Question about Intermec EasyCoder® PF4i Label Printer
Cannot boot printer, after a few minutes display "time-out" messagge
Clearing a Print System Failure on the HP Photosmart C6150 All in One Printer
Try the below steps to bypass the error.
1) Press * and # at the same time
2) Press 1, 2, 3 and "support R0632M" should display
3) Press > and "information menu" should display
4) Press > and "configuration menu" should display
5) Press OK and "hardware failure status" should display
6) Press OK "failure status: clear". Press OK to clear
7) Press CANCEL
8) Press CANCEL
9) Press CANCEL
10) Turn printer off, unplug power cord for 2 minutes, plug cord back in then turn printer back on.
You may need to repeat the above a few times as the error can change.
Aug 04, 2013 | HP PhotoSmart Office Equipment & Supplies
Most of the time while I'm switching on it, power led does glow, HDD Led glows once and also can here the spinning sound of Processor fan but there is no display and after few seconds it will restart. if...
two solutions:
1- use a cooling hardware. maybe your laptop hangs because of high Temprature.
2- VGA of your laptop almost destroyed !!(sorry damaged).
so you can only take your laptop to a guarantee center.
Jan 10, 2011 | Compaq Presario F572US Notebook PC
Replaced cartridge (black) but low-ink light on printer still flashing and printer won't print
Have you reset the printer? If not, follow the instructions;
Remove the cartridges, disconnect the usb, switch off, unplug the power chord, leave it off for few minutes. Again switch it On without the cartridges installed and without usb cable connected to it, press the power button several times while it boots up, and leave it on for few minutes, again shut it down using the power button and install the cartridges, connect the usb cable and restart your printer. This will fix your problem if there isn't internal/system failure/faulty.
Good luck.
Thanks for using FixYa.
Jun 22, 2010 | HP DeskJet 6840 InkJet Printer
The messagge keeps showing on scene- cartridge error
evidently the driver disc you got with your all in 1. are corrupt drivers and need to be updated at hp.com good luck
Nov 22, 2009 | HP Officejet 5610 All-In-One InkJet...
Samsung CLP-300, Replace transferbelt messagge on smart panel. Did replace with new,still same message. prints counts did not reset (60002)
you press menu until setup is displayed, right arrow until maint. is displayed. right arrow until check others is displayed. right arrow until transfer belt is displayed, press enter and it will ask count? or reset? choose reset, press enter. press stop to return to main menu...should be done!
Sep 15, 2009 | Samsung CLP 300 Laser Printer
"cover open" messagge when cover is closed
This is the problem the cover switch in the printer you need to replace the switch this switch is very difficult to find in the printer is usually hidden ,you need to check the cover there will be a projection in the cover which will go into a slot thats where the switch is located
Sep 16, 2008 | Lexmark X3480 All-In-One Printer
Xerox 8200 will not boot
If it takes a long time to cycle, then shuts down. I suspect the drum heaters are defective.
Best way to find that out is, turn off yout room lights, then turn the machine on.
There is a fan exaust on the right side of the printer where there are sloted openings.
When you turn the machine, look in that fan slot and see if you see lights inside the printer. There should be a candesent type of glow you see about 20 seconds to a minute after you turn on the machine. Leave it on for a couple of minutes, but if you see no lights the heater or heaters are bad. They are standard 120 volt 150 watt halogen lamps. Tricky to change. But it can be done.
Dec 28, 2007 | Xerox 8200/DP Thermal Printer
Display
Something's wrong with the Video. That's obvious.
Could be Resolution (too High), Refresh (off), Other Video (TV Out) at time of boot.
Try, removing TV Video, if you're using, so it's not there at time of boot. I've had that problem, I had to break the connection, that means if you want TV Out, you must Shut Down, recconnect and reboot.
I've had problems with the others too, Resolution and Refresh Rate.
Good Luck,
Dec 27, 2007 | EliteGroup P4VMM2 Motherboard
Not printing
It's a great idea! In fact i tried to do that only one thousand times...and the messagge is always the same!!!
Oct 10, 2007 | HP PSC 2175 All-In-One InkJet Printer
Intermec EasyCoder® PF4i Label Printer Logo
216 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
