Question about Draytek Vigor 2910VG Router
Incorrect static routes appearing in route table automatically
Receiving incorrect static routes that are being automatically generated in a draytek 2910g. It is in ppoe mode behind a modem set to ppoe with passthrough.
I also have a vpn connected to my HO. My HO is running on a 10.0.0.0 network and my new office is running on 10.1.0.0 and there is a vpn. However in the new office after the router has been on for about 4-6 hours an automatically generated route will appear for one ip address in particular (10.0.0.14) and it points it at the internet gateway instead of at the vpn connection like it is supposed too. Below this mystery rule is a 10.0.0.0 point at vpn but the above rule is intercepting all data for this one particular server and firing it off into the web for no reason.. If i reboot the router the route goes for a while and then 4 -6 hours later is is back again......
Very frustrating and i cant seem to make a static route to override that one as i cant make a static route to a vpn connection.
I have exactly the same problem on a couple of Sraytek 2820vm. Did you solve the problem?
Regards Herbert
Posted on Oct 17, 2011
What Web-based Management Features Do Switches Excluding the S1700 Support?
Table 1 lists the web-based management features supported by S series switches.
Table 1 Web-based management features supported by switches Category
Function System management Upgrade, patch loading, PoE, DNS, stacking, viewing log files, and setting the system time, SNMP parameters, and EasyDeploy parameters
NOTE: Switches in V200R002 and later versions support SNMP and EasyDeploy parameter configuration. Interface management Viewing/configuring basic interface attributes and viewing statistics on an interface Service management VLAN, MAC address, STP, voice VLAN, DHCP, ARP, VRRP, and IGMP snooping ACL management Creating/modifying/deleting ACL rules and effective periods QoS Priority mapping, traffic policy, rate limit on an interface, traffic shaping, and congestion management Route management Viewing IPv4 routes, configuring static routes, and setting the preference of static routes Security management Port isolation, static user binding, AAA, 802.1x authentication, and MAC address authentication Tools Ping, Tracert, and VCT S2300 Switch Thunder link com
Feb 09, 2017 | The Computers & Internet
Tip
Show Routing Table button will open a chart displaying how data is routed...
Show Routing Table button will open a chart displaying how data is routed through your LAN. Use the example below on how to configure a static routing:
STATIC ROUTING:
192.168.2.2 192.168.1.2
ROUTER C ----------------- ROUTER B ----------------- ROUTER A--------------PUBLIC IP ADDRESS
192.168.3.1 192.168.2.1 192.168.1.1
ROUTER A: Gateway Mode ROUTER C: Router Mode
1STENTRY 1ST ENTRY
DESIP: 192.168.2.0 DES IP: 192.168.2.0
SM: 24 SM: 24
DG: 192.168.1.2 DG: 192.168.2.2
HOP COUNT: 2 HOP COUNT: 3
INTERFACE: LAN INTERFACE: WAN
2NDENTRY 2ND ENTRY
DESIP: 192.168.3.0 DES IP: 192.168.1.0
SM: 24 SM: 24
HOP COUNT: 3 HOP COUNT: 2
ROUTER B: Router Mode
1STENTRY
DESIP: 192.168.1.0 WAN IP: 192.168.1.2
SM: 24 SM: 24
DG: 192.168.1.2 DG: 192.168.1.1
HOP COUNT: 2 DNS: DNS of 1st router
INTERFACE: WAN
2NDENTRY
DESIP: 192.168.3.0
SM: 24
DG: 192.168.2.2
HOP COUNT: 2
INTERFACE: LAN
1stRouter must be set on Gateway Mode
2ndRouter must be on Router Mode
Use Static Routing
Select Entry
Destination IP = IP Subnet of the 1st Router
Subnet Mask = Subnet Mask of the 1st Router
Default Gateway = Interface IP
Hop Count = 1 + n
Interface= Connection to the 1st Router
Hope this help everyone.
on Apr 22, 2010 | Computers & Internet
Tip
HOW TO CONFIGURE STATIC ROUTING ON LINKSYS ROUTER
STATIC ROUTING:
1STENTRY 1ST ENTRY
SM: 24 SM: 24
2NDENTRY 2ND ENTRY
SM: 24 SM: 24
1STENTRY
SM: 24 SM: 24
INTERFACE: WAN
2NDENTRY
DESIP: 192.168.3.0
SM: 24
DG: 192.168.2.2
HOP COUNT: 2
INTERFACE: LAN
Use Static Routing
Select Entry
Hop Count = 1 + n
on Jan 26, 2010 | Linksys Wireless-G WRT54G Router
Does the Configuration of an Active Static Route Still Exist When the Outbound Interface Status of the Static Route Goes Down?
If the outbound interface state of a static route goes Down, the static route will be deleted from the IP routing table, but its configuration still exists.
http://www.thunder-link.com/LS-S6700-24-EI_p785.html
Aug 11, 2016 | Computers & Internet
NETGEAR DGND3700 Cannot connect to Internet
your static ip may be paired with your router's mac address in a routing table and needs cleared out by the isp before your computer can use it?
shot in the dark... hope i hit something
Mar 03, 2013 | NetGear DGND3700 N600 Wireless Dual-Band...
What is routing loop?
A routing loop is a condition in which a packet is continuously transmitted within a series of routers without ever reaching its intended destination network. A routing loop can occur when two or more routers have routing information that incorrectly indicates that a valid path to an unreachable destination exists.
The loop may be a result of:
Incorrectly configured static routes
Incorrectly configured route redistribution (redistribution is a process of handing the routing information from one routing protocol to another routing protocol and is discussed in CCNP-level courses)
Inconsistent routing tables not being updated due to slow convergence in a changing network
Incorrectly configured or installed discard routes
Jun 07, 2011 | Linksys EZXS55W EtherFast 10/100 5-Port...
I have a 3com 4500 connected to 2 5500s (A & B), which are the the GWs for the 4500. I issued on the 4500: ip route-static 0.0.0.0 0 192.168.0.254 preference 60 (5500 A) ip route-static 0.0.0.0 0...
From your scenario what i guess is the two 5500's (A&B) are connected to each other also. Thats why the link between B&4500 is remaining down due to STP ( to avoid Network loop).
Please correct me if I am wrong.
What is the status of the link connecting 4500 to 5500 B when 500A is active and when 5500A is down .
If you are running STP i will suggest you to wait for 2 minutes after 5500A goes down and STP will be recalculated and the link connecting to 5500B will become active and then the route will also become active.
Best regards
Nov 02, 2010 | 3Com 4500 24-Port Ethernet Switch
Can't get SMS messages for the passed few days.
Have you tried the SIM in another handset? Have you reset the handset to default (carrier) settings? If outbound SMS does not work even in another handset, it is more than likely an incorrect routing table entry on your providers end. I had a similar issue where I could not be contacted from one certain network after a number port to a different carrier. The old carrier missed the routing table entry and all my calls from the network were being directed to the wrong IP/Destination.
Mar 15, 2010 | RIM BlackBerry Bold 9700 Smartphone
Transfering Routes to GPS device
Once you have transferred it using mapsource it won't automatically be in the custom routes. You still have to "import it from a file". Unplug your garmin from the computer then go to "Tools" then "My Data". That's where you should find the "import route from a file" button. It won't import if you already have 10 custom routes saved so you'll have to delete one.
May 03, 2009 | Garmin Nuvi 550 GPS Receiver
Private network > VPN > network firewll > priv net
Add a static route on the Sonicwall 2040 : 192.168.1.0/24 with the RV082 as gateway (the ip of the network shared between the RV082 and the Sonicwall)
Another solution is to enable NAT on RV082 for 192.168.1.0/24 network. Routing is preferable.
Feb 14, 2009 | Linksys RV082 10/100 8-Port VPN Router...
Draytek Vigor 2910VG Router Logo
409 people viewed this question
Top Draytek Computers & Internet Experts
David Payne
David Payne
Are you a Draytek Computer and Internet Expert? Answer questions, earn points and help others
