Question about SanDisk Sansa Fuze MP3 Player
How do i connect my mp3 player into my aux in my scion xb?
  • 36 Answers
Its very simply thiers aux cable available in market ......... how do i connect my mp3 player into my aux in my - 94a55ff.jpg00f4d01.jpg
Posted on Sep 11, 2009
Remote starter only allows my starter to turn over twice; needs at least 3 with my key. How to adjust to have it starter run longer on remote?
I know you are looking to have the remote starter run a third time but I would say you need to look at your Fuel Pressure Regulator on the Scion. Sounds like it is not holding fuel pressure at the fuel rail and that is why it requires a third Crank
Jan 05, 2016 | 2006 Scion xB
2005 scion xb
I would let a qualified mechanic do it
Sep 24, 2014 | 2005 Scion xB
How do you fix a stuck volume button on scion xb stock stereo?
The only way to fix it is to take it apart and see if it is just jammed or if the button is defective if defective you neeed to replace it they are very small so you need some good soldering skills. Hope this helps.
Aug 21, 2014 | Pioneer 2005-2006 Scion Tc Xa Xb Cd Mp3...
Different or additional harness needed to install a Kenwood kdc 255u radio/cd player in a 2005 Scion XB?
YES.... to prevent cutting of any factory wiring (this use to be the old install method and requires much more time and expense) and potential electrical fires, you can now buy quite cheaply, what is called a Radio adapter harness.
As you wish to install a Kenwood radio to your Toyota Scion, simply buy an adapter loom which has a 2005 Toyota Plug on one end, with a Kenwood plug on the other (this essentially replaces the wiring loom that came with your Kenwood unit).
So, it's that easy .... Plug and Play.
And... if you sell your Toyota and wish to put your old Toyota radio back in, the original radio just plugs back in. PRESTO !
Hope this helps..
Cheers,
Scott
Jan 17, 2013 | Kenwood KDC 255U - radio / CD / MP3 player...
My 2005 scion xb won't go into overdrive and the speedometer doesn't work
run the fault codes and look for a failed VSS sensor
Feb 22, 2012 | 2005 Scion xB
Scion XB automatic door lock, driver's door not working with remote. How do I reset it?
This is a common problem on the Scion XB, replace the drivers door lock actuator and you should be fine.
May 19, 2011 | 2005 Scion xB
How can i install the alpine iva-w200 to my scion xb if the scion xb has alot more wire harness connected to it?
There are companies out there that make installation harnesses. There are two companies that we (my shop) use currently. Metra and Best Kits. For a dashboard installation kit I recommend going with Metra but for the harness it doesn't really matter. You should be able to get both for under $20 each. The websites where you can get part numbers for both the harness and dash kit are metraonline.com and bestkits.com. The installation harness makes the job a lot easier. The wires are color coded with the majority of the head units out there. Use **** connectors or crimp caps. Not just electrical tape like most bozos out there. Good Luck!
Sep 28, 2010 | Alpine IVA-W200 2-DIN DVD/CD/MP3/WMA...
2005 scion xb: pioneer stereo
No they do not, but if you have an Aux plug in the front of the player, which some XB's come with, then you would just use that instead of tearing out your original player
Apr 27, 2009 | 2005 Scion xB
SanDisk Sansa Fuze MP3 Player Logo
105 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
