Question about Whirlpool SB160PEE Gas Single Oven
Gas stove works, but oven does not
Nothing happens when I turn my oven on. The heat source at the bottom does not come on and there's no gas odor. However, the gas stove still works fine, so I know that the gas supply is working. The electricity is fine because the digital display works. Please advise. Thanks in advance!
  • 10 more comments
  • Anonymous Dec 27, 2007
    I have a Whirlpool gas stove,model SF375EEZ0, Ser# RH1611157. My oven will not start. I want to take a step by step approach to find the cause of failure. I have a simple volt/ohm meter. if that is useful. The top burners' igniters work fine. I am wondering if the problem is 95% caused by the oven igniter and whether I should simply replace the igniter as a first step?
  • Anonymous Dec 28, 2007
    same problem Mod# sf315pew3
  • macman80 Jan 06, 2008
    The Oven does not come on all the time, the broiler works all the time. I checked the igniter connection and see 120 volts on it. It seems the igniter will work when I wiggle the wire. I can't locate any break in the wires going to the igniter glow plug. I swapped the broiler glow plug with oven and the broiler still works fine and the oven is still intermittent???? Any suggestions? I will try to measure the ressistence to the glow plug and see what happens.
    FYI...The gas valve will not open until the glow plug is fully hot to ignite any residual gas. If the glow plug has an open circuit the gas will not turn on. Safety feature.
  • airscott61 Jun 24, 2008
    Gas range works, oven doesn't come on. We have a touch screen on the backsplash, all the "buttons" work, and act like it always has. We adjust the temp. and press "start" and the screen comes up with "preheat", but the oven never comes on. No heat, no gas. There is a faint buzzing noise for a few seconds, then it stops.
  • Anonymous Aug 26, 2008
    top of stove works but the oven does not
  • acorbett Oct 16, 2008
    gas oven does not come on on the bottom. glow plug does come on. broiler works fine as does top of is a kenmore
  • Anonymous Nov 02, 2008
    no pilot light. Over and broiler works. NO gas odor. ? WHY
  • r1lewis1 Nov 18, 2008
    My Gas stove works, my oven does not. I think the pilot light is out but can't seem to re-light it.
  • Anonymous Nov 27, 2008
    oven will not bake but range works fine.
  • Anonymous Dec 31, 2008
    Gas stove works but oven does not. When I turn on the oven there is a slight smell of gas but no heat.When I look at the broiler, there is a small flame. Stove top worrks just fine
  • artbizconst Jan 07, 2009
    Ignitor is on but the oven willn't come on
  • mygnratn Feb 03, 2009
    Gas stove works, but none of the display will light up therefore can not use oven...anyone else have this problem??
  • 109 Answers
Yes replace the ignitor, this is the most common failures of ovens not coming on.
Posted on Mar 30, 2008
  • Patricia Foster
    Patricia Foster Aug 07, 2014
    I have replaced the ignitor and the safety valve. When the oven lights fire comes out the sides of the broiler. Then it shuts off after about 5 minutes. Help
2 Suggested Answers
  • 135 Answers
SOURCE: Gas stove works, but oven does not
you most likely have a bad oven ignitor...if you see an orange glow under the oven panel that is your ignitor trying to come on....but if it is weak it will not open the gas valve.....acess the ignitor and replace it
Posted on Jul 30, 2008
I have a Hot Point Gas Stove my burners all turn on but when I turn on oven nothing seems to happen
If you have a pilotless model it is very likely that your oven igniter is bad. This is fairly easy to replace. A contunuity check will show if the igniter is bad.
Nov 25, 2013 | Stoves Ovens
I have a Maytag Advanced Cooking System (Super Capacity) gas stove. The oven takes an incredible amount of time to preheat & then smell an odor of gas. What could be wrong?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
Jan 04, 2011 | Maytag Ovens
Gas stove When I turn on the oven, I smell gas,
This is more than likely the igniter to be sure you will need to do an amp draw on the igniter. To do this watch the video on troubleshooting a gas oven at
Mar 12, 2010 | Stoves Ovens
GE Gas built in oven Model JRS14 will not heat up
The bake ignitor has failed.Turn off the gas supply. Remove the racks. Then remove the bottom pan cover in the oven to access the ignitor. Place a amp meter on one wire of the ignitor.Turn the BAKE switch on. If it reads less than 3 amps,replace the ignitor.
Oct 30, 2009 | GE 24" Built-In Single Gas Wall Oven
Kenmore gas oven won't heat up
If your ignitor is coming on that means the oven control is supplying the power to the ignitor and gas valve. So the gas valve is ok because it is allowing for a complete circuit so what the heck is wrong? The ignitor MUST draw 3.5 amps in order to open the gas safety and allow the gas to come out. The ignitor must be very bright, if it is dim then it is bad. (MORE)
Jan 18, 2009 | Whirlpool SB160PEE Gas Single Oven
Oven - Very bad gas smell
Very Dangerous! turn off supply to appliance, supply ventalation and call service tech. If you are very familiar with gas appliances and know what you are doing then you can try to locate the leak using soapy water or leak detector liquid. make sure all flames and other possible sources of ignition have been eliminated. Keep room well ventilated. Spray leack detector on all fittings and look for leaks replace or tighten parts as needed. This responce is asuming you have not blown up already, seriously dangerous situation you have there.
Jan 07, 2009 | Ovens
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
Gas Odor coming from oven
The reason you can't smell it when the oven is on is because the gas is being ignited. DO NOT USE YOUR STOVE until you get this fixed by a gas fitter. You have a gas leak, which is either a loose fitting or faulty valve or line.
Call your appliance dealer IMMEDIATELY or you could have an explosion!!!!
Sep 06, 2008 | Ovens
Jul 30, 2008 | Frigidaire FGB24S5A Gas Single Oven
Whirlpool oven model sf315peew Super cap 465
try the broiler if it lights then replace the oven ignighter in the bottom under the bottom plate of the oven cavity reply if the broiler doesn't light
Jan 30, 2008 | Ovens
Whirlpool SB160PEE Gas Single Oven Logo
3,811 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
