Question about Dell Latitude D600 Notebook
Dell adapter light come on the shorts when put into computer
I have the same problem, but i dont understand what the person is saying about the solution
  • Ekse May 11, 2010
    Could you be alittle more spesific and what solution is that?
  • 77 Answers
What do you mean dell adapterl ight come on? ac adapter light come on when plugged in to wall outlet? but hwen plugged in to system it turns off? is that it? try the same adapter on another computer, if adapter works fine. motherboard for computer needs to be replaced for port issue.
Posted on Sep 12, 2009
I put in a new hard drive it says the same thing dell ******* sucks parameter has exceeded its normal operating range
The hard drive may be failing, or just the OS or hard drive corrupted. You could try this... Pull the hard drive out, and use a USB Hard Drive Adapter to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive.
Then, you could try to do a Factory Restore on the computer, and if that works, copy your personal files back to your newly restored computer.
Good luck.
Jul 26, 2014 | Dell Inspiron 580 Desktop Computer (Intel...
Dell inspiron 560 won't recognize network adapter
if there is no netework adapter in device manager or any device that is not instaled try checking in BIOS if it is enabled. sometimes after power loss bios is reset. if it is enabled in BIOS that short power outage probably killed your network adapter. you can add some PCI network adapter and solve your problem.
Nov 04, 2012 | Dell Inspiron 560 MT Celeron 450@ 2.2GHz...
All my Dell power adapters are dying! I have 3 and none work now. The first one started saying it was not compatible, then the next one worked for a short period then the green light went out. I put one...
Yes! unfortunately it is, the reason why the power adapter has the high pitch noise is because the power supply is being loaded down by the motherboard, it may be due to the DC jack in the laptop or the charging circuits on the motherboard causing the problem. However there is one way to find out, remove the main battery to see if the high pitch noise goes away, if it does! it will prove where the problem is. It is also very possible that the battery is loading the whole circuitry, because it may have a high resistance short, enough to cook the power supply, I have seen this in very rare cases and is one for the books.
Mar 11, 2011 | Dell Inspiron 5100 Laptop
I have a power problem with my dell precision M20. The green light shows through the adapter, but as soon as I plug it into the machine, it goes off. Suggestions..?
there is a bridge somewhere, that's why it turns off when you plug it into your machine.
I would suggest that you find someone that uses the same adapter with your machine, then use the persons adapter to test your machine. If it still goes off, then you will know that the bridge is from the machine. But if it does not turn off, then you will know that the problem is from your adapter.
I hope you are able to understand my message.
Good luck.
May 02, 2010 | Dell Precision M20 Notebook
I have a Dell M20 and it has stopped turning on. the green light on the adapter is illuminated when plugged into the wall ... then when plugged into the power port on the M20 the green light goes out. ...
I want to say that it sounds like a short in the wires for the adapter. I doubt that a motherboard would cause the light to go out on the adapter. Go to best buy, frys, or some computer store and ask them to let you plug your laptop in to test and see if it is the wire. They surely have a dell being displayed and usually they will let you plug it in with that wire to see if it works.
Dec 27, 2009 | Dell Precision M20 Notebook
Dell Inspiron E1505 shorting out adapter
I would replace the battery if you had for some time. Over time charging a battery will slowly not take a charge. If you tried two adapters, about the only thing is left is the battery.
Aug 18, 2009 | Dell Computers & Internet
I have a Laptop, Dell Inspirion 9100. Recently it
I would suggest testing your laptop with another adapter, first. Then you'll know whether to replace the adapter, which is priced around $50.
Aug 01, 2009 | Dell Computers & Internet
I bought a new battery for my dell inspiron 6000 but i cant charge it the powercord light gose out when i plug it into the computer and the computer shows no sign that any power is reaching it i dont know...
That sounds like the AC adapter has gone bad, probably a short circuit inside it. Take it to a electronics store and see if they will test it for you.
Mar 18, 2009 | Dell Inspiron 6000 Notebook
The network adapter in a dell dimension PC running XP home
Ethernet controllers click here
Check for drivers on that site, however much better that you know the brand of your LAN adapter.
Mar 15, 2009 | Dell Dimension 8250 PC Desktop
Dell 1450 wireless adapter
Yes, the driver can be corrupted and you need to reload the driver or better download the latest one and use that instead to make sure your adapter is using the right software for it...
Hope that helps... Don't forget to rate the solution FIXYA thank you
Oct 05, 2008 | Dell 1450 (D1450U) Wireless Adapter
Dell Latitude D600 Notebook Logo
50 people viewed this question
Alun Cox
