SOURCE: Message that tray is out of paper, and tray is not in machine.(SHARP FO-5700 Fax)
Go underneath the machine and make sure that a black piece of plastic is secured in there. Sometimes they get pulled out when the tray gets removed.
SOURCE: Sharp Model FO-4700 Facsimile,
unpluge the scanner and pluge back reset the scanner setting to default factory setting then try.
SOURCE: sharp plain paper fax FO-A660 dialing but not
First test the phone line with a conventional telephone, make sure you have a dial tone. If you do make sure the phone cord from the wall is plugged into the correct port.
SOURCE: want to know how to
1 - Grasp the finger hold and pull up to open the operation panel.
2 - Flip up the front paper guide.
3 - If you are loading paper that is 210mm in width, place the paper roll shims on each side of the paper compartment. (Note that Sharp recommended paper, including the initial roll, is 216 mm in width.) • The ribbed side of the shims should face in (toward each other).
4 - Unwrap the roll of thermal paper and insert the paper shaft.
5 - Place the roll of thermal paper in the compartment, making sure the ends of the paper shaft fit into the notches on each side of the compartment.
• Important: The roll must be placed so that the leading edge of the paper unrolls as shown. (The paper is only coated on one side for printing. If the roll is placed backwards, the paper will
come out blank after printing.)
6 - Insert the leading edge of the paper into the slot as shown. Continue to push the paper through the slot until it comes out the opening in the front of the machine.
7 - Make sure the paper comes out straight, and then flip down the paper guide.
8 - Close the operation panel, making sure it clicks into place.
• FO-71: A short length of the paper will be cut off.
SOURCE: I have a sharp fo-dc535
remove the paper trays, push your hands to the back where the machine pulls the paper from the tray, to the sides there are switches, play with it a bit, turn machine on with paper trays out, open cover and close it, it should work fine now.
