Question about Homedics EnviraScape Mariposa Illuminated Relaxation Fountain Black Sand
I need new air pump for Homedics Aquascape twist lamp. Pum is Model:P-12-3
I have an older & slightly different 4 sided tapered Homedics aquarium, but it has the same pump. I used a meter to determine that the proper voltage was coming out of the transformer, measured at the plug. I took the base apart & bypassed the female connector switch the transformer plug, plugs into. Everything worked fine, meaning the fail was in the female connector, as the wires were solidly soldered on. With a magnifying glass, I could see that a rectangular "C" type copper flange, had the side that touches the side of the plug when inserted, had broken off, therefore making no connection. Using an insulated screw driver, I temporarily completed the circuit & confirmed the problem. Cut out the old female connector & take that & with the transformer (& its plug) to an electronic components store & find a suitable replacement. You will need additional heat shrink tubing & to solder the connections.
If your pump is truly not working even if it is getting power, I don't know the answer the full answer to that. A privately owned aquarium store may test the pump for you, & offer to feel or replace the diaphragm & check valves if the motor works. I see the screws are painted with locktite after re-assembly so the parts don't vibrate loose. Good Luck.
Posted on Nov 16, 2011
Need manual for cvsbpw-610
google the make model and error number
Mar 05, 2015 | Dryers
Where to buy a 20' power cord for Aquascape Pro 4500 pump?
Maybe try to just buy a 20' extension cord cut off the connecting end and hardwire into the unit.... ?
Oct 26, 2012 | RTO AquaScape 4500 GPH Pump
I need seal kit for aquascape pump 7500
www.thepondoutlet.com
Call or email, they will either sell the seals or tell you where you can find them
Sep 05, 2011 | Ultra Max Aquascape AquaBasin, Pond or...
Homedics aquascape blfw500; instruction manual
Here is The Companies web Site hopefully they can get it for you or you can download it from their web site. :
http://www.homedics.com/contacts/
Aug 07, 2011 | Computers & Internet
My Aquascape 4500 pump immediately trips the GFI when I plug it into an outlet. This happens both when it is submerged and out of the water. The impeller is not obstructed.
The seal has failed allowing water into the sealed motor unit and it is now shorted to ground...in other words the unit is shot and needs to be replaced.
John
Apr 07, 2011 | RTO AquaScape 4500 GPH Pump
I have a HoMedics p-12-3 twist lamp, and its missing the bulb i was hoping to find a diagram of the electonic part of the lamp so i can see how a bulb would go in, because right now its just a metal hoop...
email me at Morris042@ymail.com and i can send you a PDF diagram of the solution. All you need is a 12V 20W flood light bulb. You can pick it up at any hardware store. It's about 1.3 inchs wide. The metal hoop and springs are what holds the bulb in place due to the vibrations from the pump.
Mar 30, 2011 | Home
My pump has locked up is there any way to fix it
No,
They are made overseas and there are NO parts available to replace anything damaged inside your unit. Unfortunately your choices are a new unit from Aquascape or a new unit from another manufacturer. In our experience none of the units are 'great' for durability but aquascape lasts as long as any others, some others are worse.
Oct 26, 2010 | Aquascape Designs PUMP AQUASURGE 3000 ()
Aquascape 4500 pump trips breaker when plugged in
water getting into pump.Thats what is triping it.
Jul 31, 2009 | RTO AquaScape 4500 GPH Pump
Rebuild kit for the Aquascape SFA3000 Pump???
I have had the same problem everyone else has had with these pumps. I did serious research on these pumps and came up with a rebuild kit some parts bought some I make. I did mine 2 years ago and still working like a champ and have done over 20 locally with no problems. If your pump is noisy or the impeller has fallen off (typical) due to water getting in the unit and causing the bearings to fail email me and I can rebuild your pump. The process is simple send me the pump I will look at it and see if it can be rebuilt at NO CHARGE if it can be rebuilt you will save over 60% of a new one. Don't spend $349 - $599 on a new one let me look at it for free if I can rebuild it great if not you will have to buy a new one. I am not a dealer for any pumps so you will not have to worry about me selling you a pump and if you want the old one back pay the shipping and it it all yours.
Jun 18, 2009 | Ultra Max Aquascape AquaBasin, Pond or...
Homedics EnviraScape Mariposa Illuminated Relaxation Fountain Black Sand Logo
1,268 people viewed this question
Top Homedics Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
Are you a Homedics Garden Expert? Answer questions, earn points and help others
