Question about HP Compaq nc6000 Notebook
Usb won't work
Usb doesn't recognize the device, if it doesn't have a power suppy, ie wacom tablet, disk reader. external hard drives with power suppys work.
    Sergeant:
  • 310 Answers
Hi, its because the usb ports have not enough power to, power on the device completely. Can you comfirm the unrecognized devices are plugged directly into the laptop and not into a usb hub, also if you go into control panel and into device manager, look up the Universal Serial Bus Controllers, Go into USB ROOT Hub for each one and into properties for them, Power Management and make sure there are no ticks.
Have a nice christmas
John
Posted on Dec 10, 2007
My Windows 7 cannot recognize my Sata/usb connector
USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced. Hope this helps.
b>
Jan 04, 2013 | Apricorn SATA Wire 3.0 - storage...
External hard drive won't boot up.
As virtualhost said, maybe you have not initialize this disk and partition it. Additional to disk mgmt, you could use this software
Sep 11, 2012 | Buffalo Technology (USA), INC. - 500GB...
My toshiba external harddrive usb 3.0 won't work
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
hope this helps you
Sep 18, 2011 | Toshiba Notebooks Canvio E05a075cau3xw 750...
It makes a clicking noise, it doesn't light up, and it's not detected by my computer.
you might have a dirty hard drive if the click noise is coming from inside your hard drive the reader arm is skipping across the platters or might be trying to connect but cant find the drive causing a clicking noise you could give the hard drive a firm tap to the side to free up up the reader arm
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Sep 16, 2011 | Seagate FreeAgent Pro 1TB External USB...
My HP DV9740Us entertainment laptop will only recognize one external hard drive at a time! If i plug in another via usb it won't pick it up in My computer but the computer makes the sound as if it did...
If these drives are internally powered by the USB hub, two devices will not be recognised. ie: you can have as many pendrives as you like and they will be seen, because they draw little power from the hub, however, a larger external hard drive requires more power (some of these in fact have two usb connectors to power them). which is why your laptop will only recognise one drive at a time:
Solution: If you can get an externally powered usb drive, this should work.Another and possibly cheaper way would be to get an externally powered USB hub, which would solve the problem
Jul 28, 2011 | HP Pavilion DV9740US Laptop
MY COMPUTER WON'T RECOGNIZE MY EXTERNAL HARD
if your computer came with a motherboard disk the drivers could be on it
hope this helps
Jul 03, 2011 | Toshiba Computers & Internet
Drive is not working. When you turn it on the blue light lights up but then goes off. The red light on the back stays on but the CPU does not recognize it. I have changed USB ports but it still doesn't...
please right click computer then Manager under storage, click Disk management. if you see you usb drive there, simply right click on it and format to exfat. fat32,or ntfs. if it doesn't show up, it pretty much shows that it needs an upgrade.
May 08, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
External hard drive is not detected
Check Following Instructions:
1. Check your USB cable properly connected to the computer.
2. Go to My computer - right click on property - Hardware - Devices Manager - in below - USB Mass storage device - right click on this - and Uninstall - then again right click - click on Scan - it should be reload your USB drivers
your External Hard Drive will be detected
Apr 25, 2010 | Seagate USB 2.0 External Enclosure + 400GB...
My computer suddenly won't recognize my wacom tablet--the blue power light doesn't even flash when I plug it in. I think it's a problem with my computer rather than my actual tablet, as the tablet...
Make sure driver is installed and there is not any ? mark or yellow ! mark in device manager.
Reinstall your tablet driver then check.
Uninstall all usb driver from computer.
Connect your tablet to computer then when you power up the computer press F8 key then enter in safe mode.
Make sure usb cable is works fine if you connect your tablet to computer with usb cable.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 07, 2009 | Wacom Computers & Internet
SeagateFree Agent Go 120 G.B external portable hard drive When I connect that in to my lap top (HP Pavilion) windows can recognize the hard drive and once I connect that same one in to my desktop windows...
you will need to install the drivers for your drive.
xp doesn;t recognize 2.0 usb unless you install drivers and have a usb 2.0 port
but install the drivers and you should get it to recognize
you can go to control panel, system and device manager.
look for a usb device that is not working and right click install drivers or update drivers.
See if it comes up.
Once it does you will see it in the device manager under disk drives
Jun 05, 2009 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
HP Compaq nc6000 Notebook Logo
149 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
