Question about Krups Small Appliances Espresso Machine
Hi Have a Krups Compact Expresseria Pro (xp7240). Produces hot water and steam. Can not get the water to flow on the coffee making cycle. Makes all the right noises but no water?
I have the same problem now....how did yoy solve your problem?
Posted on Nov 14, 2010
My Krups xp4050 no longer makes steam or hot coffee
I assume there is a power 'On' light. If it is lit and no hot water is produced... the odds are the heating element is blown. If No 'Power On light' then change the fuse in the mains plug.... simples
May 17, 2014 | Krups XP4030 Espresso Machine
Problem with Krups XP7240
The hose connected to the heating element has unattached or is leaking.
Sep 03, 2017 | Krups Small Appliances Espresso Machine
Water shoots out of steam valve and can't make espresso
Samantha,
The steam function and the expresso use the same elements to create the steam but the valves will direct the steam to the expresso unit or the steam arm. Most likely you have a faulty valve. In most cases the valve will not open until the pressure gets to the right level. If you are just getting hot water out of the steam arm instead of steam via the expresso unit it most likely means that the valve is faulty. The valves can be replaced but is not easy. You will need to have the unit serviced or you could try to replace the valves. Make sure the flow meter is working before you replace the valves. You can check the operation of the flow meter by running the hot water cycle and making sure that you get the right amount of hot water. Good luck!
Nov 21, 2011 | Krups XP2070 10 cup Coffee Maker/15 bar...
Makes a bang sound and spit sout steam
Try first to pour out some hot water first from steam wand and then try to make coffee.
Jun 30, 2010 | Krups Small Appliances Espresso Machine
KRUPS XP7240 leaking water
My XP7240 has the same problem. I went through all cleaning cycles and the filter in the boiler still gets clogged up with coffee oils. This causes back pressure and blows the boiler seal out. Easy replacement if you can turn a screw driver.
Part number for Seal: MS-5015004. You might as well change the Jack too. (the part that slides into the boiler that compresses the ground coffee. (this is a redesigned double seal unit) Part Number MS-0697072.
Both these parts you can get at http://www.krups.com/Tools/Contact/Contact.htm choose your country and email the parts list. Mine cost in Australia $27.00 including shipping.
Good luck.
May 31, 2010 | Krups Small Appliances Espresso Machine
My xp7240 has also started leaking water from beneath the machine
the distribuitor as down!
its dificult to substitute. maybe find an expert its a good option for this case.
Jul 02, 2009 | Krups Small Appliances Espresso Machine
Krups xp7230, no water running through nozzles
Yes, you're machine is identical to the xp7240. Look up the post on leaking xp7240 and follow the instructions on how to open the machine and fix the valve.
Jan 06, 2009 | Krups XP7230 Compact Super Automatic...
XP7240 has stopped ectracting milk from canister,just blows steam
Do not push steam nozzle to much on the dispenser. Just pull it back 1mm or something. If pushed to the end there is no ejection and milk is not extraced fro the canister.
Oct 01, 2008 | Krups Small Appliances Espresso Machine
Krups FME2 will not flow water.
Does it sound like it is boiling water at all?
If it is boiling, but not giving hot water, then the one-way valve is stuck.
If it is not getting hot (on the soleplate base) then usually the element has blown.
These machines use the steam generated by boiling as a means to move the water up - like a geyser, and need the heat to move the water.
Replacement elements are available, and the valves usually just require cleaning.
Jun 29, 2008 | Krups FME2 Coffee Maker
Krups Small Appliances Espresso Machine Logo
404 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
