26, 2010 | Gateway 450ROG Notebook
Toshiba screen is blank ans light on under F10 key.
Is the screen completely blank, or just dim? If it is dim, then most likely your lcd power inverter is bad, and needs to be replaced, which is the cheapest part to replace. If it is completely blank then you should try to hook up an external monitor to the laptop, and don't get any video, then most likely there is an issue with your motherboard or video card. The external monitor method sometimes needs you to press a combination of the Fn key and another F key in order to switch from your laptop lcd to an external monitor.
Feb 06, 2010 | Toshiba Satellite A105 Notebook
I have a Toshiba Satellite A55-S1063 the scrren is dim but I can still see using a flashlight. I have had the back light replaced once it worked great for about 2 weeks and then went back to being very...
Hello !
Since the screen is dim, the display's inverter board needs to be replaced.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation, the inverter would be indicated.
Hope this helps.
Dec 01, 2009 | Toshiba Satellite A55-S1063 Notebook
My Toshiba Satellite A105 screen comes on for a little bit, flickers and then shuts off. However I can faintly see the screen, and the laptop works fine when hooked up to the external monitor. Wondering...
If you can still view screen if you view it in an angle or spot a flashlight on screen. Then, definitely it is a problem on backlighting, might be loose connection, inverter giving up or cfl giving up.
Hope this helps
Nov 06, 2009 | Toshiba Satellite A105 Notebook
I have a toshiba hd theare view tv. The other day
Hi
did you notice the standby light? or blinking lights? and how many blinks as you see?
Thanks!
Jul 08, 2009 | Toshiba 55H70 55" Rear Projection...
Screen Brightness gone too low on toshiba satellite 1110 laptop
Hello Tim,
Sorry to answer u by this news :
this problem u have happening by 2 cases ..
1st Case :::: that's maybe ur screen lamps is broken ..so u can see the data but very dark or no Back-light .. so u will need to replace the screen..or advanced option but with expret person to change the lamps from another broken sceen,,
2nd Case ::::: The high-voltage board..it's small board built below the screen to give the screen the right voltage to light on .. so u will need to replace it also ..or Advanced option also but with expert electronic person to check it ..
best luck.
Dec 01, 2008 | Toshiba Satellite 1115-S103 Notebook
Open Questions:
See all Toshiba Satellite M45-S265 Notebook Questions
Toshiba Satellite M45-S265 Notebook Logo
981 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
