Question about HP Md5880n 58 in. HDTV
TV shuts down
My HP m6580n shuts down after 1-3 hours. No warning lights or error message. TV flickers a little before shutting down. Picture looks great otherwise.
  • paul r Dec 20, 2007
    I have the EXACT SAME problem.
    HP tech support said that this may be due to an old bulb, but they weren't sure.
In response to the "Guest" post on 12/21/07, first, thanks for your reply. Yes, I agree that it's potentially a thermal issue, given that the longer it's on, the more often it happens. However, I have never gotten temperature warning lights to come on in relation to this issue. (Maybe the temperature sensor is broken.) I have a new bulb coming tomorrow, so I can see if that fixes things. If not, the next thing will be for me to pull off the back panel and vaccuum everything out to see if the heat sinks have gotten dirty (and therefore, less effective).
HP said they would allow me to return the bulb within 21 days, so it doesn't cost me anything to try the new bulb.
I'll put up another post with my results later.
- Paul
Posted on Dec 21, 2007
  • paul r Dec 30, 2007
    I recently received a new bulb for my HP Pavillion md5880n TV. After replacing the bulb, the flickering and random shut downs stopped. After 4 days of heavy usage, I have seen no repeat of these problems.
    Jim4: buy a new bulb and see if your problems go away. If they don't, HP will allow you to return your bulb within 21 days of purchase. Be aware the bulb costs $350.
Stating the obvious, I suppose, but it may be possible that the TV is simply overheating. These giant TVs create a LOT of heat. Perhaps removing it from your current TV cabinet and setting it on a stand outside will help. You may even want to try a small fan to blow air to the back of the machine to see if this fixes the issue.
If so, and it's under warranty, I'd have a tech look at it. May be replacement parts that won't run as hot.
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but af
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
Mar 07, 2013 | Televison & Video
Tip
Automatically Close Programs at Shutdown
When you shut down Windows, if you have any programs running you'll get a message box warning you that a program is still running. You then have to close the program and tell XP again to shut down. It's a fairly pointless warning—better yet would be if XP automatically killed the programs without issuing the warning. That way, you wouldn't get error messages and wouldn't have to close each individual application before shutting down your computer.
To have XP automatically close programs at shutdown, run the Registry Editor and go to HKEY_CURRENT_USER\Control Panel\Desktop. Edit the AutoEndTasks key so that is has a value of 1. If the key doesn't exist, create it as a DWORD value and give it the value of 1. To disable it, either delete the key, or set the value to 0.
on Mar 17, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Tv keeps shutting off without warning
Hope Bob C does not mean computer_Bob who used to be a expert here.
To address your question:
If no error blink code exists (power light or other blinks a specific number of blinks) it likely is a issue in the power supply of the set which usually will give an error blink code of some type.
Common failure reasons include but not limited to:
Lamp
Ballast
Dirt
Yes, dirt inside (dust to be kind) will trigger shutdown etc.
A lamp will usually before it fails give some indication like a dimmer picture but dirty fans and dust inside can also do this.
In our shop if it is dirty inside first thing is it goes out the door and gets a good dose of compressed air--usually looks like a dust storm.
Lamp life is on average 2,000 hours (average user it is 2 years) and generic lamps have a lesser life.
Ballast usually is suspect if several lamps have failed in a shorter period of time but can just fail.
These are my thoughts from working on this and similar sets--what have you tried so far?
Apr 30, 2012 | Sony KDF46E2000 46" Projection HDTV
Replaced the bulb but tv continues to shut down
radadtoo,
My wd 62525 was acting the same way. Then after a couple days, started flickering and scrambling the picture. I found neals solution # 2 at this link and replaced a few capacitors and 4 hours later, its all fixed!
Here is the link, scroll down to solution # 2 to get an idea of what the caps and boards look like.
http://www.fixya.com/support/t155026-flickering_blue_picture#SameProblemContinued
Any bad capacitor will be oozing out of the top or just bulging on top. And this took a little time and patience to do. Be sure to label all your connectors and screws.. It really helps
Jun 06, 2010 | Mitsubishi WD-52631 52" Projection HDTV
After turning on TV, lamp light blinks but no picture
IF IT SHUTS DOWN TO STANDBY, THEN DIGITAL BAORD IS BAD, IF IT JUST KEEPS CYCLING ON/OFF THEN YOU NEED A POWER SUPPLY, BALLAST AND PROBABLY LAMP
Dec 30, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Hp 6735s wont shut down
using the button to shut it down is not recomended, but if you do not have programs running that is loading/saving data, it should be ok, in some cases it could damage the computer, you should see if it is under worrenty and get it looked at or call tech support and see if they can help
Sep 28, 2009 | HP Compaq 6735s Notebook
Mitsubishi HC900 Projector shuts down after 5 minutes.
You have 1 of 2 possible problems.
(1) You need a new lamp.
(2) You have an overheating problem.
Just a quick couple of notes about your projector. It is a DLP projector (not LCD) and as such the machine as no air filters to clean. It does have air intake and air exhaust grilles, but no air filters to clean. This next part comes directly from the owner' manual for your projector:
When the lamp operation time exceeds 2000 hours*1 *2, the projector automatically shuts off and can’t be used until the lamp is replaced and the lamp operation time is reset.
Your machine is designed to give visual warning messages at 1500 hours used, and 1900 hours used. Did you see any visual warning about lamp life over the past few months?
If you were experiencing an overheating problem, a "TEMPERATURE!!" message would flash up on the screen just before the unit shuts down. If there is no warning, you don't have a heat problem.
If you have a replacement lamp available, install it and reset the lmap hours according to your user manual. If you don't have the manual, google it on the web (it available).
Apr 01, 2009 | Mitsubishi HC900 Multimedia Projector
KDS-R60XBR1 Sony Projection SXRD
The lamp may be starting to go, the symptoms you describe are classic warning signs. You could unplug tv let it cool down and check lamp most likely the glass will not look clear maybe a little milky or smoky in areas..dead give away.
Mar 07, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Projection TV keeps shutting down
Good Day;
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Error message
My plasma display the "error message condition 1" and red flashing light start blinking and TV screen shut down. Who can halp me to fix the problem??
Jul 03, 2008 | Fujitsu Plasmavision PDS-4221 42 in....
HP Md5880n 58 in. HDTV Logo
322 people viewed this question
Top HP Televison & Video Experts
Computer Links
vbalag
Level 1 Expert
Alun Cox
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
