Question about Sony Ericsson Walkman® W995 Cell Phone
Hi there my phone has come up with no network coverage and wont let me into my contats but will let me in any other file on the menu !! it wont ring out or accept incommin calls let alone txts . i have tried to update the software and update the phone in general but still nuffin what can i do to fix this ??
    President:
  • 1,952 Answers
Install anti virus
Posted on Sep 11, 2009
  • w995 Mar 31, 2011
    If you still want to repair you W995, please email me at dickson.chui@360.com
No network coverage
when a phone is showing no network coverage, there are possible ways you could look into,
Network setting in the phone.
Re-formatting the phone or flashing it.
Hardware repair.
In your phone you can check the network setting on your phone if it has been tampered with you so can easily reset it.
Some times when a phone drops in water or on the flow, and after then was not serviced might cause the network reception to fluctuate .Some application downloads,Dirts or malfunction of the phone can also cause a phone s network to disappear.
So you can service the phone by taking it to a repair shop and tell them you would like to service the phone for better service.
Hardware repair, can also be checked only when the other options did not give the solution. You will have to take that to a repair shop, to prevent more damage of the phone. It needs professional handling .
Take care.
May 19, 2010 | Nokia E63 Cell Phone
I cant manually activate my blackberry pearl I went to options, mobile network but all it says is roaming.
See if this works....
-Press menu key
-Click OPTIONS
-Select Mobile Network
-Click on "START PROVISIONING"
It should give you a message saying: PROVISIONING COMPLETED SUCCESFULLY.
You wont need a MSL code if you do it this way.
Nov 13, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
Sony C902 shows No Network Coverage
Mine did it today :-( first said i had a message coming and that i need to delete some files then restarted itself and now i have no network and i cant access my contacts.
Sep 16, 2009 | Sony Ericsson Cyber-shot C902 Cellular...
No network coverage?!
OK i have just fixed my W995 that also came up with No network coverage out of the blue. Also when i went to charge it it said i needed a SE battery.
All this problem is, software. Yes simply all your phone needs is a software update. Sony Ericsson are known for disconnecting peoples phones if they do not have the latest software.
Go to http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/w995?lc=is&cc=is
Should solve your problem. It did for me:)
Aug 13, 2009 | Sony Ericsson Walkman® W995 Cell Phone
My mobile N70 failed to find network and show 3g in place of network tower
there may not be any problem at all ,
as 3g is notorious for sometimes bad and very patchy network coverage ,so it may be a network problem rather than your phone
i know a few people who have similar issues with all ranges off phones from nokia,sony erricson,samsung blackberries etc.
if problem persists ring 3g from a land line to find out about the network coverage and if they have known issues/problems
May 19, 2009 | Nokia N70 Cellular Phone
Motorola U9 - irritating noise
Found it myself. I was looking in the settings for ring tones/alerts and all along this little feature was hiding in the Networks menu. It's a simple thing to have set on or off and for some reason after repair my phone was returned with this setting switched to on. It's an alert to let you know when there is no network coverage and the phone is searching. All well and good but very irritating if you live in a poor signal area!
Apr 28, 2009 | Motorola Mobility MOTO U9 Pink Cellular...
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
K850i says no network coverage constantly.
stixLFC hello,
Try to manually define the network by going to Main menu - Settings - Connectivity - Cellular networks - Search Mode - Manual - there, choose the right network.
Oct 25, 2008 | Sony Ericsson K850i Mobile Phone
Network problem
Try manually selecting your network. Where are you located?
Jun 28, 2008 | Sony Ericsson W600i Cellular Phone
Change the amount of times it rings before goes to V-mail
In Coverage path form for voice mail
COVERAGE CRITERIA
Don't Answer? y y Number of Rings: 2
COVERAGE POINTS
Point1: h2 Rng: 1
you can change Number of rings,Rng options
Jan 17, 2008 | NorStar T7316E Corded Phone
Sony Ericsson Walkman® W995 Cell Phone Logo
103 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
