Question about Sony Handycam CCD-TR517 Camcorder
Sony CCD-TR51 8mm Camcorder
I am unable to open the cassette compartment. When I push on the eject button nothing happens. No sounds just a blinking 'eject symbol' flashes in the screen.
  • Anonymous Apr 25, 2008
    Same problem
  • 196 Answers
SOURCE: PLEASE HELP!! Sony Handycam CCD-TRV37
The problem is usually caused by no drum rotation. Have it serviced.
Posted on Feb 13, 2006
ctf1800
  • 4402 Answers
SOURCE: inserted cassete in wrong way in Sony camcorder CCDTRV68, not ejecting cassette Error codeC32:20
Sony camcorders C:31:23 error
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
good luck
please mark the post with a fixya
Posted on Mar 17, 2008
SOURCE: camcorder cassette holder stuck/won't eject
Try taking the battery out...
Posted on Jun 30, 2008
SOURCE: I have a Sony Handy CAM 8 CCD-FX310. It will
I had the same problem with a Sony FX410, not much different than a FX310. With my camera all i had to do was to push the top down with a gentle push, it would engage and play and record normal. Don't force it hard, just a light pressure to help the cradle down. Most of these Sony cameras are crappy when it comes to loading the tape, most if not all the Sony's i've had end up with this problem, no matter what model you have. I've taken my camera competely apart and could not find the problem for not pulling down the tape, don't know if it can be a sensor or what, i never could find anything broken or loose or misalign, i oiled all the joints and moving parts with a light dab of thin oil, it worked fine except for that darn cradle not pulling down the tape.
Another thing that causes this is when the tape is to tight? In other words the tape should have a slight **** in it, i once ran into this big problem when the tape would not load and the camera kept ejecting it over and over. It was when i tried a new tape that i noticed how well it loaded yet the other tape wouldn't load. So i pulled out the tape and poked that little hole on the back right below the left hand pick up reel, i then turned the reel with my finger and gave it some slack, not much just enough to see the tape a little loose. I then reloaded the tape and it worked like a charm, seems that if the tape if to tight the camera won't accept it as the reels need to adjust back and forth for a few seconds, its that wacky sound you hear when you load a tape, seems like it has to adjust the tention inside the take up reels. Hope this might help you some?
Posted on Nov 30, 2010
Testimonial: "Seemed to work for a bt"
SOURCE: loading tapes
Sony HDR models that the carriage won't close is caused by the mode switch on the chassis. The mode switch controls the cameras function for loading and loading of the cassette. Basically tells the electronics what is happening. This becomes dirty and causes the chassis not to complete it's cycle on eject. Thus staying open. It has no idea where the mechanism is at this time. It can be cleaned and realigned but the chassis needs to be removed to get at it. Definitely a service depot repair. Sorry!
Posted on May 02, 2011
HELP, I have borrowed an older camcorder from a friend. A sony Hi8 CCD-TR101 handycam. My child put the tape in backwards and now it wont eject. What should I do??
Tape can not be inserted backward in.It is impossible to to insert cassette inside video wrong way.
If it is not ejecting its eject switch might have got broken by physically pulling its cassette compartment outward before closing last time.
Its mini switch is very fragile in all sony models. so only way is to take to technician to bring it out.If i were you,I would buy used one from ebay at lower price than repairing.
May 07, 2010 | Sony Handycam CCD-TR87 Camcorder
Can not eject
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
Aug 11, 2009 | Sony Handycam CCD-TRV318 Camcorder
The cassette is stuck and the player will not eject it. when you turn it on it just makes a beeping noise.
Aug 11, 2009 | Sony Hi8 CCD-TRV138 Camcorder
Sony ccd trv218e, recording & playing back does'nt work
I had that problem also and I found that using smaller tapes helped. I was using the 120 minute tapes, I think they may be too heavy.
Feb 13, 2009 | Sony Handycam CCD-TRV21 Camcorder
Tape will not eject
a small spring (eject spring) is getting dam or missplace due to that you having the problem
Nov 11, 2008 | Sony Handycam CCD-TRV58 Camcorder
Can not eject tape
I had same problem, while transferring media from TRV-16 to DVD, tape would not play, then would not eject. This after transferring several tapes to DVD. I tried several things over the last couple months that did not work before finally getting it open today. It did me no good to remove several of the outer panels that were each held by two "tiny" phillips head screws each. Went to the internet, found your post, also found a post that referred me back to SONY page which follows.......
"NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required."
After I did this, I could hear a whirring sound when I hit eject, although nothing came out. While the whirring was going on, I pulled up and out with constant pressure and the cassette holder opened. The tape had jammed apparently as the little protective plastic tape guard was jammed partially open when I pulled the cassette out. Good Luck and don't be afraid to put a little pressure on the door if you can hear the door trying to open.
Now I turn to recovering the tape, but having grown up with cassette decks, don't believe it will be a problem.
Oct 14, 2008 | Sony Handycam CCD-TR416 Camcorder
CCD-TRV68 hi-8 cam
Unit may have damaged loader mechanism, have it checked
May 13, 2008 | Sony Handycam CCD-TRV68 Camcorder
Sony Handycam DCR-TRV19E Pal do not eject tape
I think, your camera requires new DV Mechanism replacement.
May 08, 2008 | Sony Handycam DCR-TRV33 Mini DV Digital...
Inserted cassete in wrong way in Sony camcorder CCDTRV68, not ejecting cassette Error codeC32:20
good luck
Dec 24, 2007 | Sony Handycam CCD-TRV68 Camcorder
Cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Jun 18, 2007 | Sony Handycam CCD-TRV107E Camcorder
Sony Handycam CCD-TR517 Camcorder Logo
414 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
