Question about Compaq Presario CQ60-220US PC Laptop
Help! Compaq Laptop "Plugged in,Battery Not Charging"
Help! My compaq laptop cq 60 is 2 mos. old and has a problem. tells me plugged in but battery not charging.the adapter is lite up etc.. yet battery isnt charging. then on occassion it will start charging. i have no clue here. please help!
    Welcome Back:
    Visited the website for 2 consecutive days.
I had the same problem on my CQ60. HP battery test showed one or more cells not working. After spending about 2 hours talking to some guy in India,or somewhere, he came to the conclusion that my battery was bad. HP sent me a new battery, which fixed the problem.
kenbun
Posted on Dec 13, 2009
My laptop stopped charging at 16% and showed power plugged sign and light showing at the plug terminal but no charging
Posted on Nov 30, 2009
I have a Compaq Presario CQ20 my original battery is going low so I buy a new battery. When I using new battery it show plugged in, not charging. But when I use old one it is charging. Please help me to solve the problems.
Posted on Feb 26, 2012
  • 21 Answers
The problem could also be the power cord. A friend of mine was complaining her HP CQ60 wouldn't charge unless she jiggled the plug connection at the laptop. She thought it was the battery and ordered another one but found it was still not charging correctly. I looked at it and confirmed that the cord had one loose connection at the barrel plug.
If it is the power cord you could purchase a new one or repair it like I did below:
The cord can be fixed by slicing a concentric circle around the plug about a 1/2 inch down from the rubber end and then peeling it off to expose the two wires. I found one wire broken from the solder joint and thus not getting a good connection. I drilled a small hole into the metal barrel to make a better contact and then re-soldered the wire into the hole. I then super glued the concentric section I sliced off and then put a piece of 1/2" 2:1 heat shrink tubing ($1.25 on eBay) around it and shrank it around the repair. It's fixed and due to the black heat shrink tubing, you can barely tell it was repaired. Hope this helps!
Posted on Nov 09, 2011
    Scholar:
  • 53 Answers
Cable from AC adapter to PC is damaged or solder junctions of DC-In connector on the motherboard is cracked, or faulty DC-In connector. Is Power LED on the laptop is on as well as LED on adapter when battery is NOT charging?
Posted on Sep 11, 2009
  • kashif_farid
    kashif_farid Oct 11, 2012
    dear i have the same problem. my compaq presario cq60 says plugged in not charging. i have replaced adapter. it worked for 1 day. but after that it says the same thing. i have adopted all procedures discussed on internet. but i works for some time but starts again.
Compaq presario cq62, plugged in but won't charge battery
The rechargeable battery needs to be replaced, the old one is just about exhausted. Go to www.ebay.com Type: make and model of laptop, refine search to battery, and I recommend sticking with new genuine.
May 04, 2012 | Compaq Presario CQ62-112TU
We have a compaq presario cq 60 bought in Canada and it's about 3 years old. Until yesterday, the computer battery would hold a charge for about 45 minutes (yes, we know we will have to replace the...
You need to replace your old battery. Don't over charged your battery. If you are using your laptop in your house it is better not to use it with battery. Just use the power adaptor/supply only. Then make sure you will drain the battery let say once a week. =)
Jul 13, 2011 | Compaq Presario CQ60-220US PC Laptop
I have compaq notebook pc...using vista... my battery was working perfectly fine. suddenly, now when i plug in. it says, 0% available , plugged in not charging. i have tried uninstalling and then...
how old is the laptop?
either your battery has developed a fault or the laptop connectors have developed a fault therefore not registering the battery output.
also check the ac adapter.
Jul 09, 2010 | Compaq Presario Notebook
Battery problem with HP Compaq Presario V2000 laptop
When batteries fail, they usually lose the cells inside them, which means that the cell is no longer able to function as a holding cell for power and therefore cannot do its job anymore, when a battery fails to hold and refuses charging it is bad and needs to be recycled. The flashing is telling you to purchase a new battery. The larger the number of cells in the battery, the longer and better it will perfrom,,RE: 6 cell, 9 cell, 12 cell.
Jan 13, 2010 | HP Compaq Presario V2000 Notebook
Battery does not charge
Will the old battery (that you are replacing) charge up at all? If the old battery charges but the new battery will not, then it's likely a bad replacement battery.
To rule out the possibility of a corrupted battery meter inside of windows, you may wish to leave the laptop on battery power only, until it dies. A 5% charge will usually only grant you about 20 minutes of laptop life maximum. Since you left it charging all night, you should get a few hours of life before it dies. If you get a few hours of life, the battery meter software is corrupted.
Most likely though, the replacement battery is bad.
Sep 02, 2009 | HP Compaq Evo n610c Notebook
Compaq presario shut down while plugged in
Greetings my friend, regarding on your problem try to remove your battery then clean it and after you clean insert it back. then used the power connector and insert it in the DC plug and wait for 5 - 10 mins before you turn on your laptop. In that way the battery is already charging then try also to touch the battery of the laptop if it is charging or not by touching the battery and when it warms meaning it charge otherwise it is not charging. Then if your findings are true that your battery are not charging then try to test it with tester so that you check the status of your battery.
Jun 16, 2009 | HP Compaq Presario C306US Notebook
In my compaq laptop CQ 40 330 TU,there is no charging of battery when it is turned off. Kindly suggest as soon as possible.
my laptop is not charging. when i inserted the power cable, it is showing as charging, after a minute, it is saying that it is not changing
Apr 17, 2009 | Computers & Internet
Problem with power, plugged in, not charging
For just such occasions, I recommend that everyone have a low-cost multimeter at home. They are versatile and give you the features for measuring AC/DC voltage (which is what you need), resistance and a few current ranges.  They cost less than $20 US at Radio Shack or auto parts stores or if near a Harbor Freight Tool store, underr $10 US.
You need to verify if you have any voltage from your adapter/charger and whether the battery pack is still intact (they have thermal fuses inside).
The meters come with an adequate Chinglish basic instruction sheet and leads and battery.
Apr 01, 2009 | Compaq Presario CQ60-220US PC Laptop
Compaq Presario CQ60-220US PC Laptop Logo
8,424 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
