Question about Philips Magnavox 27MS343S 27" TV
Black square on screen won't go away
I have a black square in the middle of my screen. It happened while I went into the menu to try to get captioning on
  • SD Tech
    SD Tech May 11, 2010
    I have a tip for you--go back into the menu and in the closed caption area you will find you have selected "TEXT" ---THIS IS WHY THE BLACK BOX IS THERE--it usually is only on certain channels--move to off or cc2 or anything except Text one--let me know if this corrects if for you--I do this here for free.
    Sergeant:
  • 269 Answers
Hi! have on the text option, just turn it off
Posted on Sep 11, 2009
How to clear a square on tv screen that has a black rectangular block in middle of picture?
it could be you have pressed the old teletext service button, look for a button with 3 lines on it in a box and press it or try turning the tv off at the plug then back on again.
Jan 22, 2015 | Televison & Video
Black Box appearing on my screen
go into your menu and access the closed caption modes. someone has accidently put your tv in the "text" mode. turning off the closed caption feature will correct this.
Apr 01, 2009 | Televison & Video
Black Square in bottom half middle of screen
It sounds like your panel is going out and time for a new TV
Nov 30, 2017 | NEC PlasmaSync 50MP1 50 in. Television
Black square
Black square in the middle could be closed captioning. Light engine is approx. $700 to $1000 for the parts alone. Time consuming job to change - 2 hours - so expect a hefty labor charge as well.
May 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Black square
If the picture can be seen on the sides of the black square you need to go to the menu and find the text and turn it off
Usually in the closed caption section
Mar 12, 2008 | JVC AV-27230 27" TV
Black square
hmmm...the black square syndrome..sounds like the picture in picture settings are unhappy..check those, to see if maybe it's on some sort of timer, and accessing a non channel(which might explain the black square).
Feb 29, 2008 | Hitachi 57F500 57" Rear Projection...
Black Square
Turn Off the CC Caption inside the Setup Menu.
Dec 31, 2007 | Insignia IS-LCDTV32 32 in. Television
Black square in middle of tv
He, he. Somebody activated the subtitle mode on the remote. Desactivate the CC mode on your menu and it'll go away or at least if you want CC put it in CC1 Text1
Dec 10, 2007 | Hitachi 50FX20B 50" Rear Projection...
BLACK SQUARE IN THE MIDDLE OF THE SCREEN
Find menu selection for closed caption. Note TEXT box ......Step through selections in that menu until you see text change to
closed caption and then select off.....Hope that helps....T.
Nov 04, 2007 | Hitachi 51F510 51" Rear Projection...
Black out screen
I had the same problem once with my RCA television. It only happened on certain channels and didn't happen during commercial breaks. If I adjusted the volume on the tv the box went away, but came back shortly after. The problem ended up being some malfunction in the closed captioning. I turned it all off and changed the CC settings and never had the problem again.
Oct 05, 2007 | Westinghouse W33001 30 in. HD-Ready LCD...
Philips Magnavox 27MS343S 27" TV Logo
801 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
