Question about Dryers
Dried a load of clothes and put another load in and now it's not working. Timer is clicking, but when I push the start button it does not kick on. Tried different settings and still nothing. It's been working fine up to this point. Unplugged it and plugged it back in and still nothing. Dryer is 2 years old.
  • 986 Answers
Sometimes blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Posted on Sep 12, 2009
Dryer won't start and has a burning smell.
there should be a fan in the unit that blows air over the element and through the clothes
there should also be a thermostat that sets the element temp to low mild or hot according to the switch on the front
Jan 20, 2016 | Maytag Centennial Series MEDC300XW
Press button dryer clicks but doesn't start
then it means motor is got jammed..
Mar 12, 2008 | Kenmore 63942 Dryer
Electrolux Washer dryer EWW 1273 banging
I think a sensor is being faulty when you load and go to use the unit. Also might want someone to check out the timer on the unit just in case it is going out on you.
Aug 08, 2012 | Washing Machines
Dryer lights works, but when the start button is pushed the drum does not spin. the timer shows the minutes counting off, but no spinning. the dryer worked yesterday, but no today. dryer is a duet...
I am having the same problem. Dried towels last night. This morning, I loaded it, turned it on, it did not lock the door or start drying (spinning) but the timer started counting down. I pressed Cancel twice, unplugged it for a few minutes then tried again. Problem still exists. Any suggestions?
Aug 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Washer runs when timer dial turned though ON button not pushed
Problem solved by ourselves! It was NOT in the circuit board (brain) of the machine. It was NOT in the door locking assembly as others would lead us to believe. It WAS the on/off switch on the control panel--part number 22002560 - a $22.00 problem fix.
Jan 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
LER8858EQ2 electric dryer will not come on.
Thermal fuse on the blower housing is open. Take back off and the thermal fuse is near the blower outlet. It is white and about 2 inches long. Part number is 3392519
Dec 12, 2008 | Whirlpool LGV4634JQ Gas Dryer
Dryers Logo
42 people viewed this question
Top Dryers Experts
