Question about Sony VPL CX5 Multimedia Projector
Projector wont switch on. - Sony VPL CX5 Multimedia Projector
  • 2,237 Answers
If there are no leds lit on the top, then the power supply is bad (check the fuse on it first). if there are leds lit, which ones, what color, and are they flashing, and how many times? this will tell you the problem.
Posted on Sep 11, 2009
Testimonial: "Sony Projector: No LEDS on, unable to locate any fuse. Partially disassembled projector. No access to power input socket or assembly. On/off switch it"
Brookstone pocket projector wont turn off
i'm having the same issue. it 1st started with a No Signal error. then this started...ugh!
Feb 10, 2014 | Brookstone Pocket Projector for iPhone 4...
Infocus 4805, wont power up remotely
the lamp has burned ot and needs replaced,
Nov 25, 2007 | InFocus ScreenPlay 4805 Multimedia...
Wont see projector
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 19, 2012 | Dell Latitude D630 Laptop Computer PC...
Plc-xu30 wont power up
Switching of Projector within few seconds ??!!
This problem is common when Projector lamp is not replaced with that of the same band & model but one can fool the projector lamp as it powered with logic switching ...0 V or 5 V set by its company ...
Go through following Web :
http://www.diy-community.de/forumdisplay.php?f=60
http://www.allinbox.com/modding.htm
http://www.dity.nl/forum/lampen/442-...qi-lampen.html
http://recklessphilosophers.com/2008...ad-of-300.aspx
Jun 20, 2012 | Sanyo PLC XU33 Multimedia Projector
I changed the bulb and the power lights wont come on
Certain Mitsubishi projectors have a built in bulb life timer, and are programmed to not allow a projector to power on unless the bulb is replaced and the bulb life timer is reset. Its a simple process:
1) Make sure your projector is plugged in.
2) Make sure the main power switch is on.
3) Hold the left arrow, right arrow, and power button on the control panel of the projector (not remote) for 3-5 seconds.
4) Release...
This will reset the bulb life timer to 0000 and allow for normal power up barring any other unforeseen issues.
Mar 07, 2011 | Mitsubishi HC3000U Multimedia Projector
I had a bulb burn replaced both bulbs worked for a couple of days but now it wont power up only lamp1 light blinking. I have tried taking bulbs out and putting them back in still nothing, also the lamp...
the lamp units should be properly aligned with the 2 very tiny switches
between them. If not lamp led will blink.
If lamp led is continuously on, lamp timer has to be reset, according instructions that come with new units.
Original lamp modules are AH-45001 and AH-45002, two different
units needen for 1 projector, reset procedure is different for each lamp !!
Dec 21, 2010 | Eiki EIP-4500 DLP Projector Multimedia...
NEC VT 595 wont turn on. Just red blinking light
I had this same problem with 2 NEC VT595 projectors. My problem was that there was a broken "tab" on the lamp cover (the plastic cover that slides in place over the lamp) that is supposed to depress a switch which insures the lamp cover is in place before operating the projector. The tab was broken in half and not making the connection there for causing the blinking status light (.5 sec on, 2.5 sec off) indicating a lamp housing or cover error.
May 28, 2009 | NEC VT595 LCD Projector
Projector problem
I generally fix this by re-seating the bulb housing. Take it out and put it back in. Look for cracking at the base of the bulb on the mirrored surface. It could be a barely functioning bulb that isn't busted, but can't initialize. I would take it to a shop that has the same bub type in a housing and make a quick switch.
Jun 20, 2008 | InFocus ScreenPlay 4805 Multimedia...
Sony VPL CX5 Multimedia Projector Logo
626 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
