Question about Brother HL-2040 Laser Printer
Drum light The drum light keep flashing not in a fast way , but I used the resetting way , opeen door , turn on with pressing Go bottom , then release then press twice then wait them press 5 times , the drum light keep flashing , is this mean I need to change the drum , or Can I reset it in another way to check before replacing the drum that is a drum problem
  • sam67 Dec 11, 2007
    the drum is fine , even , when i tried to print test page by pressing the Go bottom 3 times , the all light went on , when I pressed the Go bottom all the lights off but not the paper one which kept on
  • Brother Master
  • 1,113 Answers
Drum light reset below
Open cover
Press and hold down Go button for about 4 seconds until all the LEDs light up. Once all 4 LEDs are lit, release the Go button
Close cover
link to MANUAL
Posted on Dec 12, 2007
  • Soulvisitor
    Soulvisitor Dec 12, 2007
    manual links is 2070
  • Soulvisitor
    Soulvisitor Dec 20, 2007
    • The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
    • The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
    Open the front cover of the printer.
    Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button
    Close cover
    Link that explains the little brothers HL 2040/70 Lights
    Sergeant:
    Novelist:
  • 143 Answers
I have the HL-2070. Great printer.
Shut down the machine. Consider unplugging it. (You never know...)
Remove the drum/toner cartridge assembly. Find the blue tab near the FRONT of the drum. (It has a little arrow on it.)
That tab is meant to clear debris from the front of the drum. This could be your problem. Slide the tab back and forth several times. BE SURE TO RETURN THE TAB TO THE ORIGINAL POSITION which is marked by another arrow in the grey plastic.
Return the drum to the machine. Turn it on and see what you get.
Report your results here when you are done.
Keep in mind that you may be looking at replacing the drum.
Click HERE for the drum at Staples.
Click HERE for the toner cartridge.
Posted on Dec 13, 2007
    Sergeant:
    Champion:
  • 317 Answers
Check if the drum itself is not worn out or scratched, if not it would also be helpful to see if there is something stuck along the print path.
Posted on Dec 10, 2007
Drum 0% Remaining?
you need to install a new drum and then reset the drum counter:
1.- Open front door
2.- Change the drum Unit
3.- Press Go button and keep pressing until the 4 lights turn on
4.- Release the button and close the door
Oct 30, 2013 | Brother HL 2140 Laser Printer
Reset HL5470dw drum
1.- Open front door
Jul 15, 2013 | Brother International HL-5470DW hl5470dw...
I relaced the drum yesterday on my HL-2170W but the drum light keeps flashing - how do I get it to remain off?
To reset the drum message:
Open the front door
Press and hold down the white button for about 4 seconds. Once all 4 LEDs are lit, release the button.
Close the front cover. Make sure that the Drum LED is now off.
Oct 31, 2010 | Brother HL-2170W Laser Printer
Drum light keeps appearing
  1. Open the front cover of the printer.
  1. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  1. Close the front cover
Mar 31, 2010 | Brother HL-2040 Laser Printer
I've recently installed a new Brother toner, but the drum light is flashing and the Brother hl 5140 printer won't print
DRUM UNIT "spent"
It can be reset if the printing quality is good
Press the cover release button and then open the front cover of the printer.
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
Caution: Reset the drum counter only when you replaced the drum unit with a new one.
Oct 09, 2009 | Brother HL 5140 Laser Printer
Brother HL 2040 drum light flashing after drum replacement
The drum light is triggered by a page counter. To reset it, hold the GO button with the drum door opened until the light goes out (10 seconds). Close the door and it should be reset.
Aug 07, 2009 | Brother HL-2040 Laser Printer
Resetting the Drum counter on a Brother HL-2040
Hi.
Have you recently replaced the drum?
  2. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  3. Close the front cover.
Aug 03, 2009 | Brother HL-2040 Laser Printer
Replaced drum on Dell 1720dn printer. Where is
This should fix the drum light being on that 1720
Turn off the power using the switch on the back of the printer. Open the front door of the printer. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit. Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit. Cycle the power of the printer: Remove the power cable - Wait for 5 seconds - Plug the power cable back to the printer - Power the Printer on.
May 13, 2009 | Dell 1720dn Laser Printer
Brother printer Hl 2070. Toner light is on , changed the toner , still yellow light is on and I can't print
From Brother.com: Description:
  1. Close the front cover.
Caution
Apr 06, 2008 | Office Equipment & Supplies
Drum light flash Brother HL 2070N
You need to have the front of the printer open, when you press and hold the 'Go' button. All four lights will come on, in sequence. Release the button, and close the front cover. Done...
Feb 27, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
700 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
